Shockli IMR14500 660mAh (Yellow) 2018
%202018/DSC_5797.jpg)
Official specifications:
Type of Battery: Shockli 14500 660mah IMR 10A Button top
Size(mm): 14.2±0.1mm(Diameter) x 50mm±0.1mm(Length)
Weight(g): 20±1g
Nominal Voltage: 3.7V
Nominal Capacity: 660mah (1A Discharge)
Discharge Cut-off voltage: 2.75 V
Standard Charge: 0.3 A~1A (Recommend 0.5 A~1.0A) /4.2V±0.05V
Maximum charge current: 1A
Continuous Discharge Current: 7A
MAX Discharge Current: 10A
Initial Impedance: <25 mOhm
Cycle Life: 500 times, discharging capacity >70%
Charging Time: Standard charge, 4hours at charge current 1A
Operating environment: Charging, 0°C ~ 45°C, Discharging, –20°C~60°C
Application: Flashlight
%202018/Shockli%20IMR14500%20660mAh%20(Yellow)%202018-info.png)
This is a high current AA sized (14500) LiIon battery.
%202018/DSC_5796.jpg)
%202018/DSC_5799.jpg)
%202018/DSC_5800.jpg)
%202018/DSC_5801.jpg)
%202018/DSC_5802.jpg)
%202018/Shockli%20IMR14500%20660mAh%20(Yellow)%202018-Capacity.png)
The discharge curves traks nicely up to 7A, at 10A there is difference between the cells.
%202018/Shockli%20IMR14500%20660mAh%20(Yellow)%202018-CapacityTimeHours.png)
%202018/Shockli%20IMR14500%20660mAh%20(Yellow)%202018-CapacityTime.png)
%202018/Shockli%20IMR14500%20660mAh%20(Yellow)%202018-Energy.png)
%202018/Shockli%20IMR14500%20660mAh%20(Yellow)%202018-PowerLoadTime.png)
%202018/Shockli%20IMR14500%20660mAh%20(Yellow)%202018-TripCurrent.png)
%202018/Shockli%20IMR14500%20660mAh%20(Yellow)%202018-Charge.png)
Conclusion
These batteries has good high current performance
Notes and links
The battery was supplied by shockli.com for review.
Comparison to other LiIon batteries
