Blitzwolf BW-LT5 lantern
This one seems interesting:
Possibly a low-cost alternative to Fenix CL25R and other similar lanterns? I have a couple of Blitzwolf USB PSU:s/chargers which are quality-wise a step over the usual cheapo-china stuff so my expectations are high with this.
Preliminary comparison to CL25R based on info available at preorder-phase (subject to change)
Pros:
+price
+compact size
+not only usb-rechargeable, but also power bank function included
Cons:
-fixed battery (not replaceable)?
-neutral white not available?
Depending on user preferrences:
+/- Approx 180 degree lighting angle instead of 360?
+/- Two brightness modes of white light (instead of four with CL25R)
Looks interesting
Pretty cool. Will have to check it out.
ordered :wink:
Thanks for the hint!
I wanted the BlitzWolf BW-LT3, but I didn’t came to order that yet.
The BW-LT5 is even better, so good for me :smiley:
I’d be in for one if the battery is a 18650 removable. Very interesting.
use 12blitzwolf for 10% off!
Doesn’t work at this promo :stuck_out_tongue:
I like it!
Hi Martin,
Does it take a standard 18650?
Thank you,
-Chuck
most likely
But maybe not changeable, but we’ll see.
Interesting lantern. It needs to have a warmer tint for lantern use, (lower glare with warmer tints) needs the addition of a moonlight/nightlight mode, and get rid of the USB charging function. (single cell USB chargers of less than 4000mah are useless for more than one charge, then i may consider one.
I agree the need for a warmer tint, but this I did not undestand:
Huh? Better have and not need it, than need and not have it, right?
BG just announced my BW-LT5 as shipped, so maybe we’ll know more in a couple of weeks…
u was referring to the USB output charging. (the micro-USB charging input is a good idea as long as the charger circuit is of a good quality & regulation to be safe.) single cell USB “charger sticks” barely give my large Samsung Note-3 a single charge, and woudl render the lantern useless if its cell is dead due to it being drained quickly by charging a modern high powered device.
Sure, but this isn’t made to be a powerbank first in line.
It’s a little extra gadget for emergencys - and you will be very glad about a 70% charge if your smartphone is dead and you need to call help :wink:
Pretty cool little lantern.
I was looking into these few days ago. Seams bigger than it needs to be.
If 100 lumens is what you need…
It’s a power bank the gives off light. Low capacity but better than nothing. Changing out the battery would be my first goal, then not breaking it the second. It looks like a handy stocking stuffer but Christmas has already gone.
I just ordered one now.
And yes, the CL25R is the one I really would like to get, but budget is budget… unless I get a good discount for it :slight_smile:
//Tank
Seems to be equal to this …
EDIT: Well, looks like we paid more than necessary :confused: http://www.banggood.com/Portable-IP68-Waterproof-LED-Tent-Camping-Night-Light-Outdoor-Travel-Power-Bank-Lantern-Lamp-p-997324.html
