I'm currently working on a 3D camo maglite with these specs:
- 3X 26650
- TaskLED H6Flex driver, set to drive XHP70 @ 6.6A
- E-switch
- Custom Aluminium heatsink
All parts are here except the reflector/optic. I tired the "deep" magled reflector with an mt-g2 and wasn't please with the beam, this plastic reflector leaks a lot of light! I think about 20% goes right through the plastic. Also the beam although being narrow, it doesn't throw.
Also got a OP 50mm SST50 reflector from fasttech but the beam is way too floody, and it requires a good amount of modification for it to fit into the maglite head. If everything else fails I might have to go with this.
So I kept looking and found this!
http://www.cutter.com.au/proddetail.php?prod=cut2491
It is supposed to be 10 degree and the size is perfect for the maglite. Problem is it's been on backorder for a few months already and don't know any other place that sells it.
So if you know of any good reflector/optic for a XHP70 with a diamater under 48mm, please share it here.
