[Review] Acebeam L17 green - compact & powerful thrower
27 posts / 0 new
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 months 1 hour ago
Hello everyone,
Acebeam kindly sent me a free sample of their brand new product L17 in return for a review. Thanks a lot for the nice opportunity. If you are interested in another review of mine, you may want to check out the Acebeam W30 LEP review here: http://budgetlightforum.com/node/67500.
What's special about Acebeam's L17?
While the market is quite flooded with reflector flashlights, we now get to see more and more flashlights using TIR optics. These optics have many benefits over reflectors such as a great ratio of focusing and physical diameter, less weight due to plastic materials and lower material costs. Moreover, Osram's Ostar Projection Compact LEDs (a.k.a. "White Flat") has found its way from stage lighting into the flashlight business. This LED offers a remarkable performance for compact throwers at reasonable costs. Last but no least Lumintops successful and popular FW3A has lead the way for tactical e-switches, using a double-tube design.
All these benefits are reflected and combined in Acebeam's L17, offering you an unrivalled beam distance at the size of a rather compact 18650 light with a small head diameter as well as a noiseless tactical e-switch along with a decent constant current/brightness regulation for a very competitive and reasonable price well below $ 80.00. Now, Acebeam sells this light in three different versions using Osram's White Flat LEDs in white, red or green tint. This review here is about the green version which may suit well for hunters or military applications.
Some specifications:
  • Dimensions: 140.5mm (length) x 40mm (head diameter) x 25.4mm (tube diameter)
  • Weight: 150g w/o battery
  • Emitter: Osram KG CSLPM1.2 Green
  • Max. output: 2.000 lumens
  • Max. runtime: 58 hours
  • Max. beam distance: 820m
  • Peak beam intensity: 168.100cd
  • Driver: high efficiency constant current circuit design (without PWM)
  • Battery: 1x 18650 lithium-ion battery or 2x CR123A lithium primary batteries
  • Water resistance: IP68 waterproof to 5 meters
  • Impact resistance: 1 meter
  • UI: classic UI with stepped modes of ultra-low, low, medium, high and turbo as well as strobe
  • Mode memory: yes (standard modes of low, medium and high)
  • Low voltage protection
  • Thermal regulation (probably 65°C)
  • Electronic lockout
More specifications can be found under:
https://www.acebeam.com/l17
Unboxing
The light and its accessories come in a quite compact cardboard box...
Inside you will find...
  • Acebeam L17
  • a high quality holster
  • a microUSB to USB-A charging cable (for the optional Acebeam ARC18650H-310A battery)
  • a lanyard
  • two spare o-rings
  • a spare switch boot
  • the manual
  • a warranty card
  • a warning leaflet
As usual for Acebeam, the glas lens is protected by a dustproof film that has to be removed before first use.
A closer look at the front of the light, using ultra-low mode.
The outer appearance leaves no room for complaining. Everything is well machined, anodized and assembled.
The soft touch tail switch is absolutely noiseless but cannot be operated in momentary mode. However, Acebeam offers an optional remote switch with three buttons where one button is for momentary mode only, see advertising picture below courtesy by Acebeam.
Acebeam kindly supplied the light with an Acebeam battery, see more below. The double tube design is well-made. Unfortunately, I did not manage to unscrew the tube from the head as it was extremely tight.
The tactical cigar grip ring can be easily removed as well as the clip. Threads are very well greased, so twisting the tailcap works like a charm. Acebeam used a very innovative way to enable contact with both tube ends. This could result in much less contact problems as reported in some of Lumintops FW3A lights. The L17 fits gently into the holster for those who want to put it onto the belt.
Using the battery in Acebeam's L17
The optional 18650 3.100mAh battery (ARC18650H-310A) has 69mm in length and can be recharged with the supplied microUSB cable. It came with a resting voltage of 3.76V. There is a charging indicator which is red on charging and turns green when charging is finished. After charging with the microUSB cable the battery indicated 4.18V resting voltage. To my surprise the LED keeps on glowing green afterwards and gets dimmer as the voltage drops. I don't know what this everglowing LED is useful for as its (very low) current drain may affect long-term storage of the battery. Since it's a protected battery, there should be no harm, though. Standard 18650 batteries work properly with the L17 as long as they have a button top or a solder blob. Some flat tops may work, too. However, rattling the light back and forth might result in power failure during operation.
I tested the battery's capacity using a Miboxer C2-4000 charger at 1A discharge current (C-D-C procedure). Please take the numbers with a grain of salt but 2.895mAh seem quite okay and should match the nominal capacity of 3.100mAh (usually measured at lower discharge currents).
I tested some other (cheap) third party microUSB charging cables but they would not work correctly. With the supplied microUSB cable the battery was properly charged at a bit more than 1A.
Size comparison
Below you see some flashlights for comparison and reference. These lights were also used for the beamshot comparison. I chose them by purpose in order to highlight and compare the different beam profiles as well as the color rendition of green respectively monochromatic light in darkness. From left to right...
  • Odepro KL52 Plus zoomlight (fitted with the XP-E green dropin module)
  • Acebeam L17 (using Osram's KG CSLPM1.2 @ 2.000lm)
  • Amutorch New VG10 (using Osram's Ostar Projection Compact LE R Q8WP with red light)
  • Sofirn's new SC31 Pro (using Luminus's SST40 6.500K 70CRI @ 2.000lm)
  • Wurkkos FC11 prototype (using Samsung's LH351D 5.000K 90CRI @ 1.300lm)
  • Wurkkos WK40 prototype (using Cree XP-L2 and Luminus SST-10 in blue, green and red color)
User interface & mode spacing
Acebeam keeps using their popular and foolproof UI with stepped modes.
From OFF
  • 1x click to turn ON (using mode memory)
  • 2x click for turbo mode (2.000lm)
  • 3x click for strobe mode
  • Hold 0.5s for accessing ultra-low mode (25lm)
  • Hold 3s for electronic lockout => to unlock hold 5s, the light will turn on at ultra-low mode
From ON
  • 1x click to turn OFF
  • Hold to cycle through standard modes (low 75lm => medium 230lm => high 500lm => low 75lm…)
  • 2x click for turbo mode (another 2 clicks to return to previous standard mode)
While testing the light I got the impression that mode spacing between low, medium and high more is well done, see also runtime and thermal analysis below. High and medium mode are both very useful whereas turbo mode is quite blindingly bright even on medium distances (15-30m). I'm a bit torn with the ultra-low mode which is way too bright to be considered as a typical 'moonlight' mode. But as maukka already mentioned for the white L17, a thrower light is not meant to be used for ultra-short distances like searching keys in one's bag/purse.
Runtime and thermal analysis
The test ran for about 4 hours. As noted in other reviews of the L17, the output is very well regulated on all modes. The thermal management and constant current circuit of the L17 works very efficient and keeps a constant brightness of about 46% (approx. 900lm) with a settled head temperature of 55°C for about an hour before a second stepdown regulates it down to 6% with a low but still useable mode. The light gets rather hot in its initial phase with close to 70°C. Personally, I like it this way as otherwise the stepdown would be triggered much earlier than after 4 minutes. The thermal heat transfer from head to tailcap is well done as can be seen on the pictures of the thermal imaging camera. After a while the entire body structure shows an evenly distributed body temperature of approx. 55°C. After 4 hours runtime the battery was nearly fully depleted.
Beamshots
All beamshots were made with a Panasonic Lumix DMC-G6 digital camera using following settings:
Focal length: 12mm
ISO: 400
Aperture: f / 5.6
Shutter speed: 4s
These results represent the actual perception by the human eye.
Location #1: The white house is about 120m far away.
Acebeam L17 on turbo mode
Acebeam L17 on high, medium and low mode (from left to right)
Amutorch New VG10 on high mode
Wurkkos WK40 prototype on green mode
Wurkkos WK40 prototype on white, red and blue modes
Sofirn SC31 Pro on turbo mode
Wurkkos FC11 on turbo mode
Odepro KL52 Plus with green dropin (focused)
Odepro KL52 Plus with green dropin (defocused)
Location #2: The illuminated trees are about 35m far away.
Conclusion & Verdict
These beamshots prove that Acebeam created a little powerthrower of 2.000 lumens intense green light with a remarkable beam distance. It easily outperforms any zoomlight in existence and eradicates its downsides of low efficiency in focused alignment and missing spill. Talking about spill, L17 produces a good amount of spill even though most of the light is collimated into the hotspot. Unlike LEP lights you get enough spill on turbo and high mode for orientation in darkness. However, for walking one's dog or close distance lighting I would recommend using another (second) flashlight. The L17's strenghts are definitely in mid-distance scenarios like searching, hunting, police/military applications. In my opinion, this flashlight fills the gap between classic small sized reflector lights (using a high proportion of spill) and LEP lights with no spill at all but extreme beam distances. For most customers this light could be more useful in everday usage than any LEP light.
The green tint color is for sure somehow exotic to most people's eyes but unlike red or especially blue light, green light did not cause any confining or even discomforting feeling after many minutes of using in pitch black darkness. As the human eye is most sensitive to green light, small amounts of light in this wavelength will suffice for orientation.
Acebeam successfully demonstrates the benefits of combining a thrower LED and a narrow-beam optic with a small-sized host. While some months ago beam distances of up to 800m with more than 1.400lm required significantly larger reflector/head designs we now get to see more and more small-sized EDC-like lights with astonishing performance. Acebeam's most promising competitor is Manker's MC13 which is currently using the smaller, less powerful but even more efficient CULNM1.TG (Osram Boost HX). The odds are good that they will try using the CULPM1.TG to match or outperform Acebeam's L17 anytime soon. As usual, competition is a good thing and so I will be curious if Acebeam will be using Osram Boost HX in future batches of the L17, too.
Let's wind up this review with the Pros and Cons...
Pro:
㊉ Impressive ratio between beam distance and size/weight
㊉ Very competitive price/performance/quality ratio with less than $ 80.00
㊉ Great quality in material selection and assembly (no dust, no scratches, no nicks from CNC machining)
㊉ The noiseless switch works like a charm being not too cushy or too stiff
㊉ Well-chosen design with a tactical tailswitch, compatibility to remote switches (for mounting on rifles), efficient TIR optic and Osram's 2mm² emitters
㊉ Constant current driver for stable output and compatibility to 3V CR123A primary cells
㊉ Thermal management that pushes the LED to its limits => great performance
Neutral:
O Thermal management that pushes the LED to its limits => results in lots of excess heat
O The user interface is very intuitive but some user maybe miss a ramping mode and a way to indicate the battery's voltage
O An additional true 'firefly' or 'moonlight' mode would look gorgeous in this TIR optic
Con:
㊀ Momentary mode is possible but only when using an optional remote switch which is not supplied with the light
㊀ 18650 battery size compatibility is somehow a bit restricted as flat top batteries may not work properly
㊀ Not a real downside but the many laser engravings on the tube somehow distract from the nice design of the light
Edited by: Lux-Perpetua on 09/12/2020 - 05:57
Sirstinky
Last seen: 5 hours 49 min ago
Thanks for the review. I tested the white one and the driver bug was not present in my sample. I did notice the very high external temperatures thoough- up to 65 C so the led is driven really hard. The included USB cable is a surprise! I noticed it’s very high quality. I did measure the throw and output and it’s less than Acebeams 802 m at 694 m at 30 sec. (716 m at 5 sec) but that’s remarkable for a sub-40 mm head and no reflector. I think TIR is the future of flashlights, and with the Boost HX 2mm2 version pushing 1500 lm and 200cd 2mm surface brightness at 6A I’d be surprised if Acebeam doesn’t upgrade to this emitter in the future. Downside is its expensive…more than a xhp50.2 3v.
klrman
klrman's picture
Last seen: 2 months 4 days ago
Very good beam shots and comparisons thanks.  Looks like I got the last green one at battery junction.
The red beam on the Amutorch New VG10 looks really strong, do you think it might be brighter than the L17 with red?
Lux-Perpetua
That‘s a good question. I did some researching...
Acebeam rated their red L17 with a maximum output of 300lm using Osram‘s Ostar Projection Compact KR CSLNM1.23. Concerning the Amutorch New VG10 Neil Zhang did not state any output on his website except for a red „20W Osram“ LED.
https://www.nealsgadgets.com/products/copy-of-amutorch-new-vg10-cree-xpl-hd-1200lm-18650-tactical-flashlight#
The only red Osram emitter that seemed to be available by the time I bought it was the before mentioned LE R Q8WP which seems to be a close relative to the white Osram Oslon Boost HX with 4040 footprint. A tailcap bypass measurement revealed approx. 5A of current on high mode.
Now, let’s have a look at some numbers...
LE R Q8WP is rated with up to 224lm at 1,400mA forward current. The LED can be driven up to 5,000mA.
KR CSLNM1.23 is rated with 180lm at 1,000mA forward current. The LED can be driven up to 2,500mA.
Acebeam probably runs the red emitter in their L17 at 2,000mA forward current to get approx. 300lm. If Amutorch‘s New VG10 puts 5,000mA on their emitter it should theoretically yield about 700lm of red light. The radiation surface of KR CSLNM1.23 is only 1mm² which makes it ideal for a small sized thrower. Sizewise LE R Q8WP can be compared with White Flat 2 or Boost HX using 2mm².
Please note that this is more or less an assumption instead of hard, proven facts. Wink
klrman
klrman's picture
I think those assumptions are pretty good and way more than  I would have figured out. nìce  job!  I'm really tempted to get the amutorch red just as I promised myself to get only two lights a year that are  unique from now on
Lux-Perpetua
Thank you klrman. I guess the LED in Amutorch‘s New VG10 can be compared with the white „White Flat 2“ while the LED in Acebeam‘s red L17 can be compared with the white „White Flat 1“.
I wonder if Acebeam is interested in using the bigger but more powerful red version in their L17, too. I guess it’s difficult to source Osram‘s LE R Q8WP as I did not find it anywhere to buy (Mouser, Arrow, Digikey).
Please check with Martin before you order the Amutorch from Neill. He may offer you a nice discount. And be careful with the high mode as the light gets warm very quickly. Wink You will probably feel most comfortable using the medium mode which looks almost as bright as the high mode but with less excess heat.
lazerEagle
lazerEagle's picture
Last seen: 21 min 34 sec ago
Interested in some comparisons to the E10
Seems to throw a bit further?
- the best way to predict the future is to create it -
cleo_stary
cleo_stary's picture
Last seen: 10 months 3 weeks ago
well done
Professional and authoritative Acebeam agent with the lowest price.
Lux-Perpetua
Acebeam informed me that L17 does support momentary mode using an optional remote switch (which was not supplied with the light). I have revised my review accordingly. I still would have favored a momentary mode being available in the flashlight's standard tailcap.
RobertB
RobertB's picture
Last seen: 12 hours 26 min ago
Not sure what this Acebeam will do that my $18 Convoy can’t
klrman
klrman's picture
Was thinking the same thing.  I'm going to order a green led from mtn electronics unless I find it something else and put it in a c8 host and see how it compares to my L17.
What led and driver setup did you use in your C8?
RobertB
RobertB's picture
klrman wrote:
Was thinking the same thing.  I’m going to order a green led from mtn electronics unless I find it something else and put it in a c8 host and see how it compares to my L17.
It’s an xp-e2 from Mtn. I bought a green one as well, just haven’t put it in a light yet. Driver is a standard convoy 8 × 7135
chooma
Last seen: 5 hours 47 min ago
Buy an acebeam and find out, so you can be sure.
klrman
klrman's picture
It's an xp-e2 from Mtn. I bought a green one as well, just haven't put it in a light yet. Driver is a standard convoy 8 x 7135
Thanks.  Going to order a green one and put it in a C8 host just to see how big or not the difference is compared to the L17.
Lux-Perpetua
It seems the L17 I have reviewed on this thread has died silently being a shelf-queen in my closet. Crying
Well, maybe she felt lonely and heartbroken being used only once ever since I made the review. She would let me turn her on anymore, regardless what buttons I tried to push on her. Tired
Strange as she was in good company with some more Acebeam flashlights and the Acebeam battery inside was still clocking at 4.10V. I also gave her an organ transplant (battery exchange) but she felt no love for me anymore. RIP, Acebeam L17. Sad
Supplemental: Maybe this story will still have an happy ending as one of Acebeam's official retailers will be so kind to exchange the defective unit by a new one.
klrman
klrman's picture
Did you long press for 5 seconds?  I thought mine died until I realized it was the electronic lockout.
Sirstinky
Yep. You need to hold the button for 5 sec or so until it blinks. It might be locked. Acebeam are pretty good lights and shouldn’t break. If it has, send it back for warranty since it has 5 year warranty.
Lux-Perpetua
Oh dear... Facepalm That might be possible indeed. Anyway, since it has a slightly faulty driver like maukka‘s L17 it will be exchanged anyway.
klrman
klrman's picture
Hey Lux-Perpetua, I can't find a data sheet on the Osram KG CSLPM1.2 Green that you list as the emitter in the L17.  Is it maybe spelled wrong?
Since it's so yellow, I'm thinking of swapping it with the KP CSLNM1.F1 from Osram but I want to compare specs first.
Lux-Perpetua
Well, here's my assumption:
I am 100% sure that Acebeam once stated the exact name of the emitter on their L17 website, as I mentioned here before...
http://budgetlightforum.com/comment/1675956#comment-1675956
Now, they seem to have removed that detail from their specifications chart, for reasons unknown. I have looked for KG CSLPM1.2 on Osram's website and I agree, it's nowhere to be found, see below.
This is however not unusual as I have another example from Osram's portfolio that cannot be google'd anymore. It's called Osram Ostar Projection Power LE A P0MQ. It is a amber colored LED and it can be driven up to 10A with an output of approx. 1,400 lumens. This powerful LED will probably be used in another interesting Wurkkos flashlight, see my thread about TS30S/TS30R. I have the datasheet here but it cannot be found on Osram's website anymore. Maybe Osram has discontinued this one as well as KG CSLPM1.2 and Acebeam was able to buy some residual reels of it.
Looking at Osram's current portfolio, there is no green 3030 or 4040 footprint LED available that can do the rated 2,000 lumens of Acebeam's L17.
klrman
klrman's picture
Maybe Acebeam got a deal on a bunch of yellowish green leds before Osram gave up on them?  I have to admit that the L17 has the most yellowish green color I have ever seen, but technically it is still green because you can see green in it.  If I ever get that bezel removed and can remove the optics, I will put a real osram green in there like the KP CSLNM1.F1.  Either that or I sell my green L17 for a steal of a deal!
Lux-Perpetua
klrman wrote:
(...) If I ever get that bezel removed and can remove the optics, I will put a real osram green in there like the KP CSLNM1.F1.  Either that or I sell my green L17 for a steal of a deal!
I‘m not sure if NM1 will fit to the driver. If Acebeam really used PM1 there’s a big chance the current will be a bit too high for using it with the smaller NM1 version. But I might be wrong with my assumption. Just thinking...
klrman
klrman's picture
That's what I was concerned about.  I gave up asking Acebeam to clarify anything.  If I want to buy something they reply instantly but as soon as I ask any tech question they stay mute.  They really seem to be a weird company.
arow55
Last seen: 12 hours 24 min ago
What is the hotspot angle? What is the diameter at 100 meters?
arow55
Do animal eyes glow the same colors with green light?
Tangra
Last seen: 1 week 2 days ago
Thanks for review.
Are green and white version use same driver?
I mean, are the consumption on turbo is the same?
klrman
klrman's picture
I just replaced the led in my c8 with a blue osram and visually it seems to out throw my green L17 and also the osram in the c8 with its standard reflector throws a tighter beam than the green L17 which has the TIR optics.  Makes me wonder how all these companies measure throw.   They must use a device that picks up the light waves that our eyes can't see and then put it on their specs to make it look like these things can throw forever.
