Received mine today. I can confirm it won’t fit any 18350, not even a flat top 16340. Either they redesigned the tailcap or planned on using a low profile button on the driver, then replaced it with a big stiff spring. Unusable without modding. Just insert a 18350, push down as hard as you can – it still sits over the battery tube, and therefore the tailcap cannot be tightened enough to make contact.
So basically if you don’t have the 18650 extension tube you can’t use the light?
Take off the driver spring and solder blob it or the battery, should solve it (i hope).
Received mine today. I can confirm it won't fit any 18350, not even a flat top 16340. Either they redesigned the tailcap or planned on using a low profile button on the driver, then replaced it with a big stiff spring. Unusable without modding. Just insert a 18350, push down as hard as you can - it still sits over the battery tube, and therefore the tailcap cannot be tightened enough to make contact.
So basically if you don't have the 18650 extension tube you can't use the light? :FACEPALM:
It's a chunky one, but just sitting in that machined out spot. Seen this many times before. It's gotta collapse maybe 1-2 mm above the bottom for the cell to fit w/solder boob.
This is my temp solution. Banggood should still make good this faulty designed flashlight and send us the proper tube.
Remove the tail spring and fit 3 magnets to the -ve end of the 18350. Tail spring can be easily pulled out of the cap, and no soldering required. It then fit quite nicely, provided you happens to have the magnets.
Nice! With the solder job I did, the S41 tail works great with it. The S41 tail spring is real soft, plus it's got more clearance.
Battery tubes are identical between the S41 and S42, though the S41 feels slightly heavier.
A shorter or softer tail spring would probably work well, but dunno what options you'd have. Can't just solder in a replacement. Maybe can cut down the stock one, then solder a softer one to the remaining bottom ring of the stock spring.
It seems like the simplest solution is to send retaining rings to thread into the head and give some more length to the tube?
Is that simpler than removing the driver spring and cutting off a coil from the tail spring?
You’ll have to wait a month for an extra part and it will not look nice when the tube is not screwed in the head all the way.
Dang, taking off the bezel, thought I was real careful, but the first movement I heard something that didn't sound right - broke a post off the quad optic . Super thin and tall posts - wow.
I think with the solder blob for the driver spring, there's something that can be done for a soft spring in the tail. Didn't check any 18650 tubes yet i got around.
No, I’m hoping there is a simple solution that BangGood/Astrolux can send out which will solve the problem definitively. Pulling the tail spring and putting in spacers seems fine for a temporary solution. I am astounded that they manged to hose it up given that this is really an incremental change from the S41. A different length tube just seems like another opportunity to mess up.
Does anyone who has an S42 in hand have an 18650 tube to see if the same problem exists with the long tube?
Well, if it is, and i suspect it is the same, Banggood sells spare optics, in case it’s necessary to replace it.
Geez.. To be honest i think it’s kind of fun and satisfying when you have to modify a light a little to have it work, but breaking off a leg of the optic like that is just disheartening..
So any thoughts as to what Banggood might do to make this right? Send out the 18650 tubes and an 18650 cell? Would it be easier to simply return it? Do they offer free return shipping labels?
Well, it's not so easy. I have a couple BLF A6's, so the S41/S42 tube is listed as an A6 tube. So if the A6 tubes I have are the same as what they are selling, it won't work straight up. I had to flip around the tube to get contact on the driver side, the non the tail side, I had to add a washer around the tail spring so the tube end made contact in the tail.
Now it could be there are A6 tube variants - I've had the BLF A6's since the beginning, so maybe they changed.
I finally got an16340 to work.. I try’d a magnet on the negative and it wasent working out.. but I managed to get my battery negative pushed in a little.. then try’d the battery with no magnet now it works“don’t know why now.. this light makes you work for it.. all in all for the non discounted price there is other options (and discounted price)for whatever purpose you plan on this to be..
I always planned on useing this light with a 18650.. it is too small to run this 2000 lm turbo .. it gets way hot to quick.. I was curious why so many people wanted this light useing the small battery configuration?? For what purpose with the 18350 or 16340?? the only thing would be everyday carry right? This would be horrible for that imo.. if you want a small battery edc get the on the road m3 if little is what you want.. the m3 has been awsome for edc for past months .. and this ui is a little funky.. but it’s still a cool light lol
It gets even more hot with a 18650 lol it pulls amps from a higher drain battery
But you actually have a handle with a 18650 instead of holding pretty much the head where all the heat comes from.. that’s like having a stick with a fire on the end of it. Are you gunna hold the one foot fire stick or the 3 inch fire stick
- UI is terrible
- Fit and finish is pretty good, although my lens did have blemishes
- *My Efest 18350 flat top fits fine…I do have to really tighten down the tail-cap for there to be contact. My BLF A6 18650 tubes work fine with a Samsung 30Q
- Good output, but I find the beam pattern of the BLF A6 more practical for my use
My bad. Didn’t know you meant it was too hot to hold. I thought you meant the light just get too hot in general with 18350
- UI is terrible
with all the solder boob jobs I’m doing for the Q8 and now for the S42
I may just move to Hollywood and set up practice
Yep, just did that, posted here: http://budgetlightforum.com/comment/1139682#comment-1139682, but it's not enough. Battery still getting crushed - very tight.
Hmmm…
Do you have a pic of the tailcap spring?
Is it on a PCB? (probably not)
Ask and you shall receive
Thanks.
So with a shorter tail spring it will be okay?
Maybe just cut off a coil or more from the stock tail spring?
Lazy-R-us
Lazy-R-us
Aargh..!
That’s horrible..
Is it the same optic as the S41?
Wow, what a trainwreck. Y’alls feedback in this thread is appreciated. I had an S42 in my cart…
I think so. I just got mine and 16340 wouldn’t work.. I’m waiting on my tube to come
Can't tell - never was able to open the head of my S41 - glued up tight.
what a wonderful idea…
in my dreams, too
Dang.
Just to add to the thread.
I got my S42 from alieexpress yesterday.
- UI is terrible
BLF (GT, Q8, A6)
Haikelite (MT03 TA, SC01)
Astrolux (EC01, FT03, MF-01, S1, S42)
Sofirn (C8A, SP32A, SF14, SP40)
Emisar (D4, D4S)
[Convoy L6, Utorch UT02, KDLITKER C8.2, Inova T4R]
Yea I already felt the heat quick
I agree!!
I already don’t like my not jet arrived S42.
m(
