I was thinking about getting a 3D printer but after doing some research I’ve got a headache. Right now just don’t think I want to spend time getting into that stuff yet, it simply does not seem to be tinker-free with bed leveling and all that stuff.
So, instead of spending a lot of time buying myself expensive headaches I’m looking for someone who already has this dialed and can design and print things I want, and then send to me. Of coarse I will pay for this service. EU only as to avoid paperwork and customs.
What I first want is a small block I can use as driver holders when applying solder paste to double sided 17mm drivers using stencils. So this block has to be about 6x6x1 cm, have a 17mm hole in the middle that goes down just a small bit (driver board thickness), and then a slightly smaller hole all the way through. Basically the 17mm driver needs to rest on a thin shelf so that components mounted will not be in the way. Top has to be smooth so stencil stays perfectly level on top of the driver. Then I need some edges cut in so I can easily lift out the driver board without smudging the applied solder paste. Anyone interested in making this for me? If so, send me a PM and we can work out the details.
Edit: Added CNC as option because it might be better for smooth surfaces.
