New Sofirn SP33 V3 !!
260 posts / 0 new
SKV89
Last seen: 1 day 22 hours ago
pennzy wrote:
JasonWW wrote:
pennzy wrote:
My SP33v2 loses turbo at a little above 4 volts. At what voltage do you lose turbo?
I lose mine at 3.70 volts. Dirty connections can have an effect. Boost drivers need as much voltage as possible so you want to make sure the circuits are clean with no extra resistance.
Done all that Jason. Only thing left I haven’t tried are spring bypasses. My driver just seems to lose turbo early. Wondering if I am the only one.
Although you might already tried it. I’ve had so many lights that loses turbo shortly or immediately and it is fixed after washing the tube and head with detergent and cleaning the head spring or contact with rubbing alcohol. I’ve had many lights including Thrunites that had black grime on contacts that require much rubbing with finger nail to remove. Fixes turbo problems and low output almost every time.
longuylander
longuylander's picture
Last seen: 10 hours 8 min ago
So, the big question is, is the V3 at $30 a better light than the V2 at $20? Even if money wasn’t part of the equation, is the V3 really better than the V2?
SKV89
Depends on how much you value max output and USB-C recharge. For me USB-C recharge is important in a muggle friendly light like this. However, I much prefer the V2 boost driver for its excellent regulation and efficiency making it more suitable as a tool. I wish Sofirn makes a USB-C version of the V2.
longuylander
Your logic convinced me to order the V2. While the max output is better on the V3, it doesn’t seem to live up to its numbers (as stated here), making the difference to the V2 not as dramatic. USB charging isn’t all that important for me, but steady and constant output is. I just ordered the V2 on Sofirn’s site with battery and charger for $20.70.
whatsthepoint
whatsthepoint's picture
Last seen: 2 years 6 months ago
Unlike the SP33v2 that uses glue,the SP33v3 has an aluminum locking ring that turns counterclockwise.
I have not removed out the driver.
The bezel unscrews quite easily to remove the 2 x O rings,lens and OP reflector exposing the LED / MCPCB.
The spring on the bottom of the driver was a bit tilted that was put aright with needle nose.
This light could probably use some better springs.
never underestimate the power of stupid people in large groups
Th558
Th558's picture
Last seen: 1 hour 4 min ago
Received mine today. I love it so much…It makes the tint on my EC01 look good Big Smile The bezel, reflector, beam pattern and charging port cover are identical to the EC01 but the tint is cooler and a bit greener…Seems like sofirn also make the EC01. Why didn’t they just stick with the same LED as the EC01 5000k? The only good think about the cool LED is the slightly less noticeable tint shift. The design and build quality is nice but I dont like the fact it has a FET driver whereas the older version was constant current. I definitely would have preferred anduril with 5× 7135 and a warmer tint. Might end up selling it. Not sure though. It’s for my family so they probably won’t mind the tint. Oh yh and one last thing. The LED indicator seems almost useless. It stays off when the light off and comes on for a few seconds when you turn the light..I guess its just there to serve as a low battery warning and charging indicator. They should’ve just made it stay on so you can find it in the dark…I know I’ve said a lot of negative things about it but it’s still a good light. Just not what I’m looking for.
Sofirn..if you’re reading this could you make a V4 with a better tint, regulated modes up to 1000lm and a way to permanently disable turbo. Like maybe 5 short clicks and one long. Something that someone can’t do by accident. If you do the above this could be the perfect muggle light.
phouton
Last seen: 18 hours 3 min ago
My quick impressions of the SP33v3 after spending some time with it. One note, I ordered with the 26650 battery but it did not come with a battery.
Pros:
  • Build quality. It feels solid and looks good. The machining and anodizing are very pleasing.
  • UI. It’s simple and intuitive. I really like it a lot. The moonlight and turbo (and strobe..) modes being hidden as well as instantly accessible from off make it very versatile. Good usable mode spacing too for the stepped mode. Plus of course there is ramping mode.
Cons:
  • Beam colors. My first reaction turning it on for the first time: “Wow, that’s ugly!” It has a hotspot that is white enough, but there is a VERY noticeable green/yellow ring around it, which then turns to a noticeably blue spill. At close range it is very distracting because the same object will look multicolored! Truly the worst part of this light. The colors are so bad, I don’t even notice color temperature, CRI, or any other typical concern. At larger distances or for general lighting, it is ok… ish.
  • The switch is difficult to find in the dark or by feel. It always takes me time to find it, and the easiest way is to feel for the bump of the charging port and know that the switch is 180 degrees away.
Overall, I think it’s a great flashlight and it has a ton of brightness. I’ve been using it with only 18650 batteries that are not high drain, so I imagine it is capable of even more brightness than what I’ve seen. Very abundant on that front.
A minor note is that the cuts for the “fins” of the heatsink are slightly sharp, unlike the smoothness of all other edges. Not a huge deal, but I do notice it and wish they were deburred slightly better.
Generally, the SP33 feels really good in the hand. The 26650 tube is a nice size and every time I hold it, I feel happy about the construction quality.
The USB charging is a feature I appreciate a lot as well. I don’t know what the charge current is but by comparing with the SP40 which is known to charge at ~1A, I’d say the SP33v3 charges at a higher current since it is a bit faster. That also means it seems to charge the same batteries slightly less than the SP40’s built-in charger.
With it plugged in to a charger, there is a 1.8 mA parasitic drain. That goes down to ~26-28 uA with the cable unplugged.
JasonWW
JasonWW's picture
Last seen: 1 day 16 hours ago
Welcome to the world of the Cree XHP50.2 and XHP70.2. The older 50 and 70 had a much nicer looking beam with no yellow corona, but they also tend to produce a donut hole beam pattern (OP reflectors needed) and the max output was lower. I will say you tend to get used to the corona over time. Maybe we will get better leds in the future.
I think the very new Luminus SST-70 might make a good replacement for the 6v 50.2. Hopefully we can buy them soon. It should make a nice replacement for the version 2 light. I dont know of a good led for this version 3 since it’s 3v.
phouton
Um, thanks… I don’t know if I’ll get used to the corona. It’s especially noticeable when the beam is not static. The yellow ring gives everything a pee-stained look, especially light-colored surfaces like snow! Sick
In contrast, the 5000K XP-L in the SP-40 also doesn’t have what I would consider a pleasant color due a greenish hotspot with blueish spill, but at least that is more homogeneous without a corona, making it less hideous and more tolerable.
Does that make me a tint snob??
To be clear I still think the SP33v3 is a fantastic flashlight. I don’t go easy on criticism.
JasonWW
JasonWW's picture
No, it just means you can see. Big Smile No one likes the yellow corona of the 50.2, 70.2, XP-G3 and XP-L2. These use Crees new flip chip design which has phosphor all the way across the top of the chip. Here is a comparison of old vs new.
The performance is good, but something about the design, maybe phosphor on the sides of the led, creates the yellow corona.
Tint snobs can be really picky always swapping new leds in all their lights looking for just the perfect tint.
There can be a lot of variety in the tint of any led and it also changes based on brightness. If you see green in the hot spot it may be a sign that it’s above the BBL. I dont know what model xpl Sofirn uses for the SP40, but you can certainly swap it for a different one. Most folks prefer tints below the BBL because they are closer to red than green and that’s more pleasing to most people.
whatsthepoint
Using a U2 USB C power meter the SP33v3 charged at 5.03v / 1.3A using premium thunderbolt 3 certified 18" C cable from the meter to the USB 3.0 port on the SP33v3.A high end A to C cable was used from a recently made custom build gaming desktop PC USB 3 gen2 port to the U2 meter..The very new ShockLi 26650 5500mAh cell inside the SP33v3 was at 3.6v when the USB C port charging began.When charging completed the flashing red power button turned blue.
An SP40 using a U2 USB power meters but using an A to micro USB cable from the meter to the SP40 charged at 4.97v / 0.898A.The new Panasonic NCR18650G in the SP40 was at 3.75V when charging began.When charging completed the flashing red power button turned green.
I did not time the charging.
phouton
I wonder, are those LEDs expected to be used with specific optics? I don’t see how any professional application could tolerate those inconsistent colors.
Maybe I “spoiled” my eyes by the order in which I viewed LEDs. My first “fancy-pants” flashlight was the C01S with the 4000K CRI95 SST-20 and TIR. It blew me away by how nice it looks, even though I did notice the slight greenness at low brightness. Then I got the i3E (Luxeon TX + TIR) and i1R 2 (unnamed LED + TIR) which looked worse in comparison. Then came the SP40 (XP-L + OP reflector) and SP33v3 (XHP50.2 + OP reflector) and suddenly the previous two looked like beauty queens.
I wonder if the big difference is TIR vs OP reflector, with the former presumably mixing any colors to produce a homogeneous beam that is invariably more pleasant and less distracting than bands of colors.
As a side note: the human eye and brain are strange. What looks good one moment can look terrible depending on the contrast with something else. 4000K SST-20 looks yellow compared to cold CCT lights, but then looks crisp white compared to incandescent bulbs. My brain gets so confused!
whatsthepoint wrote:
Using a U2 USB C power meter the SP33v3 charged at 5.03v / 1.3A using premium thunderbolt 3 certified 18” C cable from the meter to the USB 3.0 port on the SP33v3.A high end A to C cable was used from a recently made custom build gaming desktop PC USB 3 gen2 port to the U2 meter..The very new ShockLi 26650 5500mAh cell inside the SP33v3 was at 3.6v when the USB C port charging began.When charging completed the flashing red power button turned blue.
Thanks for these measurements! What are the final voltages of the cells after charging has ended?
Ryzbor
Ryzbor's picture
Last seen: 1 day 6 hours ago
Can the led be swapped to the SST-40 NW?
JasonWW
JasonWW's picture
Keep in mind these leds were not made for flashlights, they are made for things such as street lights. We just use them for other things.
Optics do make a big difference.
Our eyes/brain automatically adjust white balance.
JasonWW
JasonWW's picture
Yes. The FT03 is offered in both SST-40 and 3v 50.2 and they use the same mcpcb. Just a matter of reflowing the led. Same package size so the reflector and centering ring are all the same. Keep in mind that output is a lot less, maybe 1800-1900lm at most due to smaller die size (2mm square and 3mm square)
Th558
Th558's picture
Just did some testing with the SP33 v3 and EC01. Set both to about 190 on my lux meter (max stepped mode for the sofirn). My FT03 with a fully charged shockli measures 387 so 190lux is somewhere close to 1000 lumens. Both lights were at 26°C at the start of the test (room 22.5°C).
Beginning of test: about 190lux.
SP33:
13 mins (46°C head) step down to around 70-80 lux
Once it cools down a bit it starts stepping up again. The temperature management doesn’t let it become too hot to hold. I’m sure it could run near 1000 lumens without stepping down if the temp was set higher. Yesterday I tested it whilst holding it (170-180lux 900ish lumens) and it didn’t step down after 30+ mins.
EC01: temp set to 65°C
13 mins 57°C negligible drop in output, body too hot to hold
18 mins 153lux
22 mins 118lux
At the end of the test the cell was 50°C, body was about the same and the head was 59°C max.
It seems like the longer head and cooler (slightly more efficient) LED helps the SP33 dissipate heat better.
phouton
Cree lists portable lighting as one of the applications: https://www.cree.com/led-components/products/xlamp-leds-arrays/xlamp-xhp...
https://www.cree.com/led-components/applications/portable-lighting
What optics might help? Has anyone used them with TIR lenses?
Maybe a diffuser film or lens would be an easy fix. As a proof of concept, shining the light through two layers of clear bubble wrap (just because I had some nearby) shows dramatic improvement: the corona is almost totally gone, and the spill is less blue. Everything looks closer to “white”.
Nice. Based on that I prefer the SP33v3’s behavior. Where did you measure temperature?
Your observations match my own with a thermocouple held on the head by the rubber charging port cover’s flap (not under the cover, just the pull tab).
On Turbo, it stayed in the low to mid 40s C range. The brightness did ramp down and up noticeably, but the changes were made sufficiently smoothly not to be annoying.
However I was not using a high drain battery.
whatsthepoint
[/quote] Thanks for these measurements! What are the final voltages of the cells after charging has ended?[/quote]
The ShockLi 26650 5500mAh in the SP33v3 was 4.15v and the Panasonic NCR18650G 3600mAh in the SP40 was 4.13v
The 26650 ShockLi charges to 4.20v and the 186650 Panasonic charges to 4.19v in my Xtar VC4
Th558
Th558's picture
Temp was measured using a cheap infrared thermometer at the head wherever I could find the hottest spot. Tested it tailstanding indoors at max stepped setting which is about 1000 lumens with a shockli 5500. This drops as the cell voltage declines but it doesn’t seem to drop as much as the EC01. Could be cause the battery has more capacity. The EC01 will also ramp up once it cools down. This would’ve happened if I left it for longer or set the temp lower. I tested it before with temp set a bit lower at 60°C and it stablised at around 90-105lux which should be about 500 lumens. This doesn’t make sense to me cause my MH20GT could do that whilst being smaller and having a less efficient LED. Maybe it’s more than 500. I highly doubt it though cause I’m assuming the FT03 is 2000 when it’s probably a bit less..so it might actually be less than 500..makes even less sense.
JasonWW
JasonWW's picture
If I understand you correctly, your directly associating lux with lumens? These are completely different measurements. Are you integrating all the light? You have me quite confused.
JasonWW
JasonWW's picture
A TIR lens or OP reflector. Anything that helps blend the corona into the main hot spot. Diffuser films works, but you loose efficiency.
phouton
Thanks. Those voltages are right in line with what I observed too. Maybe also try the same 18650 cell in the SP33v3 for one less variable, but I’m guessing the result will be similar.
Well it already has an OP reflector. Perhaps it needed stronger OP. Blending the corona and reducing the blueness of the spill make it much much nicer.
On a side note, I’m finding I’m not the biggest fan of strong hotspots. Blended, homogeneous, wide beam profiles seem more pleasant and useful to me, certainly for shorter distances. Also, hotspots seem to give a tunnel vision effect, even (especially?) after turning off the flashlight.
80T
80T's picture
Astrolux EC01 has an ever so slightly slightly stronger OP reflector than the SP33 V3.0 (identical reflector and glass, o-rings and SS bezel) just enough that you can see it in the beam pattern (bit smoother - actually the reason I've noticed it in the first place)
For high tint shift emitters like the XHP 50/70, XP-L2, XP-G3, etc. a narrower reflector with the smallest emitter hole as possible helps much more than an OP texture (and gives a cleaner, sharper beam) - the lower the angle between the base of the reflector and the emitter, the less tint shift - the higher the angle, the stronger the tint shifting in the corona.
phouton
Thanks for the tip 80T. Any beamshot comparison of the two?
If a drop-in reflector replacement would fix the beam, that would be very nice and convenient.
80T
80T's picture
No, I don't have a beamshot comparison, as I don't have a good way of taking such pictures. The difference is marginal and the tint between the two would be much more noticeable than the beam pattern itself. Being the same geometry reflectors, the tint shifting is also the same, just a little bit smoother beam on the EC01, but actually looking worse because of the overall cooler tint vs my SP33, thus more tint shifting into green.
JasonWW
JasonWW's picture
I only have the version 2, but the reflector on it is just barely OP. It’s almost SMO if you look at it closely and look at how sharp the hot spot is. If they made it more OP it would definitely help the appearance.
whatsthepoint
[/quote] Thanks. Those voltages are right in line with what I observed too. Maybe also try the same 18650 cell in the SP33v3 for one less variable, but I'm guessing the result will be similar. [quote=JasonWW]
    I repeated the SP33v3 USB C charging tests this time using the Sofirn branded 26650 5500mAh battery that shipped with the flashlight plus the Sofirn 18650 3000mAh that shipped inside the SP40.
With nothing attached to the USB C cable the USB 3.0 port in my desktop PC puts out 5.08v monitored on a U2 USB power meter.
When the USB C cable is inserted into the USB C port on the SP33v3 the volts drop to 4.73v and the charging amps is 1.58A.The test began with the battery testing at 3.65v
About half way through the charging the displayed volts starts creeping upward while the displayed amps starts creeping lower.
The charging ends with the volts back at 5.08v and the last displayed amps was 0.278A.The battery tests at 4.15v at the end of charging where the power button displays blue.
    The next test is with the Sofirn 3000mAh 18650 in the SP33v3 inside the plastic sleeve.Again as with the Sofirn 26650 5500mAh battery the displayed 5.08v dropped to 4.73v when the USB C cable was inserted in the SP33v3 USB C port and the charging started at 1.578A.The battery tested at 3.65v when charging began.
About half way through the charging the volts stated rising and the amps dropping.
When charging completed with the power button blue light displaying volts were back at 5.08v and the last displayed charging amps was 0.267A.The battery tested at 4.14v
Both batteries were then placed in an Xtar VC4 charger until red charging lights turned to green.
The Sofirn 5500mAh 26650 added 185mAh and tested at 4.20v
The Sofirn 3000mAh 18650 added 118mAh and tested at 4.19v
Hope this helps!
hank
hank's picture
Last seen: 1 month 3 days ago
Quote:
I have a lot to learn about this flashlight before I place it in my SUV.The size is good for the center console.
Don’t keep li-ion flashlights in hot boxes, it’s not good for them.
whatsthepoint
Never gets hot in Texaswink
If I leave the car in the sun it's only for a short time to flow LEDs onto MCPCBs on the hoodsealed
phouton
whatsthepoint So the results are consistent. Final voltage around 4.14-4.15V. How soon did you measure voltage after charging ended?
