Simon uses 3030 boards, which are also sold in his store!
I didn’t try one of these leds under a single optic but…I don’t think it will be a great thing. :zipper_mouth_face:
Having an Acebam TK16 with 3 of these leds under a Carclo 10507, I can tell that it generates some artifacts and even some tint shifts.
If you want the beaded (pebbled) TIR, it will be more floody and lose the throw that these leds give. It will have less shifts and artifacts, though.
Also, for your choice, bear in mind that if the TIR lens is clear (not frosted or pebbled) any small mis-centering (with or without proper gasket) will result in awfullness
It doesnt make any sense to use a throwy LED under a TIR op optic, for anything other than throw.
If you want a nice and even spread of light (floody) just use an appropriate LED, not a CSLNM1.TG
BTW, i do have the TK16 as well and it’s a nice little light, not the best UI though
I was trying to smooth out artifacts and the corona but at the same time turn it into something similar to the Acebeam L17. Trying to get more of the hotspot and less corona to minimize artifacts in the beam.
Trying to get more throw if possible with a 10 or 15 degree TIR.
This kind of shape lens is - eventually - more what want (notice there seems to be a hole in the front, that will make the beam narrower as the L17). No 100% sure, though.
How would the beamshots differ between the two? Output? I can’t seem to find any information where someone has tried frosted TIR optics or pebbled/beaded TIR optics. I know the most popular option is a 45 or 65 degree TIR.
My EDC is currently (and has been for year ) is a custom FW1A with a sliced sst20 4000k. I was first using an OP S2+ reflector, then a modified S21A OP reflector, and now a pebbled narrow TIR from the Convoy store. I’ve bought so many 20-22mm TIRs in search of the perfect beam (for me). What I’m targeting is an artifact free medium/narrow spot with only the faintest spill. 9-11° is the upper range and down to 7-8 is okay. I’ve bought each variant of the LEDiL Leila XP optics, and have been very unhappy with their results with this emitter, especially considering the $ spent. Thinking of swapping in a 351d sliced to give a better beam with the larger LES, but don’t want to give up CD/LM. With the aforementioned Convoy optic, I’m seeing the best results according to my goals, but there are a few stray assymetric spill artifacts that annoy me, so the hunt continues. I think they are from the mold injection points. BTW, beam is about 9 or 11 degrees, depending if I count the ‘corona’, which is really more of a fuzzy edge
So @supreme, I think I understand what you might want from such a setup. CD/LM without artifacts and spill that causes foreground glare in close quarters. I personally can’t get behind the CW osrams in anything but a dedicated max throw setup, but if you don’t care about CCT or CRI go for it. Not much lost if it doesn’t turn out the way you like it. Its your flashlight!
I don’t have numbers for you, but I can say that both reduce the output if compared to a light with a reflector. I am sue there are numbers out there comparing lights in the same situation or theorizing about that.
I just did some output measurements to compare losses last night and rough ceiling bounce tests showed the difference between the reflector and narrow optics was minimal. About 3%, if you would believe that the noise of my measurement isn’t that much or more…
BTW, I’m not saying that all TIRs will perform this way, but my samples didn’t suggest a huge loss.
Well, and there I was, in name of the flashlight science, experimenting some non scientific stuff
So, I picked my Skilhunt M200 with Samsung LH351D led and did the test with different TIRs, and stock reflector. Also made some “ceiling bounce” - if you wanna call it that way, with the different configurations.
Luxmeter configured to Lux measurement.
Distance to the ceiling (white) = ~1.68m
The flashlight wasn’t moved from its place during the test. The output in every test was turbo.
1 - No lenses nor reflector nor bezel = 23 lux
2 - Reflector + glass lens + bezel = 60 lux
3 - Pebbled TIR + bezel = 45 lux (less intense and more widespread beam than the frosted, as you’ll see below)
4 - Frosted TIR + bezel = 59 lux
5 - Angle TIR (25 degrees) = 64 lux (more intense in terms of light concentration, and less widespread spill than the reflector)
Some beamshots comparing:
Reflector > Angle TIR (25 Degrees)
Pebbled TIR > Frosted TIR
Please note that the TIR optics were sitting on the gasket, not directly on the PCB, so that may change the beam a little bit. Still, you are able to see what they do.
This is also a beamshot of a Angle TIR (45degrees) sitting on a XP-L HD CW emitter (with gasket too).
Yup! I might give a 10 degree TIR from Simon a try in the S2+ with CW osram. I’m trying to have two cheap 18350 flashlights for short night walks. One thrower and one flood. Should be achievable with two S2+’s for less than $50.
Yup, the frosted - at least in my case - has a less wide/floody beam! It is probably that larger domed leds, or dedomed leds, will produce differences, though.
But I’d say that a 60º Pebbled lens will produce a wider beam (you can chose one less floody)
May I suggest you one thing?
For the shorter throwy light, why don’t you go for an S2 (not S2+) with Smooth reflector?
Check this post where I compared an S2 with smooth reflector and Osram W1 and an S2+ with smooth reflector and XP-L HI Leds.
You can see that the S2 has incredible throw! And with an 18350 tube you’ll be able to “shrink” it!
Just a suggestion, though!
I am not sure if I understood the question well, but I’ll try to reply.
Looking to the examples I gave above, namely the clear TIRs of 25º and 45º (last one), you can see that these clear TIRs produce an hotspot but there is some spill around it which is more or less defined depending on:
a) how the TIR sits on the gasket or PCB
b) the type of (dome, dedomed, footprint)
c) the angle of the TIR itself (10, 25, 45, 60).
Besides this, there is the outer spill which is also more or less floody depending on the above criteria.
As you can see, the 25º lens has a more centered beam (although not completely defined), while the 45º has a defined hotspot and a defined “spill” around it.
