Eagle Eye X7 Melt Down
18 posts / 0 new
dsiddens
dsiddens's picture
Eagle Eye X7, no mods, EVVA 26650 5200mAh button top.
Both springs overheated, lost temper and lost spring.
I tried to bluetooth a pic from my phone to the computer for attachment but couldn’t get it to transfer.
Doug
Edit: unsoldered the wires, looked for possible contacts between + and host, resoldered the wires. At first turn on there was no light but the springs were on the way to a second melt down. I suspect the driver is internally shorted.
Edited by: dsiddens on 07/06/2017 - 05:30
The Miller
The Miller's picture
Last seen: 2 years 1 month ago
Hmm i can upload to tinypic from my phone (even from cam)
maybe that works?
Lowtech
Last seen: 1 year 1 month ago
So where was the short? Or have you not disasembled the light yet?
dsiddens
dsiddens's picture
I’ve dissembled the light and no other damage is apparent. Just the overheated springs.
dsiddens
dsiddens's picture
I did a reboot of the computer and that fixed the bluetooth issue. Now when I try to attach an image I don’t a popup that allows me to go to my drive and select the image.
RobertB
RobertB's picture
Last seen: 2 days 1 hour ago
Just email the picture to yourself from phone to computer.
The Miller
Yes you need to host the image somewhere, like tinypic or something
Then you have a link to it and it can be posted (please set width 100% while doing the posting Wink )
Lowtech
Well there has to be since you cant melt the springs just like that on a stock light
The Miller
Do check the wires under the reflector, do they have enough clearance or is one touching it by any chance?
kramer5150
kramer5150's picture
Last seen: 1 week 2 days ago
Here you go…
http://i1052.photobucket.com/albums/s450/muvotx/Screen%20Shot%202017-07-...
Hard to tell from the pics. How does the reflector back side look? Any chance the LED+ and LED- are shorting through the reflector?
Lowtech
Use another site.. pb is useless.
khas
Last seen: 1 month 3 days ago
The Miller
Can you take a PIC of the other side of the driver?
How much space between driver spring and retainer ring?
ImA4Wheelr
Last seen: 4 months 1 week ago
If the springs fried before power on, short within the driver does seem most likely cause.  Please let us know what problem you find on the top of the driver (or post a couple good close up pics).
EDIT: Nix the above.  The switch would have to be On (or shorted) for a short in the driver or LED leads to matter.
jr2017
Last seen: 3 years 2 months ago
You can always try running it without a reflector to determine if that is the cause of a short circuit. If that was the original cause, something else might have been fried but you may be lucky too
The Miller
Welcome to BLF jr2017, right on!
It reminds me of the Coneta, 26650 with a wide +top could short because the driver retainer ring could touch the cell creating a dead short.
Firelight2
Firelight2's picture
Last seen: 6 hours 14 min ago
Sounds like the light had a dead short, which caused the springs to overheat and lose tension.
It’s a very good thing that happened. If the springs hadn’t failed, the short might have caused the light to explode.
jr2017
Thanks Smile
