Sony 18650 Protected 3000MAH
66 posts / 0 new
2100
Last seen: 3 years 4 weeks ago
Ok, here's the TF Flames, 2208mAh down to 2.6V @ 1A constant draw.  Same as what old4570 got i believe. I got the later batch as his....so not too bad. From dealextreme.
asd
2100
Of course those Ultrafire cells are usable for some apps, like XR-E lights or even XP-G.  The 783mAh one can still be used for stuff like laser pointers etc.  I use them for my greenie, they only draw 0.7A.  Smile  And that means i can switch on the laser for about 1hr and 1.3hrs respectively (!!).  And seriously you don't use them for 1hr at a time, so no worries.
What the...it's only $4.80 for 5pcs of the Ultrafire 2400mAh shipped!!  Re-claimed cells sure are cheap like nothing (cost is gonna be much lower).
I'd advise getting the TF-Flames, and from DX only. At least we know that's a good source.  Other sources, it's like lottery.  The "best" thing that can happen to anyone, is getting getting a 2208mAh cell, and another at 1356mAh, the user has no measurement equipment, and then you use this in a triple XM-L with no LV protection...like the TF-3T6.  heh....
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 3 years 3 months ago
agenthex wrote:
ILIKEFLASHLIGHTS wrote:
I'm not disagreeing with you at all.  But again if I can buy 4 sets of the Ultrafire grey protected 2400MAH batteries for about the same exact cost of the Xtar 2600MAH batteries I believe the 8 Ultrafires will out last 2 of the Xtars.  I just ordered 6 more of the Ultrafires.  So far I like these batteries.  I don't need the Rolls Royce of batteries to keep my lights a working.
The crap grey ultrafire are like $8/pair, the xtars about twice that or less. The ultrafires are crap to start with, and what's even worse is that they're not consistently crap so it's probably not very safe to use in multi-cell lights. Frankly half-way decent unprotected cell are better.
Wrong.  Again, I can buy about 8 of them for about the same price as 2 Xtars and I got money that 8 of them will in fact out last 2 Xtar 2600MAH batteries.
http://www.ebay.com/itm/2400-mAh-UltraFire-Protected-18650-Rechargeable-Battery-/360290113090?pt=US_Batteries&hash=item53e2f6d642
I can buy 2 of these for $4.38 factory sealed and delivered to my door.  These again are good batteries regardless of what you Xtar promoters are saying.  I will run them in more of my lights and compare them to the Trustfire flames.  But I doubt I will see any big difference than what I have seen so far.  Again, for the money they are the better deal.
agenthex
agenthex's picture
Last seen: 8 years 1 month ago
So you're buy something that has a catastrophic failure mode at half the price that DX sells them for. And let's be fair here, it's not really half the price since it costly around $2 to ship them to you, so more like 1/3 the price. Good luck.
Reading this makes you smarter: http://lesswrong.com/
DasEtwas
Last seen: 4 years 3 months ago
Well.. If your personal health and safety is it worth.. its on you.. I better pay a few dollars more and will not land in hospital soon Wink .. Interesting most of the "explosion threads" I read where on "ultrafire" batteries... Nobody suggests here to buy AW, Redilsat or other overpriced (but good) batteries.. But the Xtars with Sanyo are very good value... Btw. two ultrafire on your ebay link are ~9.50 shipped... 2 Xtars are 13.50$ shipped... 4$ for a bit of safety and better batteries... Should be a no brainer imho
brted
brted's picture
Last seen: 1 week 18 hours ago
There is a lot of variability in batches, esp. the gray ones, and there are probably a lot of fakes too. I have some true gray Ultrafires ("Ultrafire" is engraved on the negative plate) and they do pretty well. My Trustfire flames have been good, but I know some people get bad ones, and there are definitely fakes of those too since I have some (which are lousy). I don't regret buying the XTAR's I got in the group buy, but I wouldn't want to spend more than that.
I don't buy batteries off of eBay anymore unless I know the batteries from that seller have been tested. That's 1 battery for $4.38 that you linked to, which is about the going rate. The XTAR's were $13.50 a pair. I wouldn't trust a battery that $3.50 a pair.
ILIKEFLASHLIGHTS
Yea I had the wrong link.
http://www.ebay.com/itm/2-x-UltraFire-Protected-18650-Rechargeable-Battery-3-7V-/260749510699?pt=US_Batteries&hash=item3cb5e1c82b
I can buy 6 of these for the price of 2 Xtars.  And I'll be the first to let you know if I see a problem.  They may not be the Rolls Royce of batteries but they will get you there just like a Volkswagen.  I may try some of the Xtars later on.  But I like these batteries for the price and they seem to take and hold a charge well.
2100
Also we have these additional pts to consider :
(1) XTAR 2600s are purchased from XTAR HK as per paypal transaction reference.  There is absolutely no way you can get ripped off. Zero percent. They ship fast, i purchased 3X from them and 3X they arrived in my mailbox within 2 weeks, fastest was 5 working days.    For the budget brands, you deal with ebay, DX, MF, focalprice. You play with roulette as the source, even the same source may receive fakes. And if you do not test/measure, you will never know.  In that case it's better to stick with the small single cell stuff, ie you will never advance past a point, esp if in the future when there are new emitters doing higher currents. We all know that lights are somewhat hindered by cell discharge performance - basically it is 18650 coz that is where all the R&D going to be.  Nobody will give you a true 6AH 32600 even though size would dictate it easily could.
It is really the fakes that are floating around, the ones with using reclaimed cells. So many hundreds of reports around and they have been around for years literally on websites/blogs/CPF/flashlightforums etc. This is not a new problem, and with new flashaholics they will always find buyers. Sellers are interested in profit, and many are not technical.  Eg, you can't blame DX for selling 22g worth of Fujik when it says 30g on the bottle, but you can warn others and that is pefectly ok/legal.
(2) Quality of PCB. Their PCB protection is pretty aggressive.  In my DD XM-L lights, they cut off when fully charged, even in strobe mode. Prob at just over 4 amps. Sensitive as well.  It works perfectly ok when charged to 4.1V in my DRY triple XM-Ls...so it's cool (no real capacity from 4.2V till 4.1V, unless you count approx 30-45 seconds runtime as capacity). Low voltage cut also works. This would be a very safe battery to use but still leave enough headroom for high powered lights.  I have many other budget type protected cells but they cut way too early like they do not allow me to use in the UF-980L @ 3.5A. Only exception is Trustfire Flames.
I don't know how they protect against overcharging in case your cheap charger goes wonky (most usual case of catastropic venting), but i'll bet they cut perfectly.  If a user wants to save a few bucks on cells, i am sure they won't be using hobby chargers or Pila or even XTAR.  I already have 2 faulty OEM generic charger, one actually works but cuts at 4.25V and i don't like that.  Try some more with cheap cells w/o PCB and play more roulette....
I'd rather run a 4S light complemented with equipment like DMM/charger and Li-ion handling SOP, its relatively safer....
(3) Unprotected. Esp if you are a novice and do not know when and how a driver fails and FETs create a dead short and what are the consequences, you will definitely be facing a pipe bomb case, guaranteed. Even if it's protected. I have a protected cell actually do not protect against shorts, faulty?  Again, it's roulette.  Obviously if they can fake a cell they can also fake a PCB.    I'd not count on it to work 100%, or prolonged usage etc.
Edit - i am not saying that they are bad, but only for other applications with lower current needs.
2100
If it's too technical, this should explain better.....pictures and video.
http://www.youtube.com/watch?v=mw8jb1KmAG8
http://thebrightsideforums.com/viewtopic.php?f=15&t=201
Here's one with the Ultrafire Grey...
http://www.candlepowerforums.com/vb/showthread.php?318976-OMG-i-nearly-lost-my-finger!!
http://www.candlepowerforums.com/vb/showthread.php?280909-Ultrafire-18650-3000mA-exploded
During usage : http://www.candlepowerforums.com/vb/showthread.php?122500-Cyclops-Flashlight-Explosion
Seriously when i discharged mine at 1A it already got somewhat warm (high internal resistance). I don't know how it can survive a 2.5-3A discharge and also heated by the XM-L, and still stay safe. Not to mention those DD lights (pretty common) soaking 4 amps which the battery can do at full charge.  (at least mine does, even though the capacity is sucky)
ILIKEFLASHLIGHTS
I have a lot of flashlights, and I can't see putting Xtar batteries in everyone.  So what's the cheapest route you feel is still a good enough battery?  Someone mentioned the Hi-Max.  But even www.goinggear.com sells the Ultrafire blues and I think some of their lights come with a charger and these batteries.  And they aren't protected.  But apparently they work ok or I doubt the guy would still be selling them.  Go to youtube and you can see tons of his flashlight reviews.  Seems to be a pretty smart man on flashlights.
agenthex
agenthex's picture
The hi max are good, but not that much less than the xtars anyway. I mean, if you wanted protected cells, $7 apiece for high end stuff really isn't all that much. You don't need every light to be loaded, you'll only need a few for normal use anyway.
ILIKEFLASHLIGHTS
So where is the cheapest place to buy the Xtars?  Like I said I may buy a few and try them.
agenthex
agenthex's picture
Search the forum. At least two vendors were offering them at the prices mentioned above.
CheapThrills
CheapThrills's picture
Last seen: 2 weeks 3 days ago
We have here a proverb. Hard to interpret directly but:
Always buy the cheapest. By the time, it will cost you a lot and expensive means good quality!
Pretty much fits this thread like a glove...
ILIKEFLASHLIGHTS
Well I'm not pitching the Ultrafires I can tell you that.  They will do me for now.
Chicago X
Chicago X's picture
Last seen: 8 years 5 months ago
I purchased 3 sets of grey UF batteries in the beginning.
They all ended up having different buttons, PCBs, printing, and capacities.
Not wanting to lose a finger, I only buy Sanyo- or Panasonic-based cells now.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS
Ok men I just bought 2 Xtar 18700 2600MAH batteries for $13.50.  That is a very good price for some great quality batteries.  So I thank you men.  I'll probably buy some more.
Thanks Serena for still honoring that price.
I'll let you guys know what I think once I get to use them.  I'm sure they are as good as you guys say they are.
Ian2381
Ian2381's picture
Last seen: 4 years 5 months ago
I just received my XTAR 18700 today and like the batteries, just make sure it will fit your charger as it is longer than the protected 18650. It won't fit with my old charger and barely fit in my newer one.
ILIKEFLASHLIGHTS
I have the Xtar WP2 charger.  Do you think that will work?
Ian2381
Ian2381's picture
I think someone already tried that and fit it barely.Laughing
ILIKEFLASHLIGHTS
Thanks.  I have some other cheaper plug in wall chargers that will definately work if not.
Jacobhl
Last seen: 9 years 11 months ago
Xtar WP II will work without a problem Smile
Moving electrons to light my way.
ILIKEFLASHLIGHTS
Ok thanks.
ILIKEFLASHLIGHTS
Well I decided to order another pair of the Xtar batteries.  I figured I could always use them.  I wonder how long they will honor that price?
mfm
Last seen: 10 months 3 weeks ago
Don't pretend that the cheap fakes from ebay at half the price of DX is actually made by Ultrafire (although the Ultrafire shop is warning that DX are selling fake items...).
ILIKEFLASHLIGHTS
Well it don't look like these guys are much better when it comes to selling fakes then.
http://www.lightmalls.com/sony-lr18650-3-7v-3000mah-rechargeable-li-ion-battery-2-pack
http://kaidomain.com/ProductDetails.aspx?ProductId=10683
So they are selling fakes as well.
That's going off of this info.
wiljen wrote:
Fake for sure.  I checked with a reputable Sony reseller here locally and they say the highest capacity currently available is the 2600 mAh US18650GR cell.   His most recent parts catalog from Sony doesn't even list a cell with a higher capacity than that and the price per piece on the 2600s is higher in bulk than those ebay cells are going for retail.
ILIKEFLASHLIGHTS
I also wanted to tell you guys that ebay pulled the plug on those Sony fakes.  They are no longer on there.  I don't know what they did to the sellers.  But I told them they need to give them the boot.
Hikelite
Sony  makes only industrial wrapped 18650s, not looking like a retail battery.
BTW, check this battery pack built with 18650s from Sony
Chicago X
Chicago X's picture
I count 144 18650s in that pack.  Not bad for something the size of a car battery.
You could run a serious short-arc searchlight with that much energy....
