Looking for multi-cell flashlights that use a battery carrier and can take flat-top 18650 batteries
10 posts / 0 new
xlotus
Last seen: 4 years 9 months ago
I am looking to buy a few multi-cell flashlights that use a battery carrier and can take flat-top 18650 batteries.
Prefer to get a flooder than a thrower.
If the price is not too high, I plan to buy a few.
I currently own an Acebeam K40M and I really like it.
Since I have plenty flat-top batteries, that’s all that I use on the K40M.
Something like K40M but cheaper would be great.
Thanks in advance for information.
Too many flashlights!!!
Morocho
Last seen: 12 months 4 days ago
There are a number of flashlights such as the Skyray that use up to three our four 18650 batteries and multiple LEDs. If there are seven LEDs, for example, each one will have a relatively small reflector, so you will get a pretty wide flood.
xlotus
I have a complete set of SKR from the 3x to the 9x.
They don’t use a battery carrier and they don’t take flat-top batteries either.
What I am looking for is a multi-cell flashlight that uses a battery carrier and can take flat-top batteries.
A good example is Acebeam K40M.
http://www.acebeam.com/content/images/uploaded/K40M-15.jpg
Do you see the battery carrier in the picture? That’s the kind of flashlight that I want.
The design of the battery carrier allows the use of flat-top 18650 batteries.
This is an example of a flat top battery:
http://cdn.shopify.com/s/files/1/0367/9953/products/samsung-inr-18650-ba...
The top is flush with the rim so there is no protruding part of the positive terminal.
Ronin42
Ronin42's picture
Last seen: 2 years 1 month ago
Check out the Jm30.not as floody as the mm15 but more then most others. I just think it is a cool modable light!!!
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
Ronin42
Ronin42's picture
oh and start adding a small solder dimple to your cells then they can work in any light
xlotus
Thanks for the recommendation but this is not what I am looking for.
I am looking for a flashlight that uses 18650 batteries with a battery carrier and not too expensive.
I am sure it is not just K40M that uses a battery carrier.
There must be others within the same price range.
xlotus
I have button-top and raised-top 18650 for those multi-cell flashlights that require them.
I don’t like to modify my flat-top 18650.
The solder makes it looks ugly and it doesn’t sit well with me doing that on batteries that cost me $5-$10 each.
Adoby
Adoby's picture
Last seen: 3 years 9 months ago
I found that my flat-top unprotected Panasonic 18650B was a little short for my K40M. The batteries was a little loose in the holder and sometimes the light flickered. So I added a small magnet to the top of each battery and the problem was fixed.
I assume that you can do the same and have your flat-top batteries work fine in any flashlight.
xlotus
I use Panasonic NCR18650BD, NCR18650PF, Samsung ICR18650-32A and LGABE11865 and they all fit just fine in the K40M battery carrier without the need of a magnet for each flat-top battery.
The magnet costs extra money and I am concerned that it may cause short circuit in certain flashlights.
antiparanoico
+1
I use flattop NCR18650B and NCR18650BD as is in K40M, no problem. The same with SR51.
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
