Mini rebuild of Tangsfire TS-2010 from tmart
8 posts / 0 new
furythings
Last seen: 2 years 7 months ago
Never intended to get one of these as I’m not into throwers but when it popped up on offer at $9.90 I could hardly say no now could I.
1st thing I noticed was a rattle which I assumed was the 26650-18650 tube which it half was as the pill was also loose and rattling .
Looking over the light the finish is ok, up close there are a few sub 1mm dings on the head area but nothing to see at a normal distance.
Stripping the light finds all the o-rings present but all the threads are dry, the reflector had a good bit of (thankfully) loose dust on it so it was easily blown off.
The pill had metal shaving in it and some large bits of drill swarf ready to fall off which is not great.
Driver was an east-092
Quick check with everything stock I got 2.2A at the tail
After changing the wires to 20awg and then again to 24awg as 20awg was too thick, resoldering the driver spring and re pasting the star which was glued unevenly, I still get 2.2A Sad guess my east 92 driver is not one of the good ones.
So I took the 6× 7135 Nanjg 105c driver out of my 502b stuck on 2 more chips and then stacked another 2 to up the output and now I get 3.4a at the tail so much better and I can ditch the flashy modes Smile
No driver retaining ring any more as the 7135 chips get in the way so I used a bit of desoldering braid on one edge of the pcb to make it a tight fit so the driver stayed put.
Have to say I rather like it, didn’t think I would but I quite enjoyed playing about with it and am already thinking of modifying it to improve the beam and stack a few more 7135 chips and maybe stick in an XM-l2, but that can wait till summer is over and darkness starts to return.
Ouchyfoot
Ouchyfoot's picture
Fun mod. Always great to have an inexpensive light with possibilities.
What’s the beam like? Hot spot? Any rings?
DayLighter
DayLighter's picture
Last seen: 4 years 6 months ago
at $9.90 ?!? Shocked
The only way to do a great work is to love what you do.
Jerommel
Jerommel's picture
Last seen: 1 year 6 months ago
Wow, what an annoying price! Silly
Any link worth mentioning?
furythings
Ouchyfoot wrote:
Fun mod. Always great to have an inexpensive light with possibilities. What’s the beam like? Hot spot? Any rings?
beam is a bit ringy which is why I’d like to improve that if I can but to be honest you don’t really see it in normal use so I’m not in any rush to sort it.
Jerommel wrote:
Wow, what an annoying price! Silly Any link worth mentioning?
did post it at the time but there was only 1 left so as you’d imagine it didn’t last long.
Pulsar13
Pulsar13's picture
Last seen: 2 weeks 12 hours ago
I saw the $9.90 price on my phone, IN stock, ran to the computer and it was already sold out. Smile
Your FET was the 06N03, which should be the good one. I wonder why it pulled only 2.2A.
WarHawk-AVG
WarHawk-AVG's picture
I wonder what gauge the wires were from the driver to the emitter
A few simple “tweaks” help these things pull better current…
If it still has trouble…the OSHPark FET driver might be a good route to go
What does the centering ring look like on the emitter, does it have a high shelf around the dome, if it does that might result in ringyness
Pretty cool review…need some beam shots Big Smile
Oh wow…you did change out the wires, odd, not good when you can’t push 3A out of a East-92, darn
ImA4Wheelr
Congrats on the score. Nice review and mod.
