Review: Eagle Eye X6 (1x XM-L2, 1x 18650)
147 posts / 0 new
unknown00101
Eagle Eye X6
Reviewer's Overall Rating:  ★★★½
Summary:
Battery: 1x 18650
Switch: Reverse Tailcap Clicky
Modes: 5: High, Medium, Low, Strobe, SOS
Memory: Yes (Off, ~3seconds)
LED Type: 1 x XM-L2  3C (Neutral) , Also available in 1A (Cool White)
Lens: Glass
Reflector: Aluminum (Smooth)
Tailstands: No
Price: $18.89 Shipped
Provided by: Banggood
Pros:
Very comfortable to hold for long periods of time, which you will be doing if you have this flashlight. Smile
Machining is superb
  • Smooth edges
  • no 'play' in any threaded connections
  • knurling provides grip, but not overly aggressive
Annodization is flawless
Flawless reflector
Perfect, square, lubed threads
No visible/audible PWM
Surprisingly small, makes for a easily pocket-able thrower.
Great thermal management
Serious mod potential
Price
Cons:
Bezel is slightly darker than the rest of the light.
5 Mode driver
Tailcap boot sticks up a bit too far and prevents tailstanding.
Battery tube has very small ridges on the inside and wide protected cells (KP/Generic wrap NCR18650B) tend to catch every now and then and need to be twisted slightly to slide down the rest of the way (No damage to cells or wrap after several battery swaps, it is just a bit annoying).
A bit under-driven.
Function/UI:
Tailcap current (Amps):
High  Medium  Low
 2.231.52.25
(Protected & Unprotected NCR18650B 3400mAh)
14300 cd @ 30sec
Standard reverse tailcap clicky switch operation.
Click on. Half press for mode change. H-M-L-Strobe-SOS
Strobe is a fairly slow strobe.
Pictures:
The light arrived in the standard bubble mailer, crushed white box, and bubble wrapped flashlight inside. Got here without a scratch. Smile
It came with a replacement GITD tailcap boot, 2 O-rings, a decent lanyard, and an extremely sturdy clip. Fairly uncommon for a light in this price range.
Here's a 360 view. I'm not a clip guy, but this is a very nice clip. The fact that it is still on for the pictures is saying something. Smile
Some close ups of the fine machining.
Mini Breakdown:
Here are those beautifully lubed, square threads.
Perfectly centered XM-L2 Emitter. It's tough to see, but the glass lens is actually a bit dirty on the inside. It did wipe off easily after disassembly though.
Back of the head.
Bezel threads. Triangle cut, plentiful, lubed, O-ring seats beautifully.
Note: One BLF user received this flashlight that had heavily glued bezel threads. Several BLF members and I have received Eagle Eye X6 flashlights with zero glue in the bezel threads.
Back of the reflector. Fits right down around the XM substrate, and away from the solder joints.
The XM-L2 emitter on a 20mm star is secured with some screws.
Size Comparison:
Left to Right: Sk68 - Convoy S2+ - Eagle Eye X6 - Solarforce L2 - Convoy C8
The knurling is a bit more 'grippy' than the S2+, a bit less aggressive than my L2's knurling. A bit more Matte than the L2.
Beamshots:
As with all my beamshots, all pictures are taken in manual mode at the same settings.
The distance is 50yards to the center tree with the majority of the trunk showing.
Eagle Eye X6 : High - Medium - Low
I wanted to show a wide range of XM-L/XM-L2 lights. All lights are on their Highest mode. All stock except the noted P60.
I pulled the 3 closest to the Eagle Eye X6. The Convoy (OP Reflector) is slightly brighter with a bit more throw which is consistent with the measured 19kcd and 2.8A drive. The Tangsfire (SMO Reflector) has a much more focused beam measured at 26kcd and 3.4A.
Conclusion:
Simply put, the Eagle Eye X6 is a great light.
It is definitely among the elite few in the less than $20 flashlights that have this level of build quality. The only significant issue I have with this flashlight is the drive current. I would like to see at least 3A drive in a light like this, but it should be able to handle 3.5-4A.
Taking that into consideration and the minor cons of this flashlight like the small ridges inside the battery tube, no tailstanding, color mismatch, and 5 mode driver, I rate the Eagle Eye X6 a 4.5 out of 5.
As far as modding is concerned, I plan on very simply swapping out the driver and reflowing the XM-L2 to a copper star. The result will probably replace my Convoy C8.
Edited by: unknown00101 on 07/08/2014 - 19:29
unknown00101
I’ve updated the OP with beamshots and data.
As always feel free to ask any questions here or in a PM. Smile
MRsDNF
MRsDNF's picture
Last seen: 1 day 8 hours ago
Thanks unknown00101. Looks like a half decent light for the price.
mhanlen
mhanlen's picture
Last seen: 1 year 1 month ago
Looks great. How’s mode memory on the driver? Next mode memory? Do you have any idea of the driver size for any of us “mod lites”?
RaceR86
RaceR86's picture
Last seen: 6 years 11 months ago
Thanks for the review. Nice to see that all of these are not glued.
I have not bought one... When is the Group buy? Big Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
sesgum
sesgum's picture
Last seen: 2 weeks 2 days ago
Thanks for the nice review. The smaller size than c8 is attractive.
kronological
kronological's picture
Last seen: 5 years 1 month ago
Thanks for the concise review. I was able to read it without committing the entire morning :bigsmile:
For under $19, this looks to be a heck of a bargain!
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
bikenber73
bikenber73's picture
Last seen: 7 months 2 weeks ago
I have this light as well and have been impressed by it. I have the F35 also and am even more impressed by that light. The blinky modes are a little annoying on the X6 but it has reliable mode memory so I'm OK with it.
DB Custom
DB Custom's picture
Last seen: 7 hours 56 min ago
I too just got the X6 and really love it. The design is exceptionally pleasing, very easy in the hand. And the clip impresses me as well, mine is also still on the light…one of only 3 that rate that.
I removed the R200 sense resistors and tried it bypassed. The small twin FET’s drove it at 5.5A from a slightly used Efest 35A. BUT, I lost the lower modes…it had 3 highs and the blinkies. So I put 2 R10 sense resistors in and it now does 4.45A from the same cell, very nice. Also put a 16mm Noctigon with XM-L2 U2 2C in using Arctic Alumina Thermal Adhesive. With a piece of Kapton cut from a battery pull I’m guaranteed there won’t be a short with this smaller star.
All in all, regardless of price, this is a very nice light and ranks high in my favorites right off the top.
A side note…got an Eagle Tac TX25C2 a week or so ago. Also a very nice light and I like it. Coming home from a week vacation where I used the ET quite a bit I found this X6 had come in. In the first day, with the above mods, I am wondering why I spent the chunk of change it took to get the ET. I’ll probably use the X6 more. Just sayin…
Thanks for sharing the review, appreciate it. FWIW, no glue on mine whatsoever.
And it’s worth mentioning that the reflector is aluminum, exquisitely finished, with a lip around the top edge that holds a very robust red O-ring that presses against the lens directly. Nice touch. The brass driver retaining ring is thick and way overkill, also a nice touch to pull heat away from the driver. Brass retaining ring in the tailcap as well. Big spring on the driver, thick diameter wire and again, nice touch. This light had some serious thought put into it and it shows everywhere. The driver compartment is, I think, for a 17mm driver, they angle cut into the area of the shelf such that every possible bit of mass was retained in the head. Thick star shelf as well. Smooth, no recess or dimple. All the little details are there and I for one greatly appreciate it.
Solar
Last seen: 10 months 3 weeks ago
For 19 bucks this looks like a good host for a MT-G2 build. How long did it take to get the light from Banggood to your neck of the woods?
kronological
GB requested from Neal at BG. We’ll see what he comes up with.
My Reviews: Ma
unknown00101
Mode memory is in off time (there’s probably a better word for this that I can’t think of)
So whatever mode it is turned off in is the mode it will turn on in as long as approximately 3 seconds pass. I will check on the driver measurements.
unknown00101
Packages from BG typically arrive here (Central US) in about 17 days (weekend/holidays included), about 30 days for Li-ion packages. I’ll double check my spreadsheets to confirm. Doubled checked and edited.
harry218
harry218's picture
Last seen: 2 years 6 months ago
Thanks for the nice review. Wow, great light and look at that clip and lanyard too. They look high quality for such a low price. Does this light accept 17mm driver? I plan to get a moonlight mode using qlite.
That is awesome if they can do that.
unknown00101
unknown00101 wrote:
mhanlen wrote:
Looks great. How's mode memory on the driver? Next mode memory? Do you have any idea of the driver size for any of us "mod lites"?
Mode memory is in off time (there's probably a better word for this that I can't think of) So whatever mode it is turned off in is the mode it will turn on in as long as approximately 3 seconds pass. I will check on the driver measurements.
kronological wrote:
GB requested from Neal at BG. We'll see what he comes up with.
The stock driver is 16.86mm (measured on the rough tabs, widest part). The ledge the stock driver sits on is 18.12mm at the widest and 16.09mm at the thinnest, so a qlite driver with it's components on both sides will sit flush on the ledge with good contact; however, the spring side would need modification in order to utilize the 21.38mm x 13.00mm x 3.99mm brass retaining ring (Outer Diameter x Inner Diameter x Thickness).
Or one of these little numbers can be used with some extra chips stacked.
The driver cavity is approximately 8.2mm deep. The shelf the star sits on is about 3mm thick (it has been machined down flat for the star to sit on), and unmachined area surrounding the star is 5.4mm thick.
The lens is some very nice glass 2mm thick with a nicely finished edge. As noted above the reflector does have a lip around the diameter of the reflector that allows the thick O-ring to sit against and the glass to sit upon the O-ring. It is indeed a truly well thought out design.
harry218
harry218's picture
Thanks unknown00101 for the info. I might get one too.
DB Custom
DB Custom's picture
With the resistors replaced, I’m getting 4.51A and 1370 OTF start lumens. Thats a simple change of the 2 R180 sense resistors to 2 R10, and an XM-L2 U2 2C on a Noctigon.
Cereal_killer
Cereal_killer's picture
Last seen: 3 years 1 month ago
I love mine, I’m waiting on my XML color sinkpad’s to get here, I’ll be putting an XML color and a custom RGBW driver in my first one but I’ll definitely be watching for a GB, for the right price I’ll pick up one for sure, maybe more.
freeme
freeme's picture
Last seen: 15 hours 28 min ago
If I want to drive it at 3~3.5A range, will 2x R100 do the job? Do I replace the R180 resistors or just stack over them? Sorry, I have yet to try resistor mod before.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
DB Custom
DB Custom's picture
Stacking an R500 on one and trying it should be pretty close. I don’t know how this driver reacts to only one stacked resistor. If it acts funny you might try stacking 2 of an R500 (one on each R180) or closest you can find. I think if you come in higher than your’e looking for you could limit overall output by cell selection. Using something like a Panasonic 3400mAh cell would give good run time and not allow the major current, so it’d be a good choice to control top end output while keeping run time high.
Wight or Richard could probably elaborate more on this than I can.
Use an online parallel resistor calculator to get close then see what you can find that matches up. Take it from there.
Banggood
Banggood's picture
Last seen: 52 min 52 sec ago
Hi guys,
what will be the best driver for this light, and anything others need to change?
9% discount for all flashlight & Lasers
coupon code: 4BLF
Warehouse:CN
Link: https://www.banggood.com/Wholesale-Flashlight-c-1057.html?
Business inquiry
E-mail: chendongling@banggood.com
Skype: swiling88
After Sales Problems:
E-mail: cservice@banggood.com
Muto
Last seen: 6 hours 18 min ago
I really do not want to do the flame thing, but may have to try.
Put it in a vise with wood on the sides and a rubber strap wrench and it did not budge.
I really like the light as is, but would like a little more punch, so I hope to get it apart with out damage.
Really like the flashlight as is, great for the money.
later,
Keith
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
DB Custom
DB Custom's picture
Banggood, this is a sweet light with an excellent build. If you were to put a driver in it that gave 3.5-4A with no blinkies and a moon mode you’d have it just about right. The vast majority of users do not use strobe or SOS, it might be nice for them to be there but hidden so they wouldn’t have to be scrolled through on the way to off.
A very low moon in the 2% range, then 15, 30 and 100% would be very nice. If it’d came that way I wouldn’t have changed a thing.
I’ve only had the light in my possession a few days, but I liked it from the beginning and it grows on me more every day.
Thanks for a job well done.
freeme
freeme's picture
Send a DO NOT Glue request to your supplier. Save them money on the glue and serious effort of opening up from our side. Thank you.
Banggood wrote:
Hi guys,
DB Custom
DB Custom's picture
I just de-domed mine and it’s quite impressive! I have a welders lens for viewing solar eclipses. I used it to look at the emitter while on High at 4.5A, and with a scalpel I precut around the edge of the dome then applied light pressure lifting from the negative side until it released. Came off pretty clean and the tint looks nice. This is an U2 2C. Puts quite a lot of light at 100 yds, easily reaching out 200 yds and more.
Yes, the head was warming up pretty good at that power, but it didn’t get hot in the few minutes I was just using it…I’m thinking the fins are doing a good job dispersing that heat and the quality build contributes throughout.
Liking this light more all the time! Smile
Poor TX25C2 is gonna get left at home, there’s a new high power EDC in town. Wink
aoeu
aoeu's picture
I agree with DBC’s. Strobe and SOS is never used. I would have bought this if it didn’t have SOS. That’s the only thing I hate about it!
Banggood
Banggood's picture
aoeu wrote:
I agree with DBC's. Strobe and SOS is never used. I would have bought this if it didn't have SOS. That's the only thing I hate about it!
the manufacturer said 3 mode and 3A driver is OK, and the current of each mode can be made as us request, so what's the best current,
coupon code: 4BLF
Warehouse:CN
Business inquiry
Skype: swiling88
harry218
harry218's picture
Banggood wrote:
the manufacturer said 3 mode and 3A driver is OK, and the current of each mode can be made as us request, so what’s the best current,
Neil, can you ask them for 4 modes with moonlight modes too? moonlight-low-mid-high. I guess I’m happy enough with 3A driver or even 3 modes without that strobe.
Edit : exactly as DBCstm mentioned earlier “A very low moon in the 2% range, then 15, 30 and 100% would be very nice. If it’d came that way I wouldn’t have changed a thing.
Banggood
Banggood's picture
harry218 wrote:
Neil, can you ask them for 4 modes with moonlight modes too? moonlight-low-mid-high. I guess I'm happy enough with 3A driver or even 3 modes without that strobe.
OK
I'll ask him.
coupon code: 4BLF
Warehouse:CN
Business inquiry
Skype: swiling88
soddo
Last seen: 8 years 1 month ago
Nice review! Im looking for something in the $20-25 range however the beam looks
too similar to my c8 to justify
aoeu
aoeu's picture
Banggood wrote:
I’ll ask him.
Is anybody else impressed by this? What other product/manufacturer/retailer fields feedback from customers and makes direct changes? That’s awesome.
I don’t really know what current is best, I hope others can bring some input into this so we get a better all-round light. I’d buy it when the changes are made.
