21700 battery tray recommendations
5 posts / 0 new
bcm00re
Last seen: 1 month 4 days ago
I am looking for a dual battery tray for unprotected 21700 batteries. So far I have found a couple options:
A) nylon injection molded
B) 3D printed using PLA+ (according to message from the seller)
From what I have read, it sounds like there are pros and cons for each material (and no clear cut winner). Any insight would be appreciated. Thanks…
Edited by: bcm00re on 03/17/2020 - 23:26
Joshk
Joshk's picture
Last seen: 1 week 25 min ago
For what use? How many you need?
bcm00re
Sorry, I meant to mention that. I am going to use two cells to run an old Eureka cordless stick vacuum. It pulls around 5.4A but on startup its a bit more. I only need one tray, but I was going to buy two. These are the cells I plan to use. If this works well, then I might use four cells in an old Roomba (that formerly used 14.4V NiMH batteries). BTW, I do plan to install protection PCBs. I see some options on eBay — but I am very open to recommendations and/or experiences (from items there or elsewhere).
Joshk
Joshk's picture
So $9 to build with nylon injection molded and $7 to build with PLA+ 3D printed. Just go for the pretty injection molded one. Either works. If you were needing hundreds of them, the $2 would add up, but not in this case.
bcm00re
That is the way I was leaning. Thanks for the input.
