Gearbest New Arrival: March 22nd, Convoy H1 CREE 29.99$
546 posts / 0 new
gearbest
gearbest's picture
September 6th New Arrival:
1.Haikelite MT01 Waterproof Long Shots Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009983851378.html?wid=1433363
Main Features:
●Ultra clear double-sided AR coated toughened glass lens, the light transmission is up to 99pct
●Waterproof level up to IPX – 8, the flashlight can work normally even on heavy rain days
● The shot distance is up to 300 meters with the wide beam range
●Five brightness level: extremely low: 50lm; low: 250lm; mid: 850lm; high: 2500lm; strobe: 2500lm
● When the light is on, fast single click and long press to lock out the switch
● Multifunctional flashlight anti-reverse protection, anti-discharge protection, battery power detection function, low-voltage protection, temperature control protection
● The flashlight powered by 3 × 18650 / 18700 battery ( not included )
2.HKV A11 LED High Power Diving Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009157508212.html?wid=1433363
Main Features:
• Aviation aluminum alloy shell has excellent scratch resistance and corrosion resistance
• It can be used for 100 meters underwater
• 3 kinds of light can be adjusted underwater: white, blue and red
• Dual-lubricated O-rings provide dual safety for underwater use
• High performance integrated cooling surface on the base ensures low heat
• Scope of application: outdoor diving, hunting, patrolling, camping
• 4 × 18650 lithium-ion battery ( not included )
3.HaikeLite MT07S XHP70 II 5000lm Portable LED Flashlight – BLACK 6500K
https://www.gearbest.com/led-flashlights/pp_009671498460.html?wid=1433363
Main Features:
●Utilize a CREE XHP70.2 bead that can produce a blazing 5000lm illumination
●SMO aluminum reflector with double side AR coating glass lens for extreme reflector performance
●Lockout function: a single click followed by a long click to lockout the switch, repeat to unlock
● Digital full current regulation, anti-reverse protection, anti-discharge protection, thermal control remove / activation, last mode memory function
● Power indication light: 100 – 50pct: blue LED on; 50 – 9pct: blue LED flashes; below 9pct red LED flashes
●5 brightness levels: low ( 200lm ); mid I ( 550lm ); mid II ( 1300lm ); high ( 2300lm ); hidden turbo ( 5000lm )
●2 special mode: strobe ( 5000lm ); hidden moonlight ( 2lm )
4.HaikeLite MT07S – HI Portable CREE XHP35 HI LED Flashlight 7 Modes for Outdoor – BLACK COLD WHITE
https://www.gearbest.com/led-flashlights/pp_009791663221.html?wid=1433363
Main Features:
● 7 brightness levels: hidden turbo – high – medium II – medium I – low – hidden strobe – hidden moonlight
● Utilize a CREE XHP35 HI bead that can produce a blazing 3000LM illumination
● Waterproof IPX – 8, suitable for usage in rainy weather
● Powered by 4 × 18650 Li-ion battery ( not included )
5.HKV A28 Outdoor Portable LED Diving Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009662776193.html?wid=1433363
Main Features:
• Using high-quality CREE – XHP70 II chip, max output of 4000lm and beam distance of 500m
• High / medium / low / flash modes, suitable for using in different situations
• Power supply: 2 × 18650 ( not included ) / 2 × 26650 battery ( not included )
LED will give you stable and bright light, nonthermal radiation, safe and reliable
gearbest
gearbest's picture
September 11th New Arrival:
1.HKV A15 LED High Power Diving Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009789576955.html?wid=1433363
Main Features:
2.MT35Plus Super Bright Outdoor USB Charging Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009939052333.html?wid=1433363
Main Features:
• Aluminum alloy, practical and durable
•Key breath lamp design to detect the voltage and remaining power in time
30 percent above, green light is on, 10 to 30 percent, red light is on, 10 percent, red light is flicker.
PTZ hole design, can be used for fixed lighting
• Underwater 1m waterproof capacity, 1.5m anti-fall rating
• Four modes: moonlight file, medium bright file, high brightness file, very bright file
• Silicone button, widened and non-slip
• 2 × 18650 battery / 4 × 18650 battery ( not included )
3.WUBEN A21 Portable Super Bright LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009529056619.html?wid=1433363
Main Features:
●Aluminum body material
Using aluminum body material, it is non-slip, waterproof, and abrasion resistance.
● Side button switch design, easy to use
●Light modes
5 modes / strobe / stepless dimming design, so many brightness options are convenient for us.
●IP – X8 waterproof
● Powered by 1 × 21700 battery ( included )
● Light source: CREE XHP70 LED beads
gearbest
gearbest's picture
December 19th New Arrival:
HaikeLite MT03 Portable 21000lm High Power LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009427144440.html?wid=1433363
Main Features:
• Using high-quality XHP70.2 lamp bead chip, max output of 21000lm
• Side switch, easy to use
•Made of aluminum alloy, comfortable hand feeling
• Mid-size and lightweight, convenient to carry
• Power supply: 4 × 18650 battery ( not included )
•Widely application
It is suitable for camping, fishing, hunting, hiking, searching, working.
IPX – 8 waterproof
gearbest
gearbest's picture
March 22nd New Arrival:
Convoy H1 CREE XML2 Multifunctional Flashlight Head Light – Night Natural White 4200k
https://www.gearbest.com/headlights/pp_009436104860.html?wid=1433363
Main Features:
●Multifunctional light, can be a flashlight and can also be a headlamp ( with headlamp belt )
CREE XML2 lamp beads, can give you strong light at dark night
● Mini size for easy carrying
● Suitable for camping, hunting, caving, home use and other outdoor activities
● Material: aluminum alloy, double coated glass lens
● Color temperature: 4200K / 5000K / 6500K
● Powered by 1 × 18650 battery ( not included )
ichoderso
ichoderso's picture
is this offer for the second batch of H1 with changed UI??
