[Review] Amutorch X9
59 posts / 0 new
Tom E
Tom E's picture
Last seen: 8 hours 44 min ago
vresto wrote:
any idea how to make this nice flashlight more bright? which leds should fit without driver change? /dont want to loose usb port/...
Well, I modded my X9 to XHP50.2's, gets ~10K lumens, but I piggybacked in a driver. Looks like the stock driver is FET based, so you could just swap the LED's to XHP50.2's, assuming/hoping it can take higher amps, stock is ~15 amps, XHP50.2's in my custom driver setup hits 30 amps at max.
I don't see any other option for LED's to get more output, and the good thing is the stock driver is already FET based. But again, you always throw the dice when bumping up amps. I'm guessing it should work ok, because 15 amps is already a big #.
vresto
vresto's picture
Last seen: 2 hours 10 min ago
this sounds very good….:) you wrote to me…is there any pizza xhp50 neutral source? i guess you got them separatly…
EDC-Mateminco mt04 xhp50 nw,Sofirn If-25a Lh351d
Headlamp-Thrunite th30 nw
Tom E
Tom E's picture
Dunno - KD has them in 6500K and 6000K, both CW, same with MtnE. Should be 5000K or lower to be NW. I haven't checked Mouser or Arrow in a long time.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 9 hours 46 min ago
Tom E wrote:
Dunno – KD has them in 6500K and 6000K, both CW, same with MtnE. Should be 5000K or lower to be NW. I haven’t checked Mouser or Arrow in a long time.
What battery are you using? I wonder if my old blue Littokala cells will even hit 30amps.
Tom E
Tom E's picture
LK's won't, GOLISI 26650 though did for me.
vresto
vresto's picture
any idea where is this flashlight available please? with typical usb ,not magnetic…
Tom E
Tom E's picture
vresto wrote:
any idea where is this flashlight available please? with typical usb ,not magnetic...
Well the old model had USB charging, new model is magnetic. I got one of each but both had the charging removed because of piggybacking in a replacement driver.
Neal lists the old model here: https://www.nealsgadgets.com/collections/amutorch/products/amutorch-x9
but I'd check with him first if it's really USB charging.
BG lists the USB charging model here: https://www.banggood.com/Titanium-Black-AMUTORCH-X9-SST40-XP-L-HD-3600lm-High-Lumen-Flashlight-USB-Rechargeable-26650-Flashlight-Portable-4-Modes-USB-Charging-Work-Lamp-Camping-Hunting-Emergency-Lantern-p-1463001.html?ID=2246143494&cur_warehouse=CN
BG I'd trust less to ship a USB charging version.
vresto
vresto's picture
One month back order.. As many other models..and from neal never again rather…
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 1 hour 57 min ago
Do you want my red X9 with xml2 nw?
vresto
vresto's picture
Where you from? Hm.. I wanted reflow it with xhp. Not sure if is there space for it..
Chatika vas Paus
Poland.
What xhp? 50.2? X3 has already done it
vresto
vresto's picture
yes yes…..xhp 50..but neutral white.sure not cool white.and i cant found them sadly..as a tripple.but for this you need bigger reflectors …so maybe the xml version can fit.. cos there are bigger reflectors than xpl version…:)
Tom E
Tom E's picture
I already did it too. I got a triple XHP50.2 3v and now have a triple XPL HI V4 3C. The XHP50 triple was done before I got into Anduril, so it's NarsilM v1.3, while the XPL HI just finished the other night so it's got my latest Anduril.
I piggybacked in a 20 mm 0.8 mm thick FET+1 driver by DEL, OSHPark for both of them, wiring up the blue and read switch LED's so comes out look'n purple-ish. Not that I like Amutorch's:
vresto
vresto's picture
yes we know we know…but its sold out or what….and you inspired me to make it xhp triple…with stock driver to save usb port.i dont want flashlight without usb anymore..
Chatika vas Paus
Tom E is there enough space inside to add a driver and keep components from the original pcb so as not to lose charging?
Tom E
Tom E's picture
Not really sure - it's tight, but no where near as tight as the AX4, but fortunately with the AX4, I had a driver with a mounted switch that fit, with some tweaking. The X9 has the LED resistors on the driver. I left the resistors in place and wired them up to I/O pins #3 and #7 separately to the red and blue. Right now Anduril supports an AUX1 and AUX2 LED, but unfortunately doesn't take advantage of using them separately.
I've found for batteries, it's a tight fit as well. The problem could be my spring bypasses though - might have reduced spring height just enough to cause problems. Flat top LK style batts fit good, but the ones with a protruding top are a tight squeeze. I marked up the batt- end of a new EFEST 4200 pretty good.
Btw, those type of switches are prone to failure - they get bend back over time, sometimes just making it harder to activate, other times can break the contact, or bent back far enough to not work. Can't tell from the pic, but I have a clear epoxy backing that switch to support it better -- highly recommended even for the stock driver/setup.
vresto
vresto's picture
from where you got the tripple xhp board please? iam looking for neutral white colour….
Tom E
Tom E's picture
vresto wrote:
from where you got the tripple xhp board please? iam looking for neutral white colour....
Used the stock one. I bought an X9 with XPL HD LED's. Not sure where but BG has it listed, and might have been BG.
vresto
vresto's picture
I know but you replaced xpls with xhp..
Tom E
Tom E's picture
XHP? K, I'm confused. You mean the XHP50.2 3V I guess. That's an XM size - for that one, I replaced SST-40's with XHP50.2 3V's.
XHP doesn't work - could be XHP50 or XHP70 - it's not a unique size.
vresto
vresto's picture
yes yes…so…so is there any source for this xhp50? in neutral colour..
Chatika vas Paus
Here is a post with your mod with xhp50.2 3V
If there is enough space, maybe it would be possible to not remove the components on the main pcb and put the TA driver.
Or remove some of the elements. Looking at this board, the charging part (green) is clearly separated from the control part. If I see correctly, they are probably connected only by three traces.
Chatika vas Paus
Sofirn has 5000k, but as I asked Barry, he said it is in the 5000K-5700K range
vresto
vresto's picture
thats great…i wanted it on board as a tripple,but this is also good…
Tom E
Tom E's picture
I'm not familiar for a source of NW XHP50.2 3V's - if you find one, let me know!
For saving the charging, it might be possible but I'd hate to tell someone it's do-able, buy the light and parts, and find out it's not. I don't have an original populated driver to know for sure what the clearance. is. I can tell you there's some decent amount of clearance over the piggybacks I have now in the 2 lights. You usually need some space to manage the wires though. I've done tighter piggybacks before - sometimes I've had no clearance for wires, so need to drill holes for the wires so they won't lay across the driver.
I pretty much only use 0.8 mm OSHPark drivers now for piggybacks.
vresto
vresto's picture
Which cell is better for this model? Shockli or litokalla? Or keeppower?
Tom E
Tom E's picture
I'd go with a Shockli 5500 or equivalent. KeepPower 5200 or LK, or equivalents are also good. You tweak a bit more amps out of a GOLISI or equivalent, but not worth it really.
I'd stay away from protected cells though - they probably won't fit.
vresto
vresto's picture
Iam still looking for this model with usb port if anyone sells…thanks
