Test / Review: Sibeile IMR18650 3400mAh (Black)
13 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 19 hours ago
DSC_3098
Official specifications:
  • Nominal Capacity: 3400mAh(0.2C, 2.50V discharge)
  • Minimum Capacity: 3350mAh (0.2C, 2.50V discharge)
  • Charging Voltage: 4.2±0.05V
  • Nominal Voltage: 3.6V
  • Charging Method: CC-CV (constant voltage with limited current)
  • Charging Current: Standard charge: 1700mAh, Rapid charge: 3400mAh
  • Charging Time: Standard charge: 3 hours, Rapid charge: 2.5 hours
  • Discharge Cut-off Voltage: 2.50V
  • Cell Weight: 48g max.
  • Cell Dimension: Height: 65.00mm max. Diameter: 18.25mm max.
  • Operating Temperature: Charge: 0 to 45 °C Discharge:-20 to 60°C
Sibeile%20IMR18650%203400mAh%20(Black)-info
This battery performs like the Panasonic 3400mAh cell with added protection.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
DSC_3044 battery%20pack-1
After shipping the samples to me, some print was added to the box.
DSC_3099 DSC_3100
DSC_3101
DSC_3102
Sibeile%20IMR18650%203400mAh%20(Black)-Capacity
The discharge curves has good tracking, but the protection in this battery has a rather low current limit, it prevented doing a 3A discharge test.
Sibeile%20IMR18650%203400mAh%20(Black)-CapacityTimeHours
Sibeile%20IMR18650%203400mAh%20(Black)-Energy
Sibeile%20IMR18650%203400mAh%20(Black)-PowerLoadTime
Sibeile%20IMR18650%203400mAh%20(Black)-TripCurrent
Sibeile%20IMR18650%203400mAh%20(Black)-Charge
Conclusion
With the exception of the low current limit this cell has good performance.
Notes and links
According to Sibeile the IMR text will be removed from the next batch of cell.
The batteries was supplied by Sibeile for review.
Edited by: sb56637 on 08/26/2014 - 17:45
djozz
djozz's picture
Last seen: 1 hour 34 min ago
Thanks!! The low over-current cut-off will not appeal to many flashaholics.
kreisler
kreisler's picture
Last seen: 8 years 3 weeks ago
Thanks for your work, HKJ!
I will stick to generic Protected ncr18650b. Great resilient wrapper, original Panasonic, everybody has them. Wallbuys 13.80$ per pair.
Same with Eneloop, they've become inexpensive (ebay). Why would i bother buying something else.
*FMI* i got 4 i/o sh
MRsDNF
MRsDNF's picture
Thanks HKJ. Would the low current capability of the battery be because off a cheap battery protection circuit?
Milan
Last seen: 2 days 8 hours ago
kreisler wrote:
Same with Eneloop, they’ve become inexpensive (ebay). Why would i bother buying something else.
Are you sure they are genuine?
got link?
ryansoh3
ryansoh3's picture
Thanks for the review!
The protection test graph seems a little wonky. I think it should start at 0.0A and should be scaled to a maximum of 3.0A to accurately show the data.
BLF ≠ B-grade Flashlight Forum
HKJ
HKJ's picture
That would have been better for this cell, but I have kept same format as for all other 18650 batteries (All chart are made from the same scipt).
ryansoh3
ryansoh3's picture
I see, thanks for the clarification.
tivo532
tivo532's picture
Last seen: 7 years 1 month ago
HKJ
Thanks for your reviews. I’m interested for battery voltage versus current chart. Do you have this data. I may have missed it. Looking for good batteries that doesn’t sag too much at high current. Beer
HKJ
HKJ's picture
tivo532 wrote:
HKJ Thanks for your reviews. I'm interested for battery voltage versus current chart. Do you have this data. I may have missed it. Looking for good batteries that doesn't sag too much at high current. :beer:
You can always use my comparator.
tivo532
tivo532's picture
HKJ wrote:
tivo532 wrote:
HKJ Thanks for your reviews. I’m interested for battery voltage versus current chart. Do you have this data. I may have missed it. Looking for good batteries that doesn’t sag too much at high current. Beer
Excellent! Exactly what I’m looking for.
Thanks HKJ!
EDCPlus
Last seen: 7 months 1 day ago
Goes to show the Chinese will put IMR on anything just for marketing purposes.
sb56637
sb56637's picture
Last seen: 9 min 28 sec ago
Thanks a lot for the review! Frontpage’d and Sticky’d.
