Suitable hosts for 24mm quad optics.
50 posts / 0 new
RaceR86
RaceR86's picture
Last seen: 5 years 11 months ago
Looking for suitable hosts for 24mm quad optics. Preferably without much modifications.
Quad mcpcb is 20mm. Quad optics are 24mm.
ZY-T11 (pictured below) is good with a 22,6mm head opening. Id guess openings around 22 to 23,5 are ideal??
Djozz posted this picture here. Fits Supfire A6-T6 nicely too.
Anyone else that's got nice options for epic handburners bright small flashlights?
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Edited by: RaceR86 on 07/05/2014 - 11:19
WarHawk-AVG
WarHawk-AVG's picture
How wide is the Ultrafire F13?
Duh, broke out digital calipers…glass is 36.82mm, reflector OD is 36.78mm
That is a REAL nice setup you got there with the quad!
RaceR86
RaceR86's picture
lol yeah.. Head opening in F13 is more than 33mm.
P60s are usually around 24,9mm, give or take. So the head opening needs to be smaller than those if you want a simple and nice fit. Not larger than P60 sized.
ohaya
Last seen: 3 weeks 4 days ago
Hi,
If I might ask: Where’d you get the star and the lens?
Thanks,
Jim
RaceR86
RaceR86's picture
ohaya wrote:
Hi, If I might ask: Where'd you get the star and the lens? Thanks, Jim
http://budgetlightforum.com/node/25953
djozz
djozz's picture
Last seen: 31 min 53 sec ago
The star is custom made by member Dsche. He has a thread about it: http://budgetlightforum.com/node/25953
The optic is a Carclo optic, available in many places, bought mine at Conrad.nl
Racer: I have of course looked around for hosts too, there's not many, another host that I l found (and bought) is the Fandyfire P03. I'm on my phone now, I will post some dimensions tonight.
scottyhazzard
scottyhazzard's picture
Last seen: 2 years 7 months ago
Wow, I was wondering the same thing with those quad MCPCB’s. I was hoping to find a way to get the lens into something smaller in diameter than a Solarforce /P60 format. Needless to say I’ll be following this thread.
"Those who hammer their guns into plows will plow for those who do not."
scottyhazzard
I found this|1298769386 I hope it has a momentary switch! Then it could use the STAR firmware with strobe and other niceties. Quad XPG2, FET driver with STAR firmware, 26650 battery. Would make a nice camp light.
leaftye
Last seen: 1 year 1 month ago
That looked so nice, then boom, non anodized tailcap threads.
Comfychair has a post showing how to make an adapter ring to fit smaller optics into bigger heads.  It should be doable with a drill press.  I have a milling bit in the mail, so I'll be giving that a try soon.
The low mode should be lower.
djozz
djozz's picture
Solarstorm/Fandyfire SC02 (don't have one but the size is right). It has an electronic switch so it needs a suitable driver.
RaceR86
RaceR86's picture
Indeed! Size is very right. 22,5mm head opening..
Just look at it.
I forgot I had that light when looking for suitable lights. This light needs a quad rebuild!
comfychair
comfychair's picture
Last seen: 5 years 8 months ago
On the UF-T50 & 'PH-08' clones, the bezel thread ID is 26.3mm, bezel front opening is 23mm.
Roche F6 uses a 24mm lens. The bezel opening is small (~20mm) though that can be enlarged. Great quality on those as a host. Not much space in the driver compartment, it would have to use the stock driver or a dedicated redesign of the BLF-20DD.
Cereal_killer
Cereal_killer's picture
Last seen: 2 years 3 weeks ago
Helios has a F6 OSHPark driver in the works…
wight
I don’t think it’s “in the works” so much as “waiting for a crash dummy volunteer to test it”. Wink
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
scottyhazzard
anybody have a link to comfychair’s honing down of an optic?
djozz
djozz's picture
Suitable host for a 35mm triple optic? Smile
wight
Do you mean post #23 in your thread here: Recommend a bench top drill press ?
comfychair
scottyhazzard
I’m losing my mind, Wight! Thanks, Comfychair, I am subscribed to that one you posted as well. They say the mind is the second thing to go. Now if I could just remember what was first to go…
nofearek9
nofearek9's picture
or 32mm Smile ?
http://intl-outdoor.com/noctigon-xp32-advanced-direct-thermal-path-coppe...
djozz
djozz's picture
nofearek9 wrote:
or 32mm Smile ? http://intl-outdoor.com/noctigon-xp32-advanced-direct-thermal-path-coppe...
That was indeed what I was hinting at Smile . The optic that fits that board is the Ledil Cute optic, which is 35mm diameter. It could be shaved to 32mm of course, but you will loose some beam quality and a bit of output.
comfychair
djozz wrote:
[...]but you will loose some beam quality and a bit of output.
I've not found any of that to be the case when cutting down the Carclo triples from 20mm to 17mm.
nofearek9
nofearek9's picture
djozz wrote:
nofearek9 wrote:
djozz wrote:
Suitable host for a 35mm triple optic? :)
That was indeed what I was hinting at :) . The optic that fits that board is the Ledil Cute optic, which is 35mm diameter. It could be shaved to 32mm of course, but you will loose some beam quality and a bit of output.
a nice host with this triple and a colored middle with custom firmware will be perfect.
Cereal_killer
RaceR86 wrote:
djozz wrote:
Solarstorm/Fandyfire SC02 (don’t have one but the size is right). It has an electronic switch so it needs a suitable driver.
Just look at it.
Do you have the driver measurements?
RaceR86
RaceR86's picture
I have not taken the light apart yet. Not planning to tear it down before Im doing a mod.
It might be similar to SC01. If so its 15,5mm and with an electronic switch mounted to it. Maybe someone else can confirm.
ohaya
Hi,
sinner has a thread about a new host that he’s making and might offer, and I’ve posted over there about possibility of using his host with the quad setup:
http://budgetlightforum.com/node/31907
ohaya
I think that a Small Sun ZY-T29 might work. This pic is just with the Carclo quad optic in the light (not modded yet) to see the fit:
The optic is just about the same diameter as the opening, so probably would need to have a spacer to extend the pill forward.
Also, the ZY-T29 is a side switcher with an electronic switch, so I’m not sure about a driver replace to drive 4 emitters.
comfychair
ohaya wrote:
Also, the ZY-T29 is a side switcher with an electronic switch, so I'm not sure about a driver replace to drive 4 emitters.
Anything with an attiny13 MCU can be flashed with momentary firmware. The BLF-17/20/22s will do 8.5-9A from a single 20R/25R/VTC5 into 3 parallel XPG2s, with 4 LEDs I'd guess that would go up to 10-11A.
17DD in a UF-T50 (momentary side switch):
http://75.65.123.78/PH-08/Dsc07748.jpg
Switch wires go to pin #2 & ground.
ohaya
For the record, a Romisen RC-G2 works perfectly, size-wise:
Cereal_killer
By now many of you have probably seen my quad RGBW A6’s
Notice all the extra wiring? Think wiring one of these for series is a lot? Try wiring them individually addressable.
Has anyone found any other suitable clicky switch hosts for these? What I don’t want is empty space around the optic.
Also I’m using a 35mm cute in both my new EA41 builds (one the production version of pukelight, the other a white only (using a boosted factory driver) triple I’ll be calling the EA41_ck.
Note all of these lights (plus the quad SC02_MELD’s I’m doing) all require custom spacers, the optics are shorter (some by quite a bit) than the factory reflectors*
*i was able to shorten the A6’s instead of building a spacer/new pill.
Ohaya how’s the fit height wise?
Serifus
Last seen: 9 months 2 weeks ago
Can anyone tell me the height of the quadoptic + the mpcb is?
