cnqgoods - you'll probably get the light but will never have an emial answered .
manafont- will probably send you a fake that will break and then they won't respond to your emails .
Focalprice - will send you the wrong light and try to get you to pay for return shipping /and half the time paypal will see this as fair .
Kaidomain - will send you a broken light and be clueless as to why that would bother you .
Wallbuys - will send you the AA light but list it as an 18650.
Dx - would take 3 months to ship it.
There is still a reason 90% of us still love Fasttech ....If they go straight to hell at this point ....it's been a good run and was nice while it lasted.
Are you saying that you think the one from WB is a 14500?
Comparing pics on FT and WB (the side profile), it looks like the one on WB has a relatively longer middle section/battery tube than the one from FT, so it seems like the WB one is an 18650 light.
I’m still hoping that you’re correct, that I’ll get a 14500 light :)…
I’ve actually gone ahead and put 2 images next to each other and measured a bit. The middle section in the FastTech picture is in fact shorter than the one in the WallBuys picture. The difference matches the 16mm length difference in the description of the 2 sites (FastTech 107mm, WallBuys 123mm). 16mm matches pretty well with the difference in length between 14500 and 18650. They both have the same diameter though, 23mm, which is rather big for a 14500 light.
Maybe those lights, the 18650 one and the 14500 one, are members of a family of flashlights that all have the same tail and same head, and in the factory they just play lego at the end, to produce a 14500 or a 18650 ? It would explain why they have the same diameter and different lengths.
That’s an option as well ofc . I just noticed the picture of the individual components of the FastTech 14500 version. The tube is really thick there.
I do wonder whether the specs for the input voltage are correct, as the CR123A one also says 3.7-4.2V. If it’s correct, I think that would mean it’s actually only for RCR123A cells, not for non-rechargable 3V cells.
