Blitzwolf BW-LT5 lantern
45 posts / 0 new
hillosibul
Last seen: 4 years 1 month ago
This one seems interesting:
http://www.banggood.com/BlitzWolf-BW-LT5-IP68-Waterproof-LED-Lamp-Light-2600mAh-Powerbank-Emergency-Camping-Light-p-1030512.html
Possibly a low-cost alternative to Fenix CL25R and other similar lanterns? I have a couple of Blitzwolf USB PSU:s/chargers which are quality-wise a step over the usual cheapo-china stuff so my expectations are high with this.
Preliminary comparison to CL25R based on info available at preorder-phase (subject to change)
Pros:
+price
+compact size
+not only usb-rechargeable, but also power bank function included
Cons:
-fixed battery (not replaceable)?
-neutral white not available?
Depending on user preferrences:
+/- Approx 180 degree lighting angle instead of 360?
+/- Two brightness modes of white light (instead of four with CL25R)
Hobo
Looks interesting
8) Lube Threads Everyday 8)
Gunga
Gunga's picture
Last seen: 14 min 37 sec ago
Pretty cool. Will have to check it out.
L4M4
L4M4's picture
Last seen: 10 hours 10 min ago
ordered Wink
Thanks for the hint!
I wanted the BlitzWolf BW-LT3, but I didn’t came to order that yet.
The BW-LT5 is even better, so good for me Big Smile
juaquin
Last seen: 2 years 3 days ago
I’d be in for one if the battery is a 18650 removable. Very interesting.
M4D M4X
M4D M4X's picture
use 12blitzwolf for 10% off!
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
Hobo
Doesn’t work at this promo Silly
saypat
saypat's picture
Last seen: 2 hours 59 min ago
I like it!
chuckhov
Last seen: 3 years 1 month ago
Hi Martin,
Does it take a standard 18650?
Thank you,
-Chuck
L4M4
L4M4's picture
most likely
But maybe not changeable, but we’ll see.
DBSAR
DBSAR's picture
Last seen: 8 hours 17 min ago
Interesting lantern. It needs to have a warmer tint for lantern use, (lower glare with warmer tints) needs the addition of a moonlight/nightlight mode, and get rid of the USB charging function. (single cell USB chargers of less than 4000mah are useless for more than one charge, then i may consider one.
hillosibul
I agree the need for a warmer tint, but this I did not undestand:
Huh? Better have and not need it, than need and not have it, right?
BG just announced my BW-LT5 as shipped, so maybe we’ll know more in a couple of weeks…
DBSAR
DBSAR's picture
u was referring to the USB output charging. (the micro-USB charging input is a good idea as long as the charger circuit is of a good quality & regulation to be safe.) single cell USB “charger sticks” barely give my large Samsung Note-3 a single charge, and woudl render the lantern useless if its cell is dead due to it being drained quickly by charging a modern high powered device.
L4M4
L4M4's picture
Sure, but this isn’t made to be a powerbank first in line.
It’s a little extra gadget for emergencys – and you will be very glad about a 70% charge if your smartphone is dead and you need to call help Wink
Phaserburn
Pretty cool little lantern.
chadvone
chadvone's picture
Last seen: 33 min 25 sec ago
I was looking into these few days ago. Seams bigger than it needs to be.
koyotee
koyotee's picture
Last seen: 5 months 4 weeks ago
If 100 lumens is what you need…
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
texas shooter
Last seen: 41 sec ago
It’s a power bank the gives off light. Low capacity but better than nothing. Changing out the battery would be my first goal, then not breaking it the second. It looks like a handy stocking stuffer but Christmas has already gone.
Tank
Last seen: 2 years 1 month ago
I just ordered one now.
And yes, the CL25R is the one I really would like to get, but budget is budget… unless I get a good discount for it Smile
//Tank
Hobo
will34
will34's picture
Last seen: 2 hours 2 min ago
Most likely the same, I have seen these tube lanterns sell under many brands… Maybe buying blitz wolf might somewhat ensure that the internal
Battery is really 2600mah…
Pandawill used to sell these for cheap but I don’t know why they are so expensive now.
DBSAR
DBSAR's picture
Hobo wrote:
Seems to be equal to this
EDIT: Well, looks like we paid more than necessary :/ http://www.banggood.com/Portable-IP68-Waterproof-LED-Tent-Camping-Night-Light-Outdoor-Travel-Power-Bank-Lantern-Lamp-p-997324.html?utm_source=youtube&utm_medium=SKU275472-1028&utm_campaign=tommy&utm_content=tommy
interesting, i wonder if there are any BLF codes that will work for a discount on that one.
will34
will34's picture
This product is supposedly on promo right now and neither coupon or points can be used, I guess they’re getting rid of the old stock to sell their own brand only.
L4M4
L4M4's picture
So, I got mine today.
Nifty design, you can pressurize the O-Rings to make this thing even more waterproof (turning the big 16-cornered thingys on both sides).
Light output isn’t that much, but I see this as an emergency-device, and the tint is very nice.
AND I GOT IT OPEN!
It’s very (VERY) easy to open Big Smile
Will make some photos for you Smile
L4M4
L4M4's picture
So, at first I have to apologise – I had the White-Balance set to manual at first Silly
The battery is hold in place with some tape and isn’t directly soldered to the pcb – it uses a plug (plug and jack were glued together, so I had to tip them both off)
2.5Ah instead of 2.6Ah? I want my germoney back! Big Smile
And that’s how this thing seals up – the big nut presses the conical part onto the O-Ring and therefore press it to the outer tube.
Hobo
Nice, thank you for these pictures. When did you order yours? Waiting for my 2 units and the tracking code doesn’t work… This is an unprotected cell, right?
L4M4
L4M4's picture
The cell is unprotected, yes – but I hope that there is a protection circuit on the pcb Silly
I ordered on Jan 29th 2016 – but with Priority Direct Mail, which is around twice as fast as the standard shipping to germany.
edit: It delivers 1.2 Amps for my 38% full phone at 5.07V
will34
will34's picture
Nice, thanks for the pictures. So to open it you just pull both ends apart?
I thought the heatsink would be a half moon shape containing the battery, because my non waterproof model in extended operation at high modes does get pretty hot.
L4M4
L4M4's picture
unscrew the big nuts, so that the O-Rings aren’t pressurized, and then just pull and twist a bit (no lubrification on the rings)
Martini
Martini's picture
I want one
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
DBSAR
DBSAR's picture
Just discovered that link is gone from GB now..
