Which light(s) does BLF Ti Clip fit?
12 posts / 0 new
ReyLight
ReyLight's picture
Last seen: 1 day 21 hours ago
The clip fits not only BLF Ti light, but also some other lights. And the price is good,6$ shipped worldwide.
Spec:hole dia:3mm, hole center to center distance:7mm. Screw:M2.5.
You can use some other similar screws and bolts as long as the lights has two holes.
If you already have the clip, please post the model that you put the clip on. A picture will be very grateful.
List:
1.Convoy s2+ 18350
2.Jetbeam RRT-01/TCR1
3.Niteye Ey10 (normal and Ti)
4.Thrunite T10/T/S
5.Thrunite T20/T/S
Edited by: ReyLight on 08/27/2015 - 20:52
Gunga
Gunga's picture
Last seen: 4 hours 17 min ago
Convoy s2+ 18350. Very good fit.
Gunga
Gunga's picture
Okay, bumping this up. This clip really fits a ton of lights because it’s the same size as the short Nitecore/Jetbeam style clips and has the same bolt spacing. It’s short though not ideal in many applications (IE 18650 lights etc).
So, here are some lights it fits quite well.
Jetbeam RRT-01/TCR1
Thrunite T10/T/S
Thrunite T20/T/S
If you flatten the bolt area, it will fit Zebralights.
On Convoy lights, you need to use convoy bolts and nuts since they don’t have threaded holes. It fits most, like the S series, but may be too short.
If you drill and tap lights, it fits most anything but is best on lights 100mm or less. I have it mounted (by drilling and tapping) an Quark CR123.
This is the same bolt pattern on most new Sinner Tri-EDC lights too.
So really, if you are okay with the short length, it fits lots of lights. Where the clip lands on the light may or may not be ideal. It is great on shorter lights (85mm or less) because it usually clears the head, allowing one to remove the head (for abttery changes) without it scraping on the clip.
Gunga
Gunga's picture
It fits the same lights this clip fits.
http://www.banggood.com/Titanium-Alloy-LED-Flashlight-Clip-For-Nitecore-Jetbeam-Niteye-p-89414.html
ReyLight
ReyLight's picture
Thanks very much for the information.
vinte77
Last seen: 2 months 5 days ago
It fits sinner hosts as well.
Gunga
Gunga's picture
Yep. I mentioned Convoy and some (not the oldest) sinner hosts.
MagPap
Last seen: 2 years 5 months ago
Could you providencia a link if this can still be ordered, please?
Thanks.
By the way, it will fit the Nitecore EX11.2 as well.
ReyLight
ReyLight's picture
MagPap wrote:
Could you providencia a link if this can still be ordered, please? Thanks. By the way, it will fit the Nitecore EX11.2 as well.
Don't know if it fits.   You can paypal to: vivian2c326 at sina.cn.    (change "at" to "@")   6$/pc.
DrafterDan
DrafterDan's picture
Last seen: 2 years 1 month ago
Payment incoming for two (2) clips.
~D
have light, will travel
DrafterDan
So my clip order came in yesterday. Wanted to add to the “clip database”. It fits my NiteCore EX11 v2r5
You can see that the most current iteration has the design holes looking more like a flower instead of the quasi-radiation symbol
mk2rocco
Last seen: 6 months 4 weeks ago
I’m going to try them on a Malkoff MDC.
