[The Lite Review]: Rofis MR70 Dual LEDs (XHP70.2 & XP-G2) Review
9 posts / 0 new
mcorp
Preface
The original review can be found on TLR's website: Click Here
Dual LEDs (for different types of beam profiles) always gets us excited, somewhat like having "thrower" & "flooder" all-in-one flashlight.
The MR70 is even capable of working as a powerbank with its included non-proprietary 26650 battery.
All of the above may sound like a home run for Rofis or is it?
Click HERE to skip to & see the discount code (brings price down to $64.69) for this light!
Packaging & First Impressions
This is what the light will come with as shown below.
  • The threads and o-rings were well lubricated. Threads were smooth and clean (no gritty feeling).
  • The side electronic switch requires a firm and deliberate press to activate and helps in preventing any unwanted activation of the light.
  • Anodizing of the light is uniform without any missing specs; with a light shine to it.
  • The provided lanyard is able to support the full weight of the light and should hold up to the test of time.
  • Holster provided is of decent quality and should withstand day-to-day abuse without issue.
  • Battery compartment holds the provided non-proprietary 26650 5500mAh battery with sufficient room for a slightly thicker battery width. Larger capacity/fatter 26650 batteries should be able to fit without issue as well.
Front:
Back:
Sides:
Top:
Box Contents:
Quick Overview (Manufacturer Specifications)
  • Body Material: Black HAIII Aluminium
  • LED: XHP70.2 P2 bin (Main LED) & XP-G2 R5 bin (Side LED)
  • Battery Format:  1 x 26650 ONLY
  • Output & Runtime (with Rofis 26650 3.6V/5500mAh battery):
    •  Main LED (XHP70.2)
      • Low (30 lumens / 120h)
      • Mid (450 lumens / 9h)
      • High (1500 lumens / 10min) -> (1000 lumens / 206min)
      • Turbo (3500 lumens / 1min) -> (1500 lumens / 10min) -> (1000 lumens / 190min)
    •  Side LED (XP-G2)
      • Low (3 lumens / 7day)
      • Mid (60 lumens / 36h)
      • High (200 lumens -> 120 lumens / 9h)
  • Max Beam Distance: 248m
  • Beam intensity: 15,390cd
  • Waterproofness: IPX-8 Standard (2m)
  • Impact Resistance: 1m
  • Dimension: 127mm (length) x 31mm (body diameter) / 39.2mm (head diameter)
  • Weight: 139g (excluding batteries)
  • Battery reverse polarity protection
  • Accessories Included:
    • 1*Rofis 26650 5500mAh battery
    • 1*Micro-USB Cable
    • 1*Micro-USB to USB Cable Adapter
    • 2*Spare O-rings
    • 1*Lanyard
    • 1*Holster
  • MSRP: ~$90
UI (User Interface)
UI for this light is suitable for a Bug-Out Bag (BOB) or walking/hiking light as it is relatively straightforward to use.
Switching ON and OFF is done by the side electronic switch on the light, so no momentary activation is possible.
From OFF:
  • 1 Click  - Main LED will switch ON to last brightness level used (last mode memory).
  • 2 Click - Direct access to TURBO.; 2 Click again for SOS or 1 Click to switch OFF [Side/Tail Switch].
  • 3 Click - Direct access to STROBE; HOLD (~1 sec) for SOS or 1 Click to switch OFF.
  • HOLD (~1 sec) - Side LED will switch ON to last brightness level used (last mode memory).
  • HOLD (~3 sec till Side LED is OFF) - LOCATION mode is activated - red indicator light on side switch will start flashing; 1 Click - LOCATION mode is deactivated.
  • HOLD (till Side LED flashes 2 times) - LOCKOUT mode is enabled; HOLD (till Main LED switched on LOW mode) - LOCKOUT is disabled.
From ON (Main LED):
  • 1 Click - Light will switch OFF.
  • HOLD - Mode change - light cycles through LOW, MID & HIGH only.
From ON (Side LED):
  • 2 Click - Direct access to TURBO (Main LED).
  • 3 Click - Direct access to STROBE (Main LED); HOLD (~1 sec) for SOS or 1 Click to switch OFF.
Note:
  • Battery Capacity Indicator - Side Switch will glow (~2 sec) one of the following colors after screwing tight the tail cap (after battery change/charge or deactivating mechanical lockout)
    • Green (>40% battery capacity)
    • Red (<40% battery capacity)
Form Factor
For flashlights that are intended to use for a BOB or walking/hiking usages and for possibly an extended period of time, form factor is extremely important.
This light feels extremely well balanced in a medium sized hand (not head/tail-heavy). Switching between overhand and underhand holding method is easy with its form factor. The knurling on the light and smooth curvature of the head (one piece head and body) enables the light to fit one's hand almost perfectly and still be sufficiently "grippy", even with wet hands/gloves.
The Side LED does not protrude from the flashlight body and the material (Polycarbonate?) used feels well-built.
It fitting in the holster snugly as well as being able to tail-stand perfectly (even with the lanyard attached) without the slightest wobble is very much desired.
Charging Process
With the provided Rofis nylon braided-style Micro-USB Cable, the battery was charging at ~1.9A which is relatively close to the stated 2.0A charging rate.
The light is capable of operating on the Side LED's MID mode only, even when charging (at the expense of a slower charging rate).
The RED indicator depicts charging in progress and GREEN indicator depicts charging has completed.
Discharging - Power Bank Function
This is probably one of the key specialty of this flashlight - the ability to use it as a backup Power Bank with the provided Micro-USB to USB Cable Adapter.
The flashlight is said to be able to discharge at a max of 2.2A. However, we received mixed results when trying to charge an Apple iPhone 6S, Samsung S9+ and Apple iPad PRO 9.7in.
All of which had varying discharge amperes to the devices.
  • The Samsung S9+ which is capable of charging at ~1.5A (at its current battery capacity of 87%), was supplied with a charging rate of ~0.88A.
  • The Apple iPhone 6S had a charging rate of ~0.81A.
  • Interestingly, the Apple iPad PRO which is capable of charging at ~2.1A rate, refused to charge with the flashlight available discharge output. This is could be due to the flashlight being unable to provide a constant 5V output (Apple products have been known to be slightly fussier when it comes to charging requirements).
Note:
  • Battery Discharging Capacity Indicator - Side Switch Indicator Light will flash the following to indicate remaining battery capacity
    • 4 Green Flashes (>80% battery capacity)
    • 3 Green Flashes (50% - 80% battery capacity)
    • 2 Green Flashes (20% - 49% battery capacity)
    • 1 Green Flash (<20% battery capacity)
    • When battery capacity is <5%, discharging will stop
Beam Style/Beamshots
For the beam profile of the Main LED, the spill, corona and hotspot is somewhat predictable due to the fairly deep Orange Peel Reflector. Hence even with the larger sized LED used, the beam is still sufficiently “throwy” for recognising items in the near to mid-range distance. There is even a green GITD O-ring situated between the lens and reflector.
This light’s Side LED is covered by an opaque diffuser-style lens which provide a soft and artifact-free beam profile for up-close to near range distance usage.
The above beam profiles are a rough interpretation of what is seen when white wall hunting.
The Main LED has a fairly large hotspot with a ring of corona and a rather wide usable (almost circular) spill. It also helps that the XHP70.2 led is perfectly centred in this sample. There is a slight ring in the main beam when whitewall hunting but is not visible in real world usage.
The Side LED has a wide and even flood-type style with an almost 180 degree beam angle. There is no rings or beam artifacts when whitewall hunting.
All of the beamshots taken below are done so with the following camera settings ([For Main LED] LOW: 0.5, F3.5, ISO100, 5000K WB, MID: 1/4, F3.5, ISO100, 5000K WB, HIGH: 1/6, F3.5, ISO100, 5000K WB & TURBO: 1/10, F3.5, ISO100, 5000K WB) and ([For Side LED] LOW: 2, F3.5, ISO100, 5000K WB, MID & HIGH: 1/2, F3.5, ISO100, 5000K WB).
Some pictures have been adjusted slightly to depict as close as to what is seen in real life. The distance of the light from the door is 4.6m.
Main LED (XHP70.2)
Control shot:
LOW (30 lumens):
MID (450 lumens):
HIGH (1500 lumens):
TURBO (3500 lumens):
Side LED (XP-G2)
Control shot:
LOW (3 lumens):
MID (60 lumens):
HIGH (200 lumens):
Mode (Output) Spacing
Mode spacing appears to be progressively brighter to the eye and the modes are well spaced enough to be able to know which mode one is currently in. With that in mind, TLR tend to view mode spacing as battery life indicators (amount of runtime left) rather than the specific output (lumens).
It would be nice if Rofis would incorporate a MOONLIGHT mode for those bedtime runs or during which having 3 diffused lumens (Side LED) is still a tad too bright for the night-adjusted eyes. This is truly nitpicking here - as for most cases the available modes and spacing are perfect for almost every activity. That said, being able to activate both Main and Side LEDs would make the Rofis the perfect walking/trekking flashlight (being able to light up both one's footpath and the distance ahead).
Tint & CRI
Rofis did not disclose the tint (color temperature) and/or the CRI (Color Rendering Index) for the LEDs used in their light. For this light, a guesstimate would be in the 6000K and 70CRI ballpark for the Main LED & 4000K and 80CRI ballpark for the Side LED.
For the Main LED, there are tint shifts throughout the beam profile. The hotspot is cool white whilst the corona possess a slight yellow-green tint; and the spill having a slight purple tint. This is however, not as noticeable in real life.
For the Side LED, there is no tint shift in the beam profile and it has an even yellowish tint throughout.
Waterproofness
The light was subjected to warm water submersion, followed by cold water submersion and left under room temperature running water tap whilst running on TURBO (Main LED) & HIGH (Side LED) separately.
No signs of water intrusion in the head, switch or body was seen.
Lockout Capability
Both mechanical lockout and electronic lockout are possible when needed, like during transportation in a bag.
See above "UI (User Interface)", on how to activate and deactivate electronic LOCKOUT.
When LOCKOUT mode is activated, any button presses will cause the red LED on the Side Switch button to flash once for ~0.5 sec.
A quarter turn (anti-clockwise) of the tailcap will enable mechanical LOCKOUT.
Note: If electronic LOCKOUT is enabled followed by enabling mechanical LOCKOUT, the electronic LOCKOUT will still remain enabled even after the mechanical LOCKOUT has been disabled.
Scale Comparison (Ruler)
Summary
To sum up, we believe that the most important part of any review is if given the chance to purchase the same light for our own EDC or to gift to our loved ones out from one's pocket (wallet), would we still do it?
For this light, it is a definite YES if the tint shift is not an issue for your usage.
Rofis may have had created an almost perfect home run flashlight with excellent charging rate (amps), power bank capability, dual LEDs for up-close to mid-range distances and all at a rather wallet-friendly price point. Rofis is not the first manufacturer who thought of this style of dual LEDs setup but they certainly did an excellent job with an almost straightforward  UI interface (after the initial learning curve).
However, as mentioned earlier, we look forward to the day that Rofis is able to incorporate a way to enable activating both Main and Side LEDs at the same time -  that would make it THE perfect walking/trekking flashlight among other numerous uses.
Here is a bonus size comparison picture next to some of the other 26650 flashlights we reviewed previously - the Eagle Eye X7R and Klarus G20L.
As with all gears, two is one and one is none.
Stay safe,
The Lite Review
Disclaimer: Light was provided for by Banggood for this review. No other compensation was provided.
Where to Buy Links
Click HERE to check out where to get this light at a great discount!.
The Lite Review (click for my Review website!)
Edited by: mcorp on 04/25/2018 - 21:57
KevinZA1988
KevinZA1988's picture
Last seen: 2 days 13 hours ago
Great review, definitely getting one! One question though. Is it possible to swap the emitter pcb? I might want a NW Xhp70.2… Thanks!
Acebeam L18, Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Olight Baton 3, Olight Warrior Mini, Olight M2R Pro Warrior.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
mcorp
Thanks for the compliment!
Unfortunately mods (even simple LED swaps), aren’t on our handy skill list. However, it does appear like the SS bezel is held in place by threadlock(?) and should give you access to the MCPCB for the LED swap.
-X3-
-X3-'s picture
Last seen: 9 hours 55 min ago
That UI is really great ! Olight great to be more precise Big Smile
Also, this seems to be really compact, and I love the idea of the side flood LED Smile
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
weklund
weklund's picture
Last seen: 6 hours 42 sec ago
I purchased two of these awesome lights. I am very pleased. Excellent build quality. The side light is very useful and cranks out plenty of warm lumens to light your way and can be used while charging via USB for continuous area light. The MR70 has quickly become my favorite bedside and walk the dog companion.
Highly recommended.
... Happy Landings ...
mcorp
X3 wrote:
That UI is really great ! Olight great to be more precise Big Smile Also, this seems to be really compact, and I love the idea of the side flood LED Smile
Rofis definitely got the UI right for the MR70! The side LED proved its usefulness on more occasions than we care to admit – brilliant idea. Thumbs Up
Highly recommended.
!https://s19.postimg.cc/pr41yzlfn/M702.jpg!
Yep same here – it is almost permanently regulated to nightstand duty! Those warm tint lumens are great for night and just-before-bed usage; and has a calming effect after a long hectic day at work.
Not that it is needed but it would be nice to have the option of a strong (removable) magnet in the tailcap too.
JasonWW
JasonWW's picture
Last seen: 50 min 17 sec ago
Has anyone tested the amp draw at the tail cap?
F22shift
F22shift's picture
Last seen: 2 months 1 day ago
This is one my better flashlight purchases in recent years. The quality seems great and there is a lot of useful features.
If I have to complain about the UI , you can double click to access turbo but another double just access turbo again. So you need to do a slow double click which is essentially an off and on to get back to the previous mode. So they could program to toggle turbo on and off with a fast double click. Not a deal breaker but something to improve.
The battery level when screwing in the tailcap is almost useless. Green when above 40 percent and red when under. There is a substantial runtime difference between 50 percent and 100 percent battery charge. So useless especially considering that the mobile charge features blinks at the battery capacity. So better if they have it blink 4 times for full and 2 times for half etc. that’s better info to the user.
What else? Really hard to find a fault and it deserves all the praise on the reviews.
Would I recommend ? Yes
After dealing with a faulty MR70 , Rofis is gonna help me out. So it’s nice to know they stand behind their product.
I wish they would offer a NW emitter.
JasonWW
JasonWW's picture
Now they are coming out with a smaller version using a 21700 battery and a xhp50.2. It’s called the MR50.
