A decent single led with multiple batteries?
38 posts / 0 new
Woodfiend
Last seen: 4 years 10 months ago
I am trying to find a decent single led torch with 3 or maybe 4 18650 batteries. I would like to get as close to 1000 lumens as possible but have much longer runtime than the single cell ones. Any recommendations? Point me in the right direction.
musicmagic
Last seen: 7 years 4 months ago
If you can’t blind them with your brilliance, baffle them with your bullcrap.
The real currency in the world is not money, it’s trust.
wight
Last seen: 2 years 3 months ago
As I see it you can solve your problem one of two ways:
  • As musicmagic suggested, there are plenty of options already discussed ad nauseam on BLF. Search! Use terms highlighting the number of 18650’s and things like ‘single’ or ‘thrower’. You should find several threads like this one: Old-Lumens – Update – $29.95 from GB, on the Ultrafire 1226 – GOLD COLOR ONLY
  • … or just get over your desire for a single emitter. 3/4/5/6/7 emitter lights with 4×18650 have been even more heavily discussed on here. Whatever it is you’re trying to accomplish, the Supfire M6 probably does that and then some.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Woodfiend
Yeah I have been searching this forum and others but not finding decent results. I really like my Fenix TK41 but I wish it used 18650’s instead of AA’s. I have other lights like the SRK and TK70 and I think I am going to order the FF4. But I would really like to have a single emitter with multiple batteries so that I could use it for hours on end. I figured I would ask you guys to get good advice or direction.
wight
I forgot to say welcome! So welcome.
Anyway if you like that form factor consider a 2×26650 light maybe? The Yezl Y3 is popular. There are a bunch of 2×26650 lights with a single emitter if that’s the form factor you want.
Woodfiend
Thanks for the welcome wight! Although it is hard to top the one that musicmagic gave me (although at least he didn’t waste his 1000th post on me). :bigsmile: Yeah I am not opposed to the 26650’s since my Nitecore charger will charge them as well. I just have so many 18650’s……… I will check out the Y3. Thanks!
wight
The Y3 can take 18650’s with an adapter tube. It takes extensions too, I forget what the max voltage is. I’d say 3s or 4s is the most you should attempt (but not before you try and figure out some more official limit).
Woodfiend
Perfect!! I was just going to ask about extensions and adapter tubes. Thanks!
Woodfiend
I will probably buy it just to try it since the price isn’t bad. Do you know who carries the tube extensions?
B42
B42's picture
If you want 2×18650 with those specs: single emitter, 1,000 lumens, good thrower and long running, I’d get the LustFire K08 instead, a knockoff of the Convoy L2 I think it was? I got one for about $20 on sale, and I was completely surprised by the size, quality, and output of it. It is the first single emitter light thrower I have that I’m happy enough with that I really think I’m going to leave alone, and I thought I was buying it to put an MTG2 in. Somehow I lucked out though, mine is in the 3A driven range, while others are reporting a bit over 1A. The tint is nice for a CW, and it throws the farthest I’ve seen a budget light throw. It takes 18650 and 26650 just like the Y3.
The Yetzl Y3 is OK but I am underwhelmed by it in quality (loose lens, missing o-ring, knurling feel is good, but Lustefire somehow feels a lot better in the hand, Y3 feels cheaper and thinner). In output since its significantly less bright than the Lustfire, focus of the center spot is off and it doesnt throw as far. The loose lens, chipped adonizing, greenish NW turn me off of the Yetzl Y3 I have.
Another light in similar form I also really prefer over Y3 is my 2.8A Convoy L4 with $5 extender for 2×18650. I cant really compare brightness since mine is 7C and obviously going to be significantly less, but the quality is also great, feels good in the hand (not as good as Lustfire though), price is the same as Y3, and somehow looks as bright as the Y3 anyways (Y3 is probably not well driven). It does not take 26650, but no problem there with what looks to be your preference.
I have massively overpowering multi emitter lights, and the Lustfire and Convoy L4 still get rotated in and taken out on night walks, whereas my Yetzl I never used more than twice on a walk…its just kind of disappointing.
wight
Yezl Y3 could probably use a resistor mod. I think the usual suspects carry it. There have been two ‘group buy’ type things recently from different vendors, search and you’ll find them.
I haven’t really played around with the Y3 much. There are definitely some quality control issues though.
I don’t think that the LustFire K08 is still available? I see it on Amazon for nearly $100, I don’t count that as ‘available’ for a <$50 light.
allthumbs
Last seen: 5 years 10 months ago
B42
B42's picture
Ah, you have to look around the threads here, there are about 3 different named models, knockoffs of the Convoy L2, I forget the thread that had it but some are still around. It is more expensive, but around $45-50 when I looked, Yetzl is about $30+10 so $40 I think, and its much inferior in quality, I really wanted to like it, but was disappointed.
Where is the resistor mod thread though? Mine needs it, then maybe I’ll have a Yetzl green-yellow pea soup lazer Wink Its still noisy and not even water resistant though, I can’t believe they didn’t even fit the lens to the light before selling it…
Woodfiend
Hmmmmm…… yeah I like the look of the Lustfire but Amazon was the first seller I saw as well (and in the $100 range). A couple other places like Alibaba and Tmart had better prices but said discontinued.
B42
B42's picture
OK I found one, $45, different name, another clone of the Convoy L2, just like the Lustfire K08:
http://www.gearbest.com/led-flashlights/pp_73031.html
*EDIT OK now that ^ is out of stock?!? I’m sorry it is looking like all the clones are sold out, the Banggood Dipper clone is also sold out, so is the Wallbuys clone. Looks like there is a run on the Convoy L2 clones around…
Similar Lustfire at $31, smaller reflector head: http://www.aliexpress.com/item/free-shipping-LusteFire-D01-CREE-XM-L-T6-LED-1000Lm-Flashlight-Torch/827438284.html I don’t have this light (or clone) though. Look at this thread for D01 owners and deals: http://budgetlightforum.com/node/36676
If you like the look of the Convoy L4 its also much better quality control than the Yetzl Y3 or the Smallsun ZY-T08 ( have 2 of those too). Most Convoys have good quality standards. But, if you get a Smallsun ZY-T08 modified increased output and user interface by Richard of Mountain Electronics, its going to blow all these lights away… Smile
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 days 8 hours ago
http://www.banggood.com/Convoy-L5-CREE-XM-L2-T6-4C-2-Group-3-or-5-Mode-1000LM-LED-Flashlight-p-916742.html You also can get different tints if you look around BanguGood. Quality is really great too! Easy to mod.
KB1428 “Live Life WOT
Woodfiend
Can you use extension tubes on the convoy l5 as well?
wight
Personally I’m pretty sure I’d rather have a Supfire M6 than a Smallsun ZY-T08. RMM mods both.
B42 I think you got the short end of the stick with your Y3. As far as resistor modding, I’m sure I’ve posted about it in at least one or two places. Probably somewhere in this big thread: http://budgetlightforum.com/node/33066
… rather than attempting to find where I’ve explained it before, we’ll just go through it again:
  1. Find the sense resistors. The Y3 uses two resistors in parallel, a normal setup. In this case it’s R180 and R150. The R is a decimal point, those resistors are 0.18 ohm and 0.15 ohm respectively.
  2. Determine the total (net) sense resistance. Use an online parallel resistor calc to see what the total is. http://www.1728.org/resistrs.htm We can easily see that the total is about 0.08 ohms.
  3. Measure the output current (current to the LED). This should be around 3 amps with the stock driver and 2s or more.
  4. Determine the sense voltage: Punch current and resistance into an online ohms law calculator or just multiply the net resistance and the measured current together… 3 * 0.08 = 0.24v
    (Or skip those steps because we already know the sense voltage is in the 0.24v to 0.26v range due to it being a QX9920 buck controller. )
  5. Determine the new net resistance we need: Now we know sense voltage and we know your desired current (say 4.0 A), we clear our ohms law calculator and punch in the desired current along with the sense voltage… or we just divide the sense voltage by the desired current. I’m going to use 0.25v here because that’s about right: 0.25 / 4.0 = 0.0625 ohms
  6. Go back to your parallel resistor calculator and see what you need to put in parallel to achieve that resistance.
  7. Purchase and install whatever resistors you need.
B42
B42's picture
Tks wight. I think I lost interest in modding it after my Y3 showed up bedraggled and limping, then I had better lights arrive and I put it aside. Maybe I’ll try it soon with this simple info. I’ll need to buy a lens that actually fits before attempting to mod so I can actually use it in the prevalent rain though, the one they shipped it with is slightly smaller diameter and loose. Then I have to change out the emitter and driver for an MTG2 and get rid of the pea soup color…
Yes I’d rather have a M6 modded, I was just indicating a Smallsun ZY-T08 someone brought up doesnt have to be a bad selection if modded, M6 is just much further off the single emitter mark…
wight
You’re welcome. I’ll have to take a look at what I have at some point, I don’t think I had lens fitment issues.
Further off the single emitter mark, but closer to the 3-4 cells mark. Wink
B42
B42's picture
Well then if we are going there, I’ll go for a modded J12, J18, or J20 and 7,000++ lumens instead! Smile
As for the lens issue, yes, its so bad with so much motion it clinks while using it constantly. I call it my noisy pea soup light. CW lights make it look green and warm, the X6’s 3C NW beam color looks to be a nice 4C tint next to the Y3 (which looks white with green shift vs it), while the X6 NW is slightly white greenish vs my real 4C tint C8.
KawiBoy1428
I have (2) Y3’s modded with the MT-G2. I’m running RMM’s 17mm QLite Zener Mod on one for 6.2amps measured at the tail cap, made my own adapter 17mm to 23mm, put the MCPCB on 2mm copper ,with a 120 second Turbo and man it gets HOT! HOT!!!! But do able!! Now the other is built the same way “EXCEPT” with RMM’s 22MMFETDD/ZENERMOD, it needs a 60 second Turbo or even 30 second Turbo, whoa this thing is BLAZING SCARY HOT at 120 seconds!!!! Just saying…..
wight
@KawiBoy1428 – how was your lens fitment? how was your stock tint & alignment?
Woodfiend
The SunZ seems kind of underpowered and a bit homely.
KawiBoy1428
Both were loose at first, I used .032” solder and made a ring out of it and put it between the bezel ring and glass, and slowly tightened and loosen till flat, worked out well. Then I found some 2mm black oring’s to replace the GITD ones. I have used in the past and it’s still on my SRK the wax paper card board that’s on the bottom of Hostess Sno Ball’s, I traced the O.D. and cut it out, screwed the bezel on and cut the I.D. out using a razor knife and the inside of the ring as a guide. Still there and seals well too? Hard to find the SRK o-ring’s at 2.5mm cause 3mm wouldn’t let the bezel ring screw down?
KawiBoy1428
Stock tint was greenish, alignment meh big plastic piece that covered the MCPCB board and tried to center the over sized emitter hole, so not that well, I’m mean you could knock it around a bit, but it wasn’t repeatable if you kept loosening the head?
Ronin42
Ronin42's picture
Last seen: 2 years 8 months ago
I have been looking for 3×18650 3S also because I think that to drive a MT-G2 well one needs the extra voltage. As such I just learned that the Courui D01 is 3P and so was dropped from my list but as it is 3P runtime should be quite good.
as a starting point
$25
http://www.dealsmachine.com/best_193759.html
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
KawiBoy1428
For the money Convoy’s are hard to beat! Great quality!!! And YES Mr.Woodfiend you can use the extension!
wight
Ronin42 wrote:
I have been looking for 3×18650 3S also because I think that to drive a MT-G2 well one needs the extra voltage. As such I just learned that the Courui D01 is 3P and so was dropped from my list but as it is 3P runtime should be quite good. as a starting point $25 http://www.dealsmachine.com/best_193759.html
IIRC dealsmachine is being tricky by not having free shipping.
B42
B42's picture
Yeah I don’t prefer them either, just agreeing that if you liked them, Richard could mod them to be nice output.
BIGBLOCKMOPAR
BIGBLOCKMOPAR's picture
Last seen: 1 year 4 months ago
Supbeam/Acebeam K50 or Olight SR51/SR52.
