A few new and uncommon super-budget 1xAA lights on eBay
82 posts / 0 new
sb56637
sb56637's picture
Last seen: 33 min 8 sec ago
Great, thanks for the review Don!  It looks rather nice for the price in my opinion, but if I were to review it using my criteria, I'd probably give it 4/5 stars for Features / Value, and obviously 5/5 to the DeLight.  Yes, it's a bit too long, and I don't know why they don't make more tailstandable lights.
Don
Don's picture
Last seen: 2 years 1 month ago
I think the tailcaps came out of the same factory - even if the lights didn't. I can imagine a factory in China churning out cheap switch and tailcap units to be used by whoever wants them. It is the threading that makes me think this. There is no reason for them to be the same otherwise.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Don
Don's picture
Current Draw:
All done using the same Eneloop for consitency
MDXL 205mA
BLF DeLight 406mA
Powerlight 155mA
Just checked and the DeLight/MDXL tailcaps also fit and work with the Powerlight. The Powerlight tailcap does not work with the MDXL though as the spring on it isn't long enough to reach the battery.
sb56637
sb56637's picture
Should have pretty good runtime, then.  I guess that's the secret to the Powerlight's great runtime-- low amperage.  For me the Powerlight's output is often more enough.  Did you ever compare the Powerlight's beam quality to, say, the AA-S1 or the R5-A3?  My two Powerlights have absolutely stellar beam quality.  Obviously brightness is incomparable, though.
Don
Don's picture
I thought the LED looked the same as the one in the Powerlight. So I fiddled around withe the camera to get a picture of the bond wires. This took about 3000 lumens shining into the reflectors (and back into my eyes) while I tried to get focus on the LEDs. The Powerlight is on the left, the MDXL on the right
hunt the bond wiresThe arrangement of the wires in the LEDs does look different so I imagine they were made in a different place, though they look very similar to the naked eye. I had to mess around a lot with contrast and so on to make the wires inside the LEDs visible at all.
Don
Don's picture
Will try that once it is a bit darker - though it's been a dim, grey and overcast day with plenty of rain all day. Official sunset is 8.5 hours away - currently 3:30pm here
sb56637
sb56637's picture
Just on a white wall mainly the Powerlight has a very pretty beam.
anduril
Last seen: 1 year 9 months ago
So, do I understand right? A $1,5 light is better than a $3,5 light even not taking the price into account?
Crazy...
Don
Don's picture
Depending on where you stand in runtime/brightness, the $4 Powerlight may be better than both.
sb56637
sb56637's picture
For me, the DeLight has better brightness, worse runtime, an uglier beam, and poorer quality.  The Powerlight has a much nicer beam, less brightness, much better runtime, and slightly better quality.  So basically you get what you pay for, and I like them both for the price.
anduril
Thanks for the to-the-point description. Brightness/runtime? Give me a lightsaber for 30 seconds Big Smile
So it seems choosing MXDL over the focusing one was a blunder, which I now have to fix ASAP Smile
fmmike
My MXDL arrived yesterday. My take on this light is pretty much the same as Don's. The E-Bay seller (go_market) was really responsive. Ordered the light on June 1, it shipped on June 2, I received it in New Mexico on June 7. I don't have to have a light that burns holes in things @ 10 feet but this one could be a little brighter.
Bottom line is a 5 for looks & a 3 for brightness.
Mike
Don
Don's picture
I dug out some AA lights and got the close up beams. Here are the lights:
lotsalights
MX Power ML-310, Powerlight, Ultrafire C3 stainless steel, Trustfire F22, MDXL, BLF DeLight, Tank007 E07.
Here are the beams at 2" from the beige wall - actually it's the side off a just retired server. 11 years it ran till the 4th PSU and a hard drive died. Best uptime was 3 years! Would have been more but for a power cut. Kept it on a UPS while we moved it whenI put in ethernet cabling a few years ago to keep the uptime.
The more powerful lights are stepped down to their lowest mode sothey didn't drown out the less powerful ones. All of them were fed freshly charged Eneloops for the purpose.
The beams
There is actually a huge hole in the centre of the beam from the MX Power at this range but it is too overexposed to show up. Notice how enormously wide the spill of the MDXL light is (3rd from right). The only thing even close is the Tank007 on the right. The Powerlight - second from left - has a nice beam though my personal favourite is the Trustfire F22 but then it cost about 5x as much. It has a lovely vanilla colour that doesn't show up here - the bluer lights here have shifted the colour balance.
Now at about 100mm (4") to lose the hole in the MX Power beam.
4 inches
The Tank007 beam is almost washing out the DeLight so I took out the brighter ones and left the Powerlight, the MDXL and the DeLight.
3 cheapies
The Powerlight has the tightest, and nicest beam of the three, the MDXL far and away the widest beam of anything I've got apart from a pure flood Zebralight headlamp.
Don
Don's picture
Done in a hurry as it was raining.
MDXL
MDXL
BLF cheapskates' DeLight
DeLight
Control
control shot
I'd have to wait 3 months for better quality darkness. I am north of Labrador in Canada and it is what passes for summer around here - the rain gets a little bit warmer. It reached a whole 11 degrees today (50F)
alfreddajero
alfreddajero's picture
Last seen: 2 years 2 months ago
I would love to have weather like that all year long.
With Darkness, there will always be Light.
FlexakaMal
Last seen: 12 years 1 month ago
Recieved today. A quick test about the same drightness as my powerlight  but draws less current in single cell mode at least.
printed on body Smallsun 5W.
fishinfool
fishinfool's picture
Last seen: 3 years 4 months ago
How do you check current draw?
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
FlexakaMal
set multimeter to 10a
current draw
fishinfool
Learned something new today.  Thank you sir!  Smile
FlexakaMal
I had to hunt around the net abit to find it first of myself. Wink
fishinfool
It took me a few minutes to figure out that I had to move the red lead from V to 10A.  lol
FlexakaMal
I guess you have checked the draw on every torch you own?? Smile
alfreddajero
Who has'nt lol.......
sb56637
sb56637's picture
Cool, that's a pretty nice looking light for the price.  How are the connections?  Any flickering?  Sections fit together fairly well?  How is the beam quality?  As Don and I have mentioned, the Powerlight has a suprisingly good beam by any standards, to say nothing of a $4.28 budget light.  It has a nice buttery color and a smooth beam with no shadows.  So the Powerlight beam is the one to beat.
sb56637
sb56637's picture
Thanks for those pictures Don!  If you ask me, the MXDL is not a flop by any means; that's an impressively large flood from a rather small light.  In fact it sounds like a useful tool for any budgeteer to keep on his shelf.
sb56637
sb56637's picture
Mike
Thanks for the update Mike!  That is is incredibly fast shipping, I wonder how he does it?  DealExtreme should be ashamed.  They can't even get the product from their suppliers within 5 days most of the time, to say nothing of the shipment.
What color is the beam of your light?  My BLF DeLights have a slight but noticeable bluish tinge.  My current and only MXDL light (good choice too, by the way) also has a bluish tinge.  But my Powerlights have a buttery or, as Don says, vanilla colored beam that is really impressive.
Don
Don's picture
Again, pretty good at 15 days from China.
First impressions. It has the same tailcap and switch as the DeLight, the MDXL, the Powerlight et al. Which means the extension tube ought to fit and work with all of these. Had a bit of fun legoing bits together and taking pics which will go up tonight. It really doesn't bear thinking about how long it'd take to upload them over the 3G modem I'm using just now. None of them seemed unhappy with 2.8V from two Eneloops.
Will try some white wall beamshots under the desk - the walls above it are far too brightly lit for beamshots.
sb56637
sb56637's picture
Don wrote:
C3 clone arrived today
Very nice!  Can't wait to see detailed comments from everyone on the C3 clone.
This thread epitomizes budget lighting at its best, in my opinion.  They used to buy spices from far away in the Orient.  Now we buy flashlights.   8)
Don
Don's picture
Cheaper too - famously, pepper in Scotland was worth considerably more than its weight in gold in the 17th and 18th centuries. With gold at $40 a gramme just now, a 40 gramme flashlight for under $5 has to be a much better deal.
First impressions - pictures to come. A bit brighter on 2AA than the Powerlight and a much warmer beam colour. This can and will vary from sample to sample. On a single AA (All NiMH as no fresh alkalines around just now) it is not as bright as the DeLight and is fractionally brighter, but a lot warmer coloured than my Powerlight that I have with me.
I think I am only waiting for two lights now. And two sets of fine pointed forceps. Must remember not to buy any more this month (well, we'll see if I can make it to the end of the week, let alone month.) Since the car needs a new cylinder head gasket and that is a $750 job, I'd better not buy any more till that's done and paid for.
Don
Don's picture
The Small Sun "5W" does not have interchangeable parts with a real C3. Just tried some C3 bodies and tailcaps with the clone extension and tailcap. They sorta, kinda fit but the thread pitch on the real C3 is much finer. However the extension works just fine on the Powerlight
Lego
And the BLF DeLight. That is one of the shorter, earlier DeLights with the tailcap from the Powerlight which works just fine. This is the one with the too short tailcap that works fine with the tailcap off the MDXL and the MDXL works just fine with the tailcap from this DeLight.
DeLight lego
Here's the original Small Sun with its extension tube. The finish on the extension is very different from the much glossier tailcap and body.
As it came
Here's the LED - yet another unknown. This one would undoubtedly vapourise if anything even close to 5W went through it - the one on the Powerlight has six bond wires, this appears to have only two and those are the limiting factors for current into the LED. Most white LEDs have a forward voltage in the 3.2-3.6V range. Even assuming the higher end of that range 5W = 3.6V x ?A.
Rearranging Power = current x voltage we get power/voltage = current or 5/3.6 = 1.39A. Asuming a perfectly efficient conversion from the 1.2ish volts of the cell to 3.6 that would imply 4.2A out of the cell.
Aye. Right!
LED
1.4A through those hair-fine wires just isn't happening.
The other end of the head isn't all that pretty. A rather poor blob of solder isn't as nice as a spring. It is probably more durable than the bent bit of wire in the MDXL though.
Inner head
The tailcap is the same as all the other ultra-budget lights. And appears to be interchangeable with all of them.
Inner tailcap
Single AA configuration
1 cell
2AA configuration
2AA
The beam is a nice colour on my one.
Beamshot
That's the Small Sun "5W", the Powerlight and the DeLight
Better exposed when I remembered to stop the flash from firing.
wallshot
Of those three, I like the beam colour of the C3 clone best. I like it a lot more than the MDXL. It is very well worth the extra 45 cents over the MDXL and allows all these ultra-budget lights to use 2AA if you want them to. I did rather worry the next patient into the office when he saw me crawling out from under my desk with camera in hand. But then I work in a psychiatric hospital and strange is what the customers are used to - just not usually from the staff....
Since I got carried away taking pics, here's my favourite Lego shot.
colourful lego
Measurements to follow - but at present, because of the versatility, I think this may actually be worth 4x as much as the DeLight. As you may have guessed, I like it.
