**Resolved** Need some help on a Nanjig 105c
3 posts / 0 new
WillyD
Last seen: 4 days 14 hours ago
My C8 started flickering lately, so I pulled the driver and found the issue right away. The positive pad on the driver board has separated or peeled away from the actual board. I put a dab of superglue on it and pressed it down and I’ll try to bridge any gaps if they are broken. But, I don’t think it will hold soldering the positive led wire back on it. Is there any other spot on this driver where I can solder the positive led wire back on? If not I’ll probably just scrap this driver and put a new one in. It was the very first driver I had ever tried stacking 7135s on, so I’m not surprised it finally gave up on me. Thanks.
Edited by: WillyD on 07/12/2015 - 15:59
L4M4
L4M4's picture
Last seen: 1 hour 10 min ago
You can solder it to the pad marked green in this picture:
WillyD
Ah perfect!!! Thanks L4M4. Looks like I solder right to that component.
EDIT
Problem solved! Thanks again. Worked like a charm.
