Help with Convoy L6 requested
13 posts / 0 new
sandanbob
Last seen: 1 month 1 week ago
Hi- I received my L6 about two weeks ago, and am having trouble. I have tried two types of 26500 batteries- the LiitoKala ones, and some Supfires. With the LiitoKala cells, I get nothing. I added magnets to see if there was a problem with length, but nothing. With the Supfires, the LED would flicker as I was seating the tail cap, but once I had it threaded, nothing. I also tried some 18650 cells in sleeves, with results the same as the Supfires.
Has anybody else had trouble with theirs? What can I do to troubleshoot? Do I need different batteries?
Thank you for any assistance that can be offered. I feel bad having a light that I can’t use.
Bob
Lightbringer
Lightbringer's picture
Last seen: 2 hours 18 min ago
Directly bridge the negative end of the cells to the inside of the case (ie, bare metal, bypassing the tailcap completely)?
Of course, make sure they’re button-top cells, blah blah blah. Need to make sure they make contact from one to the other.
Far Thrower
I got caught in a moment of excitement and forgot to push the button in on the tail switch.
Sounds stupid I know but that can happen when you are dying to fire up a new light!
Facepalm
chops728
Last seen: 2 hours 52 min ago
Also check that locking nut that holds the Tacticle grip ring tight—sometimes mine comes loose preventing the tail cap from tightening all the way
sandanbob
Bridging did demonstrate that the light will work. I may need different cells, as these are flat tops, but I thought with magnets they would make sufficient contact.
I did remember both switches. Smile
I have not installed the tactical ring as of yet. Should I try doing so?
Thank you for the responses!
Speed4goal
Last seen: 1 year 2 weeks ago
He’s talking about a different ring. On the l6 after you take the tailcap off there is another ring that pretty much blends in with the light. With some people it seems this piece keeps the batteries from making a solid connection.
For the liito Kala 26650 mine wouldn’t work in series. So I took a small knife and slightly bent each of the 4 prongs up and now they work perfectly. Some people can use them as is. Others need magnets/jax connector etc.
Just like some people have problems using 30q in series I’ve never had a issue. Same with these batteries
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Streamer
Streamer's picture
Last seen: 1 year 11 months ago
Only one magnet is needed….You did install the magnet so that it is BETWEEN the 2 batteries? Right? The head and tail springs fit the flat tops just fine… just checking
sandanbob
I had tried 1, 2, and 3 magnets with no success.
However- the additional information regarding the ring helped. I found it, and turned it so it was closer to the head, and lo and behold, the light worked (with LiitoKala cells and one magnet between them.) I feel better- thanks for walking me through it. I know have a light I can use. And, I’ll watch for deals on button top cells. What do folks recommend?
chops728
Just put a solder Blob on top of the Pos + side of the battery—doesn’t take that much— I’ve had some great results with Shockli 26650
http://www.mtnelectronics.com/index.php?route=product/product&path=59_10...
Lightbringer
Umm, dumb question, maybe, but did you take an ohmmeter to the top/bottom of the magnets?
Make sure they’re not coated with anything like clear lacquer to keep the finish or anything.
sandanbob
I didn’t do that, but once I screwed down the tactical ring retainer (I am not sure what the official name is) so that the tail cap could make contact on the non-anodized portion of the tube, it worked (with one magnet between the two cells.) I am not sure if it would work with no magnet, as I haven’t tried that yet, but I will with both brands of cells that I have. Thanks!
sidecross
sidecross's picture
Last seen: 4 years 5 months ago
Most problem solving begins at the beginning. Problems in most cases were first caused by false assumptions. Smile
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
sandanbob
My initial assumption was that it would come ready to go, just add batteries. I didn’t even see the retaining ring, so didn’t realize it could be the issue. Thanks to the advice here, I am good to go. Smile
