Shockli IMR14500 660mAh (Yellow) 2018
Official specifications:
Type of Battery: Shockli 14500 660mah IMR 10A Button top
Size(mm): 14.2±0.1mm(Diameter) x 50mm±0.1mm(Length)
Weight(g): 20±1g
Nominal Voltage: 3.7V
Nominal Capacity: 660mah (1A Discharge)
Discharge Cut-off voltage: 2.75 V
Standard Charge: 0.3 A~1A (Recommend 0.5 A~1.0A) /4.2V±0.05V
Maximum charge current: 1A
Continuous Discharge Current: 7A
MAX Discharge Current: 10A
Initial Impedance: <25 mOhm
Cycle Life: 500 times, discharging capacity >70%
Charging Time: Standard charge, 4hours at charge current 1A
Operating environment: Charging, 0°C ~ 45°C, Discharging, –20°C~60°C
Application: Flashlight
This is a high current AA sized (14500) LiIon battery.
The discharge curves traks nicely up to 7A, at 10A there is difference between the cells.
Conclusion
These batteries has good high current performance
Notes and links
The battery was supplied by shockli.com for review.
Comparison to other LiIon batteries
