Chargers and who's who @2020
44 posts / 0 new
strayz
Last seen: 2 days 12 hours ago
I lost 3 chargers that were plugged in and need to replace them. (wet snow)
Yay for having the old basic night core Icharger from 7-8 years ago away from everything else or I would have no way to charge anything.
I am now looking for a good 4 slot and 8 slot chargers AAA, AA, the whole slew of CR123r through 26650s, and a couple 21700s Most of you have the idea.
The chargers that I lost were in the 3 year old range and I kinda miss the Xtar 4 slot charger with the readout all the bells and stuff.
I looked at some of the reviews by HKJ and he is not really impressed with many of the ones that have come out this year.
I would like to have 2A charging for all of the slots of a 4 slot charger, if possible. The 8 slot charger is a bulk charger and I understand that most of them don’t have 2A to each slot when they are full up.
Digital read outs and being able to adjust for each type of battery and slot would be preferable.
So whos and what model do you recommend?
richbuff
Last seen: 34 sec ago
Xtar VC8 and Vapcell S4 are what come to mind first. VC8 is 3 amps for 8 slots, and S4 is 12 amps for 4 slots. There are many others to choose from. Ranging from super expensive to budget. I like mid-range budget for my flashlight life.
Rev 22:15
xtarflashlight
xtarflashlight's picture
Last seen: 1 hour 3 min ago
Maybe you can take a look at our chargers again Big Smile Wink Beer
https://www.xtar.cc/Charger.html
d_t_a
Last seen: 2 hours 6 min ago
I) 8-slot:
a) (outlet-powered)
I personally like the Miboxer C8 — it auto-balances the charging current of each slot, based on the battery internal resistance, and will auto-balance the charge current when one or more slots finishes charging.
(what I mean is: eg. if 8 slots are used, then max charge current for all slots is 0.8A (indicated on the display) but if 7 slots are used, then 0.85A ; 6 slots will get 1.0A each ; 5 slots gets 1.2A each ; 4 or less slots get 1.5A which is the max charging current of this unit) BUT, if one or more slots starts to get near full-charge state, and those use lower charge current — that power will then automatically balance to the remaining slots so they can charge faster (up to 1.5A per slot) – Miboxer C8 fits unprotected 21700, but is just short of fitting protected 21700 batteries (can fit 8x unprotected 21700 at the same time) – individual charge current for each slot user-selectable (can also select all slots for changing charge current via different button press)
b) The Xtar VC8 is also good and is probably the most full-featured USB-powered charger, but the limit is the USB-power: – if USB power source is the ordinary 5v/2A, then max charging rate would be 4× 0.5A or 8× 0.25A – if USB power source is QuickCharge 9v/2A, then max charging rate goes up to 4× 1A or 8× 0.5A (fewer slots can go faster, like 2× 2A)
– Xtar VC8 fits 8x protected 21700 batteries at the same time (although as mentioned, they won’t be charged fast if all slots are used) – VC8 is like 2 chargers in one, the left set of 4-slots can have 1 charge current, while the right set of 4-slots can be selected with another charge current; but not individual slot (the left set of 4 slots has additional capabilities like doing capacity testing — but it means all the left 4 slots are doing capacity testing)
II) 4-slots: my suggestions (outlet-powered)
a) Vapcell S4 Plus = 4× 3Amp max charge current; length: fits protected 21700 ; width: fits 2× 26650 + 2× 21700 – capacity test function ; auto/manual charge current selection ; powerbank function
b) Liitokala Lii-600 = 4× 3Amp max charge current; length: fits unprotected 21700 ; width: fits 4× 26650 – capacity test function ; auto/manual charge current selection
c) Miboxer C4-12 v2 = 4× 3Amp max charge current; length: fits protected 21700 ; width: fits 4× 26650 – informative display ; auto with manual charge current selection
I think the Opus BT-C3100 is still good but is getting a bit old, it still has lots of functions and also fits unprotected 21700 batteries. (2× 2A ; 4× 1A)
strayz
I purchased a Vapcell S4 Plus. I have to say pleasantly surprised so far. Seems to like being full and going all out No over heating yet. 2 weeks of off and on usage and it has been a champ.
I may Pickup another one.
Lightbringer
Lightbringer's picture
Last seen: 11 hours 27 min ago
I’m still trying to wrap my brain about how or why you were using chargers in wet snow.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 21 hours 24 min ago
Miboxer no longer makes/sells any chargers. Sad Their brand is now used for totally different products.
www.miboxer.com
MoreLumens
MoreLumens's picture
Last seen: 12 hours 29 min ago
Only thing that comes in my mind is using them in a cabin that had roof collapsed in or something like that.
Or maybe something extreme survival stuff and lived in a shelter made out of branches and snow with solar panels to fuel those charger. Still living in some remote cabin would be the best life. Just nature and you.
strayz
Window in Garage was broken over night, snow entered through said window. Did not find out about the window until the next morning. Chargers were sitting on a work table. Yeah I know never leave things charging unattended.
d_t_a
www.miboxer.com
That’s probably true… but I still see some formerly “Miboxer” chargers being sold online, like in Banggood, and also a few other online sources…
Provided the charger works as intended and doesn’t malfunction prematurely (and not really mind about possible warranty issues — since it seems the “Miboxer” is not around anymore, I feel that they’re still good to use).
I suppose if longer warranty is important, then may have to cross out Miboxer chargers… (I got Miboxer charger from BG before and they did address issues that I encountered with the charger, if problems occured within a few days after receiving and using the charger)..
peg matite
peg matite's picture
Last seen: 10 hours 42 min ago
If you find the need for a smaller, 2-slot charger, I got a Littokala Lii-S2 for $13.50 a while back and honestly it charges my Li-ion cells better than my “new version” i4 Intellicharger or my DLYFULL T5 Test Charger.
The Lii-S2 holds my unprotected 21700s just fine, and has user-selectable charge current, and will charge NiMH, Ni-Cd and even LiFePO4 with user selection of voltage. Charging isn’t the fastest, but it will do a single cell at 2 amp.
I just wish it was USB-C input instead of Micro.
My cells often come off the other chargers at 4.15 to 4.17 V, but the Liitokala seems get them to 4.18 to 4.20 much more reliably.
Really glad I got it and more packable than the bigger chargers.
Oh, and I like the “retro-green” LED display.
Lightbringer
Aha. I was picturing someone intentionally setting them in snow… “That should keep those batteries cool!”, etc.
Whew!
Couchmaster
Last seen: 3 hours 33 min ago
Lightbringer, what do you make of Xtars VP series chargers?
Lightbringer
Me? No idea. Ain’t got any yet.
I’m already hip-deep in my Opi, almighty Miboxers, Zanflares, Nitecores, from back when I was trying to find The Charger™, and GB and others were having hella good discounts like every week.
I just popped in here to see if there was any blazing new tek that might be of interest.
strayz
Whew!
Don’t need snow to keep them cool, was 9 Degrees Fahrenheit last night. Big Smile
Lux-Perpetua
Is there anything "better" than Vapcell's S4+ charger right now? The only device that matches or even surpasses the S4+ charger in terms of reasonable features is the SkyRC MC3000. Unfortunately, it barely accepts unprotected 21700 batteries that have to be squeezed into the slots. So far, SkyRC does not seem to be interested in upgrading this model or in launching a successor.
Then there's the Miboxer C4-12 which has less features than Vapcell's S4+ but offers perfect voltage termination at 4.19V - 4.21V. I cannot tell at what voltage the S4+ settles batteries yet but I hope it's closer to 4.20V than most of my other devices that leave batteries finished with a resting voltage of 4.12V - 4.17V. Too sad that Miboxer has stopped selling chargers.
Then there's the BLF charger project by BlueSwordM. As much as I am looking forward to seeing this charger come to life, I doubt it is going to happen anytime soon.
Jabe1
Last seen: 1 day 5 hours ago
I’m in the market for a new 4 bay charger too. Protected 21700 capability is a must.
So far, it looks like nothing fits the bill as well as the Vapecell S4+.
What about Nitecore’s offerings?
strayz
Better? Well that depends on what you are looking for I like the 3A charging for all channels and the over all performance so far.
I am only a single source on the internets so research out a bit more. I am biased to my own choices, and I am not you.
I am still looking at getting a second charger 4 possibly a 8 channel charger It just kinda depends on my mood.
nick779
nick779's picture
Last seen: 1 week 1 day ago
www.miboxer.com
This kind of sucks because there are VERY few chargers that can do what the C4-12 can do.
3Ax4 slots with 4×26650 and 21700 support. I also like having all of the different current options it has.
Heck I’m looking for a backup with those features and would be happy to find a decent one that does 2A on all slots for around the same price.
VC8 seems Ok, but needs an additional QC PS. Also HKJ gave it a meh rating.
Vapcell S4 also had some issues in his testing as well, but was somewhat solid.
Maybe multiple Xtar SV2s, but then I’d have to deal with multiple wall warts and tight fitting 21700s
d_t_a
nick779 wrote:
www.miboxer.com
This kind of sucks because there are VERY few chargers that can do what the C4-12 can do. 3Ax4 slots with 4x26650 and 21700 support. I also like having all of the different current options it has. Heck I'm looking for a backup with those features and would be happy to find a decent one that does 2A on all slots for around the same price. VC8 seems Ok, but needs an additional QC PS. Also HKJ gave it a meh rating. Vapcell S4 also had some issues in his testing as well, but was somewhat solid. Maybe multiple Xtar SV2s, but then I'd have to deal with multiple wall warts and tight fitting 21700s
Someone else mentioned that Miboxer is still alive, check this website
http://miboxercharger.com/
However, we're unsure if "Miboxer charger" is still affiliated with "Miboxer" (a different division? or a separate company now?)
chargers that can do 4x3A charging (that I know of, there are likely others that I'm not familiar with):
a) Miboxer C4-12 v1 (single-button) = supports 4x 26650 & 4x 21700 (but may not fit longer protected 21700)
b) Miboxer C4-12 v2 (two-buttons) = supports 4x 26650 & 4x protected 21700
c) SkyRC MC3000 = supports 4x26650 and 4x unprotected 21700 (unprotected 21700 are a "tight fit" for the MC3000 though ; won't fit protected 21700)
d) Vapcell S4 Plus = supports 2x26650+2x21700 or 4x protected 21700 (the 2 inner slots won't fit 26650 when the 2 outer slots are occupied with 26650 batteries)
e) Liitokala Lii-600 = supports 4x 26650 and 4x unprotected 21700 (won't fit protected 21700)
nick779
nick779's picture
d_t_a wrote:
nick779 wrote:
www.miboxer.com
This kind of sucks because there are VERY few chargers that can do what the C4-12 can do. 3Ax4 slots with 4×26650 and 21700 support. I also like having all of the different current options it has. Heck I’m looking for a backup with those features and would be happy to find a decent one that does 2A on all slots for around the same price. VC8 seems Ok, but needs an additional QC PS. Also HKJ gave it a meh rating. Vapcell S4 also had some issues in his testing as well, but was somewhat solid. Maybe multiple Xtar SV2s, but then I’d have to deal with multiple wall warts and tight fitting 21700s
However, we’re unsure if “Miboxer charger” is still affiliated with “Miboxer” (a different division? or a separate company now?)
chargers that can do 4×3A charging (that I know of, there are likely others that I’m not familiar with):
a) Miboxer C4-12 v1 (single-button) = supports 4× 26650 & 4× 21700 (but may not fit longer protected 21700)
b) Miboxer C4-12 v2 (two-buttons) = supports 4× 26650 & 4x protected 21700
c) SkyRC MC3000 = supports 4×26650 and 4x unprotected 21700 (unprotected 21700 are a “tight fit” for the MC3000 though ; won’t fit protected 21700)
d) Vapcell S4 Plus = supports 2×26650+2×21700 or 4x protected 21700 (the 2 inner slots won’t fit 26650 when the 2 outer slots are occupied with 26650 batteries)
e) Liitokala Lii-600 = supports 4× 26650 and 4x unprotected 21700 (won’t fit protected 21700)
Thank you for the guidance! I must have missed some of that information above.
Lux-Perpetua
nick779 wrote:
www.miboxer.com
This kind of sucks because there are VERY few chargers that can do what the C4-12 can do. 3Ax4 slots with 4x26650 and 21700 support. I also like having all of the different current options it has. (...)
I couldn't agree more with you. I do have a couple of chargers here, among them the C4-12 V1, C4 V3, C2-4000, SkyRC MC3000 and Vapcell's S4 Plus. They all have their pros and cons. Maybe I can find the time to discuss some ideas with Vapcell in order to see an improved and enhanced S4 Plus model in the future. For instance, I miss the storage or LiFePO4 charging function to level my batteries at 3.6 - 3.7V.
nick779
nick779's picture
Lux-Perpetua wrote:
For instance, I miss the storage or LiFePO4 charging function to level my batteries at 3.6 – 3.7V.
I didn’t even know this was a thing until I stumbled across someone on reddit who mentioned it. I’ve been just watching the charger and charging at low current to do storage. This makes it SO much easier.
prototype3a
Last seen: 4 days 3 hours ago
www.miboxer.com
That’s just depressing. I really liked the C8 and would have loved to see an updated version that had a higher total power rating.
Garageboy
Last seen: 1 week 5 days ago
I noticed in a few of the reviews (HKJ’s review thread), the Vapcell S4+ is a little bit buggy? Has there been any firmware improvements since? I’m torn between the Lii602, the Dragon VP4, and the Vapcell S4+
d_t_a
Vapcell S4+ has (from what I know), the earlier version and later version with some fixes. But it seems (based on reports), that they may have some issues, more specifically regarding the charging portion when doing a capacity test of NiMh batteries. But for other basic functions (eg. regular charging, capacity test for Li-Ion batteries), the (old & new) Vapcell S4+ seems good.
Liitokala Lii-600 still need more in-depth test review by people who can do in-depth testing (like HKJ)… I’ve tried out the Lii-600 and it appears to work good (it doesn’t seem to “overcharge” (not that much) unlike the Lii-500S where reports are that the Lii-500S tends to charge to 4.23-4.25v. On the Lii-600 I tested, it appears to just charge to 4.20-4.22v which is a very good result, but then that’s only 1 sample…) I haven’t tested much charging / doing capacity test with the Lii-600 so I can’t comment too much with this unit yet.
Xtar Dragon VP4 is an older model but charges very well, both Li-Ion & NiMh batteries. It doesn’t have as much informative display (I usually like to see voltage instead of percentage charged) and is a reliable charger. It’s also a bit more expensive.
I probably would pick the Vapcell S4+ given the 3 choices you mentioned.. if you charge/test mostly Li-Ion batteries.
If you have more bigger batteries and “D” size NiMh, then the Xtar Dragon VP4 is the only charger that can fit 4x “D”-size NiMh at the same time (it’s the widest charger I’ve encountered in terms of individual width per slot..) Charging current is not too high (compared to the other chargers), but should be good enough unless often need to charge higher-capacity cells (eg. 21700/26650) more quickly..
Just my opinion though..
Garageboy
Thanks, I’m awaiting more reviews of the liitokala. I do a mix of nimh aa/aaa and li ions. Lots of almost perfect options…(example: xtar vc4s would be great, except it occasionally charges aaas at 2 amps)
nick779
nick779's picture
Might be worth a shot to snag a 2 button version Miiboxer C4-12 while they’re still around. HKJ rated it quite well and it does multi chemistry well too. Only thing I don’t like or use on mine is the auto current selection which can easily be overridden. It also uses a 12v 5a laptop style power supply.
d_t_a
nick779 wrote:
Garageboy wrote:
Thanks, I'm awaiting more reviews of the liitokala. I do a mix of nimh aa/aaa and li ions. Lots of almost perfect options...(example: xtar vc4s would be great, except it occasionally charges aaas at 2 amps)
Might be worth a shot to snag a 2 button version Miiboxer C4-12 while they're still around. HKJ rated it quite well and it does multi chemistry well too. Only thing I don't like or use on mine is the auto current selection which can easily be overridden. It also uses a 12v 5a laptop style power supply.
I'm not sure if HKJ reviewed the 2-button version Miboxer C4-12.. He did review the original 1-button Miboxer C4-12 that had a USB-out function.
The 2-button version Miboxer C4-12 actually has some revision in the later batch too.
Some noted difference of the earlier Miboxer C4-12 (2-button) v2 with a recent Miboxer C4-12 (2-button) v2.2 ("v2.2" is indicated in the manual only, not on the charger):
(the v2 and v2.2, both 2-button versions of C4-12s look physically the same)
I) Miboxer C4-12 v2 (2-button):
 a) has A for automatic charge current selection, when cycling the charge current (ie. user-selectable charge current can cycle from 0.1A up to 3.0A, then the "A" (automatic  setting) then back to 0.1A
 b) automatic charge current selection appears to be solely based on the measured IR by the charger, so if it's a small capacity battery that has a very low IR, then it will automatically charge at higher charge current (as high as 3A if the measured IR is low enough) (user can manually select charge current, or go back to the "A" automatic setting)
 c) the charger will display IR measurement even when the battery is at 4.20v
II) Miboxer C4-12 v2.2 (2-button):
 a) when battery is first inserted, it uses Automatic charge current selection (appears to be based on the measured IR), but when user-selecting the charge current, it cycles from 0.1A to 3A, but not the "A" (automatic) setting
 b) the automatic charge current appears to still be based on the measured IR, but now there is an upper limit of 2A (i;e. when the IR is very low, it will charge at max 2A automatically; user can still manually select own charge current)
 c) the charger does not display IR value anymore when the just-inserted battery is nearly full voltage (ie. if the battery just inserted into the charger is at 4.16v or higher, then the IR display will just indicate "---", in contrast with v2, it will still show an IR value)
prototype3a
I found a C4-12 v2 and boy is it nice. Looks like they made the slots longer than those on my C8. Decided to let the wife use the C8 for all her AAs and AAAs and I’ll stick with the C4-12 for 18650,21700 and 26650s.
I generally like the auto-current of the MiBoxers as it doesn’t seem to overly-fast-charge cells to the point that they get hot….. and I’m lazy. Smile
nick779
nick779's picture
FWIW I just ordered a backup MiiBoxer C4-12v2 from Aliexpress for $25 (on-sale). Couldn’t pass it up.
I was looking to see if anything interesting was on the horizon, but didn’t come across anything promising with 4×26650 or 4×3A(let alone 2A) capability.
I’m just learning about USB-C PD, It’s going to be pretty awesome if/when that standard is able to replace all barrel jack PSUs.
