Show us your beam shots - XHP70, XHP50, MT-G2 - for comparison
86 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 5 years 9 months ago
Ok, so we have members doing builds for the new four die leds, the XHP70 and XHP50. How do they compare to MT-G2?
Let's see some good comparison beam shots and the elusive white wall captures.
We need to see how these leds stack up as far as beam profiles.
Tell us what reflectors or optics you are using and what you did to get a good beam, if you got one without the MT-G2 dark spots or the four die X of death.
How about it?
Edit:
I have the XHP70 6V stars now and the leds should arrive next week. Hopefully, I will have a light ready within two weeks from today (02/06/15). It will be a multilpe XHP70 light, so who knows how that will look.
I will be doing a couple of LED "2D" Maglite mods, one with MT-G2 and one with XHP70, both at 9120mA. That will be some time in March, but no other single led mods coming soon. The rest are multiples.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 02/06/2015 - 11:38
MRsDNF
MRsDNF's picture
I tried to get pictures of what I'd call a shadow in the center of the hot spot but failed miserably so I'll try and explain them.
The 35mm reflector from Cutter with the XHP70 led has a large shadow in the center of the hot spot which I could not tune out. Overall it had a large hot spot,large shadow in the middle with a large flood of light around the hot spot.
The DST was the first light I tried with the XHP70 and it took along time to tune the reflector to get the smallest shadow in the middle without losing the intense hot spot. I've lost a little on the light meter out the front but come to a reasonable compromise. Compared to the smaller reflector I'm not complaining about the shadow. Keep in mind its not perfect.
I tried lots of different reflectors by holding them against the XPH70 led in the DST from P60, C8. the reflector used in Maglites and HD2010 and was not really happy with any of them though this was a pretty rough way of doing things.
A picture of the Cutter reflector.
Left to right. The Cutter reflector was fitted into a much modified F13 XHP70 2.7A, HD2010 MTG-2 2.7A, DST MTG2 3.7A and DST XHP70 3.7A. All currents at the led.
XHP70 35mm Ref 2.7A
MTG-2 HD2010 2.7A
MTG-2 DST 3.7A
XHP70 DST 3.7A
Chicken Drumstick
Last seen: 52 min 31 sec ago
Subscribed.
djozz
djozz's picture
Last seen: 8 hours 10 min ago
Thanks for these useful comparisons! So those last two are direct comparisons of the XHP70 and MTG2 ? Nice! The XHP70 seems brighter and the throw looks about the same, right?
JamesB
Looking at the leaves just vertical of the road and the trees on the left i’d say the XHP70 as at least twice the cd of the MTG2.
grantman321
grantman321's picture
Last seen: 4 years 8 months ago
subscribed. very impressive.
“We are all worms, but I believe that I am a glow-worm.” – Winston Churchill
dangerous
dangerous's picture
Last seen: 7 years 7 months ago
Damn, throw and lumens both seem improved on the XHP70 over the MTG2.
BLF
Old-Lumens
Mouseover of the last two photos that MRsDNF put up.
MT-G2 mouse OUT and XHP70 mouse OVER
1
Thank you Steve, for putting up photos for us. Hopefully others will post some when their builds are done. The more we get to see of them, the more we can learn. It's a no brainer that, at the same amperage, in the same reflector, a XHP70 should be brighter than a MT-G2. It does, after all, put out more lumens than the MT-G2. My concern is the black cross in the hot spot, which, for the most part, you will only see on a white wall test, but not see as much in the field, where the beam is already broken up with shadows, from the subject matter.
nickzom
nickzom's picture
Last seen: 2 months 2 days ago
so if i were to build a light with a xhp 70, could i use the same driver as a 6 volt mt-g2? namely the zener mod 22 mm fet from mountain electronics?
Old-Lumens
Yes.
nickzom
nickzom's picture
i wonder what it would be like in my Z1… i wish i had a source for just the brass pill out of the z1. i would build a few different set ups for it.
Rufusbduck
Rufusbduck's picture
As OL said, yup, and you can also use a Zener mod driver for the xhp 50 on XM mcpcb’s for a tighter beam or where you want to use a reflector/optic with a smaller opening. Good thread, I have 50 on the way I can compare to an mtg in the same Fastech 35mm reflector.
Scott
downlinx
downlinx's picture
subbed and will update soon.
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
Cereal_killer
Cereal_killer's picture
Last seen: 2 years 9 months ago
It would be horrible, throw would be not good (for the amount of power) and there would be dark lines in the projected image cause of the multi-die emitter.
nickzom
nickzom's picture
i know it would be like that, but what about partially zoomed? and i know exactly what you mean about the lines
MRsDNF
MRsDNF's picture
Part 2 with a lot of help from an army of willing assistants of which a couple deserve an honorable mention. Lucy and Jack. I just wish they could use Photoshop quicker and more adeptly than I can.
Applause for the two main assistants as they really pushed me to my limit like I was a dog.
All pictures with mouse overs will have the MTG-2 mouse out with the XHP70 as the mouse over.
Firstly will be zoomed out and secondly zoomed in. The zoomed out and zoomed in appear to be of a different brightness . I can only assume its because they are a new picture and not a crop of the original. Almost forgot. The white bucket is the 150M mark.
F13 XML2 dedomed over 3 amps at the led.
F13 Cutter 35mm reflector XHP70 3 amps.
DST MTG and XHP at 3.7 amps.
HD2010 MTG-2 2.7 amps.
TN35 and Monster Light.
Zoomed in pictures at the same distance.
HD2010 MTG-2 at 2.7 amps.
Now for some long shots though I would not call either of the DST throwers. Keep in mind the shed is reflective and at a distance of 520 meters.
TN35 and Monster Light. for some reason I have lost the pictures. Cry Sorry.
And finally my favorite light the C83.
The DST MTG-2 lives 99% of its life as a lantern so a comparison was deemed necessary. Both lights have a 1/4 unc thread in the tailcap for this purpose. When the pictures were taken the same cup was used on both lights.
Low.
Medium.
High.
To sum up. The F13 XHP looks useless. In all honesty it does have a shadow in the center of the beam which can be annoying. Would I recommend this reflector, no but at the end of the weekend it was the most used light away from camp. It lights everything up within 75 yards with a wall of a really nice tint light. What did surprise me is how much the light heated up on medium as this is what is was mostly used on.
The DST also has a very slight shadow but this is not noticeable as a rule unless your white walling which I try and not do. If anyone can pick the shadow in these pictures they are doing a better job than I. No comments please.Tongue Out
I have plans to downgrade the 9 amp driver in the Monster light sometime to a 6.6 amp Taskled. Maybe I will just try the XPH70 in this light? Did I mention I love the tint? Smile
And what could be better than my other favorite light that no one owns lighting up the sky after a night taking pictures in the bush. Lets hope its batteries dont run out soon.
blueb8llz
Last seen: 6 hours 41 min ago
I was actually most impressed when used in lantern form. That’s waaay cool how it jus ligjts up your entire campsite. Even low is impressive. What cups are you using?
Have you found any creamish color cups for a more neutral tint?
MRsDNF
MRsDNF's picture
I did mean to take a picture using a blue cup but forgot. Must of been the full moon. The tint from the plastic cup is ok. They have been in this bush place for over 21 years and it occurred to me one day that they may make a good diffuser. They haven't been drunk from since. These also work well with the TN35. Not what the manufacturer had in mind when they designed it one would assume. It beats having the sound of the generator in the back ground using these as a light source and music is supplied via the car.
billoz
billoz's picture
Great pics and comparisons MRsDNF. Has that TN35 been modded ?
Rufusbduck
Very clever use of the lamp base and a ood argument for side switches.
Scott
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 22 hours ago
Nice pics MRsDNF. It looks to me like the xph70 has ‘more lumens’ and only produces more throw because of the ‘more lumens’ (if that makes sense).
djozz
djozz's picture
Great beamshots! How come your daughter (I guess) stays so calm while her head is being evaporated by the XHP70-DST? Laughing
MRsDNF
MRsDNF's picture
The TN35 is stock. There is night shots of it at the longer range in another thread. The XPH70 in the DST is about 18% up on the MTG-2. Lucky my daughter is not in a close up as you'd think she was pretty old. Laughing
DBSAR
DBSAR's picture
Last seen: 1 week 4 days ago
nice shots!
djozz
djozz's picture
I once made the mistake to refer to the woman who came towards us (I got a 300km lift from a very nice gentleman in a BMW) as his mother. She appeared to be his wife. Since then I try to be on the safe side Wink
Hestbech
Hestbech's picture
Last seen: 1 year 3 months ago
look at the bright side. You didn’t refer to her as his dad Silly
It would be dandy if birds pooped candy ::
MRsDNF
MRsDNF's picture
Just a bump as there must be a few others out there who have shots of this led along with their thoughts on the reflectors used..
pilotdog68
pilotdog68's picture
I tried an XHP50 in an OP P60 module. The dark spot in the middle wasn’t terrible, but the whole thing was too floody for my taste and it got too hot too fast (even with all the P60 heatsinking tricks). I disassembled it and am working on moving the ’50 to a light with a larger reflector and better heatsinking. Sorry, no beamshots of the P60, but hopefully I’ll get some of the new build.
Ricflair
Ricflair's picture
WOW. Just plain WOW. Love those pics.
If you have a Saltytri you want to unload, hit me up. If you don’t know what that is, google it.
djozz
djozz's picture
For what it is worth in this thread: I made a S8 (my favorite Convoy host now Smile ) with a XHP50 (with a 17DD with zener mod), and the beam is acceptable but not that great. I put an extra spacer between reflector and led to make the led sit deeper below the reflector. Next tweak will be the other way around: bring the led further into the reflector than normal. I think in the end it will be a pretty ok beam, but very floody of course.
White wall @ 5m with flashlight on low, and underexposed to show the brightness drop in the center.
The tree is at 25 meter.
The output was close to 2000 lumen at first but it dropped to about 1000 now, I think I crushed one of the (18350 IMR) batteries, it is bend inwards at the underside Sad
seben
seben's picture
Last seen: 4 years 3 weeks ago
Subbed – still waiting on parts for my XHP70 lights…
