Flashlight for my bike
152 posts / 0 new
biker
Last seen: 8 years 6 months ago
It is most important to me to see as much as possible. Be seen is also an aspect but not this important as I mostly ride off-raod.
So should I take R4 into consideration or not?
Pics comparing both emitters would be fine.
Will I see more with a natural instead of cold teint with 7% more lumens?
And what about the KD C8 compared to the 18650's 50B/504B?
The head seems quite large (t00 large?) for carrying in a pocket.
sweefu
Last seen: 5 years 3 weeks ago
While I think neutral tint is nicer, I dont use neutral lights on my bike.
When I'm on my bike, I want as much light as possible, and neutral tint takes away lumens.
I don't own a KD C8, but i have read great things about it...but it looks as if it would be too big for pocket carry.
It would probably make an awesome bike light though.
biker
After I've thought too hard about which flashlight to order I opted for 504B because of the seize. Non-18650s can't be pocket carried while giving the same light. Is there any alternative to the 504B with regard to light outpue an also to price, maybe with 2 18650?
biker
The flash light should fit at least into a bigger side pocket. I don't want to wear a holster even if such lights have a better throw. Are there any flashlights with 2x18650 and XP-G R5 or XM-L (why under-driven?)? Or isn't there such a big difference to 1x18650? Thanks for linking this XTAR deal. I'm already following this XTAR group buy.
E1320
E1320's picture
I just want to let you know the last couple people that bought the 504B had trouble fitting the Xtar batteries in them. I have 4 504Bs and I love them but I do not have any Xtar batteries I use the Trustfire flames or the Samsungs. I just want to save you the trouble of ordering this stuff  and waiting weeks only to find out they won't work together.
I am already visualizing the duct tape over your mouth.
biker
Thanks for your replies.
So the XTAR 18650 has some bigger diameter as standardized?
Where can I get the Trustfire flames and an Euro charger at a good price?
I have seen this Solarforce L2 before. But this flashlight also is only 1x18650.
Is the L2 better than the 504B regarding light output and build quality?
L2 has XP-G and 504B has XM-L. I think the XM-L is the better emitter.
But both flashlight are onlyy 1x18650. Are there any interesting 2x18650 models - which are better, but at the same time not so much more expensive?
E1320
E1320's picture
This are good 18650 batteries and charger I have both and recommend them they work good.
http://www.dealextreme.com/p/trustfire-tr-001-multi-purpose-lithium-batt...
http://www.dealextreme.com/p/trustfire-protected-18650-3-7v-true-2400mah...
I have this 504B light and it is really good quality it pulls over 3 amps on high with the batteries I recomended so 8oo lumens is about right.
http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-5-mode-510-lumen-wh...
PatrikL
Last seen: 9 years 3 months ago
I do not recommend to buy 504B from DX now Smile  I can compare two samples - one bought in march and one ordered about month ago. Older one fits all batteries well - XTAR 18700, blue trustfires, black trustfires... Is even brighter and came without any scratches. That new one is a bit junk - dropin and reflector is a bit different, some scratches on body, and it is impossible to fit almost all blue trustfire batteries (from 4 ONE fits), black trustfire battery fits tight Smile
It is showed here http://budgetlightforum.com/node/2984 and here is video with blue trustfires Smile http://vimeo.com/26288185
biker
Okay, so should I go for Solarforce L2 as bulid quality is better and consistent? Or any alternative? But no 2x 18650 flashlights?
The L2 comes "only" with a XP-G. But isn't the XM-L emitter the one which delivers more light?
So should I take into consideration to mod the L2 later? Is there a fitting XM-L emitter available?
janko.hrasko
janko.hrasko's picture
you could consider http://www.lightake.com/detail.do/sku.L2_Flashlight_Body_Tube_with_Exten... with http://www.kaidomain.com/ProductDetails.aspx?ProductId=11106 -mine was too cold, so I replaced the led with t4 (lots warmer and nicer)
colder tints are better for beeing seen but warmer (or neutral) leds make you see better
it isn't that much powerful, it draws ~2A from 18650 and ~1A from two 18650
and my hi-max cells fit without a problem (nie je to na picu ako tvoja, patrik Big Smile )
E1320
E1320's picture
The post you linked is a picture of Simplemans 504B he bought from Manafont not from DX and the over sized batteries he used XTAR18700s do not fit a lot of lights there is no problem with Simplmans light and he did not buy it from DX so I a not sure what your point is.
I would really like to see your picture of your 2 samples because my 4 504bs are all the same 2 from Manafont 2 from DX all purchased at different times over the last 6 months all identical all work with Trustfire 18650 flame batteries.
The DX drop in I got in May has changed it used to be limited to 1.4 amps on high the new one pulls over 3 amps on high so it is better than the old one I bought in January. So I stand by my recommendation and I would really like you to post some pictures if these alleged defects.
Please post pictures of your DX lights as mine are all identical four samples from 4 different dates 2 different suppliers all identical.
A lot of people on here have reported problems with Lightake including them spamming the sight repeatedly so i would avoid that site.
http://budgetlightforum.com/node/386
biker
L2 body with extension tube? Is this from Solarforce or at least a clone with a good build quality?
The XM-L emitter generally isn't that powerful? Or are you talking of the T4? Is the XP-G the one with more power?
Do I understand right that the only difference between 1x and 2x18650 flashlights is the run time? There is no difference in the light output?
504B still an alternative? But where to buy to avois a flop?
PatrikL
E1320 - I did not say that s1mp13m4n has that body from DX, but it has the same problem like newer 504B (1-mode) that I bought for my friend Smile I do not own that light right now, but I can write about it: newer one looks like they advertise http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-510-lumen-white-led... . Older one (ordered 19.3.) has smaller hole in reflector near LED, red PCB on drop-in and reflector look like "more textured" Laughing
janko.hrasko
the one from lightake is a clone (504B?) with a nice shiny finish Smile
xm-l is powerful, about 50% brighter than xp-g.. just that dropin with 18V max isn't driving it to the full potential, which is not bad (considering the heat sag in p60 dropins)
I can have my fake L2 short (~1+ hour of runtime) or long (~2+ hours of runtime) and it is the same brightness
janko.hrasko
oh and it is fairly waterproof Wink
I have neutral white xm-l t4 (bin) 5a3 (tint) from cutter
biker
But the XM-L driver with 18V max is still brighter than a XP-G?
So this is what Be-Seen Triker meant with under driven XM-L?
18V max is good for longer run time and also for longer last of the emitter beacuse of the reduced heat (btw how long will the XM-L last in this configuration?), right?
Well, 1 hour at max power shall be sufficient. How many modes does this XML T6 dropin have and what will be the run time in medium/ low mode?
Is there a clone body for 1x18650, also or should I directly take the original L2 body then?
And waterproof is a very useful feature for biking!;)
E1320
E1320's picture
Here are my 4 504Bs all excellent quality. I cannot tell them apart they are all identical. I bought 2 from DX and 2 from Manafont the newest one I bought was from DX in May with the 5 mode XML drop in it pulls 3.5 amps on high about 800 lumens with the Trustfire flames from DX. This would be a great combination for a biker.
I cannot guess what the problem was with Patricks sample but I can tell you mine are all  of excellent quality and I think it is safe to get one from Manafont or DX as long as you don't try and fit the Xtar batteries in them.
PatrikL
E1320 - so it is normal that Xtar batteries will not fit? Then the newest sample is not junk but OK and that older is "special" Laughing Here is video with XTAR 18700 2600mAh http://vimeo.com/26715338 (on right in "more" is older video with blue trustfires too...).
E1320
E1320's picture
A lower voltage XML should still be a little brighter than a harder driven XPG light. Here is a link that is helpful determining brightness.
http://flashlight-wiki.com/Brightness_Bins
You can calculate approximate runtime this way the Trustfire is rated at 2400mah that means at 2.4 amps draw on high it will run for an hour, at 1 amp draw on medium 2.4 hours or low .15 amp draw about 16 hours. These are approximate numbers battery makers mah numbers tend to be exaggerated and amp draw varies from light to light
Triker was referring to the high voltage drop in only delivering 1.5-2amps on high instead of 3 amps that most low voltage drop in deliver. The advantage of the high voltage drop ins are that you can use more batteries 2 or 3 to get more run time. I prefer the low voltage ones and I just carry a spare battery with me instead of in the light.
Patrik I don't know what is different about these new lights mine are all the same the only thing I can see different is the Xtar batteries are oversized. I don't know that they changed the lights mine are all identical and I have not seen any proof that they are delivering different versions of the 504b from Manafont or DX.I am sure there are cheaper versions of this light being delivered from different venders but I have not seen pictures or measurements that prove DX or Mananfont are delivering the cheaper ones.
biker
Thanks for your explanation.
How is high and low voltage defined?
The 504B comes with a low voltage drop-in, right?
I'm of the same opinion to carry a spare battery seperately. And a XM-L running with 1x18650 for about 2,5 hours @ medium should be sufficient for me.
Are L2 and 504B also waterproof like the L2 clone with extension tube?
What shall I do now? Order the 504B from DX or Manafont and hope that the flashlight will be delivered in good quality?
Or ordering the more expensive L2 directly from Solarforce Sales?
E1320
E1320's picture
This is what I have and use and would recommend for a starter kit. I really think you will be super happy with this setup. This is the cheapest way to get the most light.
http://www.dealextreme.com/p/universal-bicycle-mount-for-flashlights-and...
$45 dollars for everything you need to get started. You could add an extra pair of batteries for another $10 dollars or upgrade to the Solarforce for another $20 if you want but you won't get anymore light out of it.
High voltage is usually defined as over 4.2 volts which is what one lion battery delivers this would be a low voltage setup. This setup will be completely waterproof and of excellent quality.
Look really good at the picture of the lights I posted that is what DX is delivering right now so I think you will be happy with the quality I am very picky and very happy with the quality of this light especially for this price.
Here is a review of the 504B host.
http://budgetlightforum.com/node/2325
biker
Thanks for the list. I'm about to place the order for the complete kit. The 504B comes with a 5-mode drop-in. Is there also a 4-(no SOS) or 3-mode version of the drop-in with a on-while-pushing-mode available? Has DX the best prices for all parts or should I check in some other shops? Will DX send out all in one shipment or will the single parts be shipped seperately? I'm asking because of customs.
E1320
E1320's picture
DX has the best prices by far some times they do take a while to ship. DX does not offer anything except a 5 or 1 mode version of the XML drop in if you want a 3 mode you will have to order from Manafont. I can give you a parts list from Manafont if you want they do ship faster most of the time but you will pay a little more money. It is hard to say if it will all ship in one package usually DX labels the contents toys or electronics so customs usually doesn't mess with them. What country are you in?
biker
Thanks. I would prefer a 4-mode dropin with a one-while-pushing-only-mode. Is such a dropin available? So I would order the parts seprately. And the parts of Manafont are of the same quality than the ones of DX? At least your lately ordered 504Bs are, right? And one more thing: Can you recommend a pocket for the flashlight and a case for one or two batteries?
biker
But there is no dropin with a on-while-pushing-only-mode? Or is this a standard feature? If this is standard I will opt for the 5 mode and take the complete 504B from DX? The battery case looks very good. What about a good pocket the flashlight fits perfectly in?
biker
Has the 504B a forward clickie? It isn't mentioned in the detials. That would mean that I could turn on the light by pushing without click. I sometimes accompany a friend who is hunter and it would be definitely disturbing to have to click through all modes when light is required only very short. I have already seachered for a pocket. But who can advise if the pocket will fit adequately to the flashlight? I thought that there would be a favourite you guys are using.
E1320
E1320's picture
If you want a forward clickie you are going to have to get a solarforce they are the only ones I know of that have a bargain priced forward clickie.
This one is nice for $17
http://www.solarforce-sales.com/product_detail.php?id=216&s=42&t=FB
biker
Is the 504B is a reverse clickie? Reverse clickie is a no-go for me as you have to click through all modes until light is finally off. The L2T body looks really nice to me, thanks for the advise. So I will still have to order the parts seperately. Where is a XM-L 6T dropiin available at the lowest price and best quality, at DX or somewhere else? E1320, can you recommend a good pocket for the flashlight, now for the L2T body?
E1320
E1320's picture
The holster(pocket) I use I bought local the DX ones I can't vouch for. I don't have any Solarforce lights either so I can't vouch for those either but people on here love them. The 504Bs are reverse clickies most  budget lights are reverse clicky except for Solarforce.
This is the drop in to get 3 mode low medium and high no strobes or flashies to go with the solarforce.
http://www.manafont.com/product_info.php/ultrafire-cree-t6-3mode-memory-...
biker
Which holster do people on here love? Is this http://www.dealextreme.com/p/cree-xml-t6-5-mode-6700k-450-lumen-smooth-a... an option for 5-mode? Or is the dropin you posted better?
