Fire-Foxes HID Flashlight FF5 100W 10000Lumen ALiExpress store
36 posts / 0 new
stone20003@163.com
stone20003@163.com's picture
hello,FF5 has been on the market, the first batch of users to buy lens cover, hand rope, sealing ring.
Global Express store:https://es.aliexpress.com/item/4001256219250.html?spm=a219c.12010612.814...
FF5 Brief Description
1 Product Description
Ff5-100w hid, ignition for 100 watt lamp, 120 watt battery input power, is the current limit value of portable HID flashlight. The 100 watt luminous flux is 10000 lumens, and the measured and calculated light intensity value is 1 million CD,
2 Design
FF5 is a high and low gear design, with 100W high grade and 40W low grade. It can be changed by pressing the side switch. There is a temperature control system inside. Once the temperature control takes effect, it will automatically jump and lock at 40W;
3. Design of heat insulation ring for flashlight
FF5
It is a 100W high power flashlight. In order to ensure user comfort, this feature is added at the expense of flashlight length. The handle can isolate 20-30 ℃ from the lamp head. For a long time, the temperature in the handle only comes from heating the battery.
4. About the color temperature of the flashlight
The default value for The Flashlight is 4300k.
FF5-Battery rack version
I basic parameters
High light source flux: About 10,000 lumens
Low: 4000 lumens
Illumination Distance (ANSI) 2000M
Size Length x handle diameter x head diameter: 200×49×95mm
Approximate weight 790g (without battery)
High output power: 100W low: 42W
42w thermal protection when thermal protection is activated
Power battery rack, user can change batteries, short circuit, reverse polarity, over discharge protection
FIRE-FOXES FLASHLIGHT this is my shop on Aliexpress:https://es.aliexpress.com/item/4001256219250.html?spm=a219c.12010612.814...
SKV89
Last seen: 12 hours 13 min ago
You created two threads, you should delete one. This light is amazing. The performance is at least 5 years ahead of LED lights. Tint is excellent. I will likely be getting one soon pending user reviews.
stone20003@163.com
The network was not good yesterday. I submitted it repeatedly Big Smile
tatasal
Last seen: 2 hours 10 min ago
I owned 2 FF4s before and while it’s officially rated at 4300k, cameras cannot do justice to its glorious tint when brought outdoors. You have to see it on hand and compare it side-by-side to its LED counterpart to see the difference which I cannot easily verbally describe.
On the other hand, this HID is a real mAh sucker considering its Low mode at “only” 4000 lumens! (the FF4’s low is 2000 lumens).
Though FireFoxes are quite impractical for everyday use unless you have a bag of batteries with you, it has its own place in a flashlight enthusiast’s collection.
Get one!
Saul M
Last seen: 1 week 13 hours ago
OH HELL YEAH, bring back HID, such wasted potential. I can see this being better than LED for it’s size/output/throw/price. But what about bulb hour lifespan? any numbers there? Last i heard anything over 70-80watts=big reduction in life esp with cheaper lamps.
2km is pretty bloody respectable, aswell the covers good idea.
HID has an old school charm to it like incans but different.
Sirstinky
Last seen: 1 day 8 hours ago
An arc lamp produces some of the farthest throwing light in the world. Some of the old carbon arc searchlights could throw 20 miles (but consume 20 kilowatts of power). It made me a believer when I switched my car’s halogen lamps to HID in 2008. Never went back. You have to get good quality ballasts though since cheap ones don’t last and perform poorly. Xenon lamps are cheap as well…cheap to make unlike high performance LED’s. The downside is the fact you need to package the bulky ballast and driver into a small package- that makes them expensive. I’d say the power consumption is similar to a high power LED flashlight, consumes less amps, but more volts is all and less heat.
stone20003@163.com
Hello, hid bulbs have a long service life. From FF1 to FF5, thousands of flashlights have been shipped. No one has ever worn out the bulbs unless they are damaged by falling from high altitude,
HID light is generated by electric arc breaking through the inert gas, no filament is applied there. Therefore, the service life is longer
HID at present, only the drive circuit may be broken, but with the technology update and upgrading of these generations, FF5 has been very stable
stone20003@163.com
Hello, FF5 100W power, volume is very small
Photon Master
Last seen: 4 hours 2 min ago
Can’t decide what color temp to get. I’d love to buy it from your Ali express store but I don’t Spanish. Is there an English version?
MascaratumB
MascaratumB's picture
Last seen: 4 hours 47 min ago
https://www.aliexpress.com/item/4001256219250.html?spm=a219c.12010612.81...
Try this!
You can change the language specs and currency on the top (in case you are using a browser and not the app) Thumbs Up
stone20003@163.com
Hello, express can translate automatically
Photon Master
This light is absolutely incredible. I agree with the comment that this is superior to everything in my collection even the mighty Imalent MS18. The 4300K is beautiful – can see all the colors of the leaves that are changing even when it’s pitch dark outside
Photon Master
How are you guys carrying yours? Mine didn’t come with a shoulder strap and there seems to only be one hole in the cap, not another in the front like the MS18 has
I’m using a fairly sturdy wrist lanyard but it’s not an ideal solution
Can’t wait to fire this puppy up tonight for trick or treat
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 day 10 hours ago
Paracord is your friend…
KB1428 “Live Life WOT
Photon Master
Oh damn now that is pimp
stone20003@163.com
There is no strap hole in FF5 lamp holder. The weight of FF5 is not too heavy. It can be held normally
J
Where can I find out about pricing and availability on the extended battery holder & charger?
Photon Master
I got my accessories from Neal. The extra battery carrier is nice because i can keep it loaded and attached to the strap on the carrier case. It’s $35
There’s no charger. Do you have a charger for 18650’s? I have an 8 bay Gyrfalcon which I like a lot
https://www.nealsgadgets.com/products/firefoxes-ff5-hid-flashlight-acces...
J
Thank you Photon… I just got my light (4300) and also need to order some batteries. The battery carrier/battery tube I am interested in actually holds 8-18650s so as to increase runtime. I apologize for not making that more clear in my post. Also, im not sure which ones to go with (Sony VTC6A, Samsung 30Q or ???). That is so ironic you mentioned the gryfalcon as I saw it got good reviews and was actually looking at them today.
ch1ir
Last seen: 3 hours 29 min ago
Have this light, is worth every penny
J
Hi Ch1ir
years ago I bought the FF4. I had never operated it until months after purchase. One evening I was bored and decided to charge up some batts and fire it up & pointed it in our court. It had just got dark, the house furthest away was about 100 yards away and it blew that house up like it was daytime-literally… I was in utter shock, mouth agape that a handheld light could do that… while the house was lit up like noon time, my wife freaked out and kept telling me to turn it off because the house residents (which we didnt know all that well) were surely going to come outside to see what was going on lol. ever since then, ive been a fan of FF.
What batteries are you using, if you dont mind me asking?
stone20003@163.com
Sony C6 or Samsung 30q
stone20003@163.com
FF5 11-11All products, low price promotion,Please pay attention to express shop
KawiBoy1428
No “Strap Hole” SP36… Next……
Photon Master
wow, so there’s a carrier that holds eight 18650’s?? I love the FF5 however it sure burns though batteries.
I’m using the pink 30Q’s and they work great. Oddly enough I just recommended the Gyrfalcon to my buddy yesterday but he said it’s sold out everywhere so I have to look around to see if I can find it. It’s literally running on my desk right now.
Fortunately I talked him out of buying a $20 “90,000 lumen” flashlight on Amazon. Oh geeze… This guy literally uses his iphone light to see stuff in the dark outside. He’s rather price sensitive so I pointed to him to the Nightwatch NSX3 w/ a 21700. Wish I could see the look on his face when he hits turbo on that bad boy. I doubt he’s even seen 200 lumens
Johnv
Last seen: 4 weeks 16 hours ago
The 8 battery holder include charger is not available anymore, this is because they can’t ship through customs.
Photon Master
Bummer…I have a spare carrier with four 30Q’s that I put in a holster that’s attached to the strap I’m using. If I ever take this thing somewhere hiking or whatever I might bring another four charged batteries
Photon Master
Went out for a walk tonight past this golf course. I was shining the FF5 on high – lit up some trees that had to have been close to a mile away. Was moving the beam and suddenly saw two huge deer looking back at me. I flipped it to low and shifted the beam a little so I wasn’t blasting them in the eyes. Really cool… oh and also it was raining and the 4300k shined through it like it was nothing.
stone20003@163.com
Eight lithium-ion battery rods, logistics is very expensive, so cancel foreign sales
Photon Master
For some reason that site always comes up in Spanish for me and I can never figure out how to change it to English amigo!
BOMBAY
Last seen: 1 hour 1 min ago
at the very top next to your wish list, there you can change
