Mec-Army PT-16, Triple XP-G2 in a "Nutshell" (NOW a 3402 Lumen Quad!)
116 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 3 weeks 1 day ago
I would guess that 3 HI’s would be in the 1300-1400 lumen territory. Remember that it’s an aluminum mcpcb and proprietary to the optic, the placement isn’t the same as with a Carclo optic so a copper Noctigon can’t be slipped in.
So, XP-L HI’s on Al wouldn’t net much over XP-G2’s but might do it at a cooler temperature. If I’d had 4 matching HI’s I would have found out…
Vinh is claiming to achieve 1253 from the 18650 variant, my little quad PT-16 is doing 1180 from a 16340, so there’s just not a lot to be gained in this one apparently. I guess it’s time to squeeze an FET driver in and find out what’s shakin… Big Smile
DB Custom
DB Custom's picture
I stripped the driver, piggybacked in a 15mm FET driver with ToyKeepers 64 level ramping firmware. This was not easy. I probably screwed it up in the end but at the moment it’s working. With the partially used little 16340 I saw a first read of 1359.3 lumens from the XP-G2 S4 2B Quad.
This PT-16 has a different button retaining ring than the newer PT-10. I unscrewed it and found a silicone button with metal insert that is fitted into a groove inside the recess, it’s well thought out, as waterproof as possible, and it works. I don’t know if the new one unscrews or not, it doesn’t have the 1/3 circle clip cutouts in the retaining ring around the button like this PT-16 does.
Cell charging, I’ll get a full charge readout when it’s done. Smile
DB Custom
DB Custom's picture
Freshly charged Efest Red V2 IMR16340, 4.20V. How does 4.16A at 1493.85 lumens sound? Big Smile
This 15mm driver has one of the tiny 3 legged mosfet’s on it, does a great job as far as I’m concerned!
onetrickpony
onetrickpony's picture
Last seen: 3 years 7 months ago
Dang it Dale, you work fast my man. Well done!
texas shooter
Last seen: 20 min 20 sec ago
Time to bore it out to 18350. I’m due to be out awhile with shoulder surgery but it’s on my list of thing to get my gunsmith to do. Great work so far.
-X3-
-X3-'s picture
Last seen: 2 weeks 1 day ago
Is MecArmy a Cooyoo rebranded or is CooyArmy a MecYoo ? Sick
http://www.banggood.com/CooYoo-Particle-3xCREE-XP-G2-1000LM-6Modes-USB-Compact-LED-Flashlight-p-1038456.html
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Easyrr
Last seen: 11 months 4 days ago
Different name due to MAP? Cooyoo-Blackwater-MecArmy triangle.
DB Custom
DB Custom's picture
Interesting, nice find X3
Same exact light, even the same cell it’s shipped with. I didn’t know they were affiliated, learn something new every day! lol
Edit: TexasShooter, been looking at that. I think it has room and feel pretty sure that a Purple IMR18350 would deliver more current. Have to look at the tube now and see if I can keep the on-board charging system or if it needs to go.
texas shooter
X3 wrote:
Is MecArmy a Cooyoo rebranded or is CooyArmy a MecYoo ? Sick http://www.banggood.com/CooYoo-Particle-3xCREE-XP-G2-1000LM-6Modes-USB-Compact-LED-Flashlight-p-1038456.html
CooYoo is their Asian logo and MecArmy is their North American/European market logo. Just changing the filters“location” changes the products names. It’s mentioned on CPF a little while ago.
DB Custom
DB Custom's picture
Removed the charger, bored the tube, made an insulated spacer with Delrin and brass. Purple Efest IMR18350 does a rested 6.01A and 1907.85 out the front… cell measured 4.15V so I’ll charge it up and see where max peaks. Smile
Last night I measured 8.39 lumens at the bottom end. So there’s 64 stop points between 8 and 1900 lumens. How sweet is that? Big Smile
Edit: Fresh off the charger, the little Purple Efest 18350 makes 2187.3 lumens on top, 8.59 lumens on bottom. I can live with that. Big Smile
-X3-
-X3-'s picture
OMG Love Nearly 2000 lumens OTF ?!
DB Custom
DB Custom's picture
Actually, 2187 out the front on a fresh cell. It’s no longer regulated so output will drop with the cell’s discharge.
I have a little battery back-up pack from GearBest called a Mi that has 3 18650’s from Samsung or Panasonic, all Texas Instruments components… nice little phone charger or back-up. I used the charger out of the PT-16 with this pack and charged a Windyfire 14500 to exactly 4.20V just a few minutes ago. I’ll carry this with the pack as a very small and accurate battery charger, with green/red indicator lights. As an added benefit, the Mi turns off when the cell is charged, so it is pretty safe as well in this combination. (I removed the springs and soldered wire leads with magnets on the ends, makes it easy to charge a cell off this pack)
will34
will34's picture
Last seen: 8 min 59 sec ago
Awesome numbers Dale, did you have to bypass both positive end springs?
DB Custom
DB Custom's picture
It no longer has springs, of any kind. Originally it had a spring between the charger and positive end of cell, another on the opposite side of the charger to contact the driver positive contact, which is a thin brass disc.
Now I have the cell fitted between a brass spacer that is adjusted with the threaded white plastic cover that once allowed the red/green charge indicator lights to show.
zoom zoom
Last seen: 2 years 7 months ago
Very cool! Do you have an endless source of quad pcbs? I can’t find them anywhere, except austrailia, shipping is terrible.
Firelight2
Firelight2's picture
Last seen: 5 hours 13 min ago
This.
Got more direct copper quad MPCBs? I need some!!!!! Big Smile
Firelight2
Awesome mod Dale.
Next step: Open up the battery tube enough to fit an 18500.
  • remove the copper spacer from the battery tube.
  • bend a strip of copper into a ring and insert it into the head as a stop to prevent the head from screwing in all the way.
  • do the same if necessary at the tail.
DB Custom
DB Custom's picture
I looked at an 18500, much too long. Besides, where is there an 18500 that supplies the kind of power the Efest Purple IMR18350 will give?
I bought a few quad boards for a project that didn’t pan out, so …
SoulCraves
Last seen: 5 hours 20 min ago
Dale, just checking, did you do runtime with the 16340 and 18350? I’m just thinking since it comes with that awesome small form factor, might be good to keep to that form but with your awesome 1493 OTF lums to wow friends instead of ramping up to almost 18650 form, where most torches congregate.
That said, duration might be a whole PITA experience.
DB Custom
DB Custom's picture
The light is making 2187 lumens from an 18350. It looks just like it did before. (Well, it’s a quad now instead of a triple) I have the charger working outside of the light, seems to be a nice little charger in it’s own right.
Haven’t done any kind of run-time tests, just got it done this morning and then my SP-03 came in and I spent the day building it with MTN’s SRK driver and a massive tellurium copper pill I made for it (all today, just got done)
Two fairly tough builds, one long day, I’m exhausted! lol
DB Custom
DB Custom's picture
Update:
I now have the 10440 and 14500 variants of this light as well. With the 16340 being heavily modified I’m leaving the other 2 stock. Swapping in a better cell makes for a nice improvement and the built in charger still makes it a very nice EDC style light that can be recharged almost anywhere with the battery bank for back-up.
The 10440 is a bit on the odd side with it’s VERY narrow tube, the 14500 is sweet, a nice balance.
The 16340 is still amazing in it’s form factor, short squatty potent little light that easily fits in a watch pocket. Crazy small. These would make nice gifts to a flashlight noob, with the USB charger built in no extra bits and pieces required. They even come with a decent cell already inside, simply remove a plastic disc that is blocking current and you’re up and running.
The only thing to watch for is that you’re getting the new UI as compared to the original one. If I’d gotten the new UI in the 16, I probably wouldn’t have modded it at all. Wink
djburkes
djburkes's picture
Last seen: 4 years 1 week ago
DB Custom wrote:
Update:
Where’d you purchase your 14500 version from so that I’ll know I’m getting the newest UI?
DB Custom
DB Custom's picture
I got it on Massdrop. Just pay attention to what they say the UI does, it should start on Moon with the first click to wake it up, a double click from off is instant Turbo (I’m blind now, had to actually do it to make sure I was remembering right)
LightRider
LightRider's picture
Last seen: 3 years 9 months ago
Dale, did you ever figure out if the newer retaining ring without notches is threaded or not? Thinking about tearing into mine soon but want to get the switch cover off so I can put it in the vise to crack loose the bezel.
DB Custom
DB Custom's picture
Yes, it’s threaded. I have one right here that I coincidentally just put on the charger… easily removed the threaded switch retaining ring with my fingernails. Wink
DB Custom
DB Custom's picture
Just did some modification to the PT-16 by swapping emitters and fitting the optic, I pulled the 1.5A XP-G2’s in favor of the new 3A XP-L W2 1D. The opening for the emitter in the optic is narrower than I’d hoped so I used a ball nosed end mill bit to fit the optic to these new emitters. While it doesn’t make a lot more lumens, it should be producing a lot less heat as the 3 XP-L W2 1D are running at such a low power consumption.
11.834 Lumens
81.42
337.76
1138.5
Slightly more lumens, nice tint, perhaps more heat efficient? At the very least I know I’m ready to turn it into a quad with one more emitter and then I can pull the driver and piggyback in a ramping firmware FET for what should prove to be some serious bumpage. Wink
LightRider
I have the pt18 and pt14 and I must say that these are my most luxurious feeling lights. Very nice lights! I’m not sure what I’m going to do yet. The tint is too cool for me. It washes colors out and reflects a lot of unusable white back at me when I’m trying to look for something I’ve dropped onto the carpet under my work area. (By the way, that carpet has to go! I spend half my day searching for all the things I drop and bump as I’m stumbling around working on stuff)
I wanted to try to reflow some of the nichia 219c 4000k high cri but I’m afraid the lower vf will result in less power. Seems to be the case with most high cri options. Any high cri options with a higher vf. In the 4000-5500 temp range though.
DB Custom
DB Custom's picture
Ok, just because I could, I put a 15mm FET driver with ramping firmware in this PT-16, Quad XP-L W2 1D emitters under a Carclo quad optic. Doubled copper under the emitters.
It’s making 1801 lumens on a rested and partially used Red Efest Button Top 16340. Smile
Edit: The charger is still in the top of the battery tube, perhaps on a warmer day I will remove the charger and bore the tube for an 18350 and see if I can’t break the 2000 barrier. On the other hand, it’s nice to have the charger still intact…. Wink
mattlward
mattlward's picture
Last seen: 15 hours 50 min ago
A close copy, the SR71, will take an 18350 and should be a great quad mod host as well.
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
LightRider
For the price, the blackwater lights do not look as nice to me. I think it’s the pinaple knurling or something. But I’ve never held one so can’t say for sure. I do like the tail cap with lanyard hook option though.
