Hi, what is the best affordable power supply i can get for this charger? i heard its getting more precise, and have less spikes during charging with better PSU.
I’m a battery addict/snob lol so i dont want my charger to harm my cells in ANY way, please recommend me some unit, thanks.
Most brick PSUs at around 10 amps. I think 12v, but check on that as Im not sure what voltage they are. You dont need the xbox PSU, its overkill big time, but will work fine if modded.
There are some tips on which one have been tried in that thread.
Sorry if this is a dumb question, but do I understand correctly that you can use a supply that puts out more than 3 A and it will not damage the charger?
I tried one like that, one that was rated at 5A. It did not solve the problem.
Using it in the car with a 12V output car adapter did fix the problem. However not just any 12V car adapter, one that is able to handle a lot of amps. The first one I tried blew the fuse internally. When I upped the rating on the fuse it melted.
Here are the instructions on how to convert different server power supplies for hobby use, it’s a very long thread! this is where I got the idea to make one.
You really shouldn’t be worrying about the charging data being inaccurate as charging data will never be a proper judge of capacity. The discharge capacity is accurate with the stock psu and that is what matters…
