FREEME ✌ LUMINTOP FWAA Andúril 2 14500 Flashlight Deals - CL2 Bundle Deal
779 posts / 0 new
wolfstyle
Last seen: 1 hour 13 min ago
Jimo wrote:
I purchased the Vapcell h10 button top. They are 49.4mm. Will they fit the fwaa.
Not sure where you purchased from but Illumn shows both the flat top and button top have a length of 49.4mm. I don’t think that can be right.
Robin Dobbie
Last seen: 1 week 4 days ago
supreme wrote:
I was wondering the same thing, Illum lists the minimum capacity which has a 100mAh difference between the 3A and 10A cells. Not sure why Vapcell carries both since 100mAh probably translates into less than a 5 min difference in runtimes
And then if you say, skip past the blink on your ramp and end up at 5A, then you get like 40% less runtime.
Yeah, I don’t know why Vapsells them, and I don’t know why Illumn carries them for the practically negligible difference in price.
Jimo
Last seen: 3 weeks 5 days ago
I purchased from Illumn. And I saw that aswell
Jimo
Robin Dobbie
Not even the Vapcell storefront on Ali has the length correct. If you look on their store listing for the H10 Button top, it just says add 2-3mm, so apparently they don’t even know.
Jimo
I’m trying to find out from lumintop if the button top will work. I believe they will as they are listed at 1.1mm under the stated battery size.
Jimo
freeme
freeme's picture
Last seen: 1 hour 3 min ago
My flat top is 48.8mm.
wolfstyle wrote:
Not sure where you purchased from but Illumn shows both the flat top and button top have a length of 49.4mm. I don't think that can be right.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
vit55
Last seen: 1 day 5 hours ago
Thanks Freeme purchased sst20 4000k
TIFisher
Last seen: 9 hours 14 min ago
Order complete Nichia 4000k. Thank you.
Firelight2
Firelight2's picture
Last seen: 50 min 31 sec ago
Jimo wrote:
I know this is slightly off-topic but it still about leds. What is the difference between say,sst20 and orsam.So I guess I want to know more about Orsam leds.I m considering the Acebeam tk16 with orsam leds.
Osram:
- Very intense and small hotspot. Lots of throw.
- Best choice of emitter for longer ranges.
- Pretty poor up close due to small size of hotspot and overall low lumens.
- Cool white tint – looks good at full power. Looks a bit greenish and ugly at lower power.
- Low CRI
SST-20:
- Less intense beam. Less throw than Osram, with considerably wider beam.
- Good for close-medium range.
- Adequate for up close use, due to wider beam. But still inferior for close range compared larger emitters such as LH351D.
- Available in very high-CRI. Renders colors very well.
- Ugly greenish tint at lower power settings. More green than Osram.
4everAwake
4everAwake's picture
I’m interested – SST 4000k version
Agro
Agro's picture
Firelight2 wrote:
Osram:
- Low CRI
SST-20:
I believe in this light SST-20 won’t work well at medium range, only up close.
Jimo
What do you consider the perfect led
Jimo
Robin Dobbie
One that emits one photon for every electron.
Jimo
Ok you lost me
Jimo
Sparks65
Sparks65's picture
Last seen: 1 min ago
Ordered 1 Nichia 3000K & 1 Nichia 4000K Thanks freeme
Firelight2
For raw impressive output, I’ve still yet to find anything better than XPL-HI for small triples. XPL-HI offers nearly as many lumens as LH351D, with much more intensity, neutral white color temperature, and excellent rosy tints. Also due to its higher forward voltage it tends to run cooler in these tiny hotrods than other LEDs like SST-20 or Nichia 219c.
If you want to impress your friends, XPL-HI tends to be the most impressive.
Unfortunately, XPL-HI does not come in high-CRI. My current EDC is a modified DQG Tiny 18650 IV running Anduril with three high-CRI Nichia 219C as emitters.
This setup is quite a bit lower output than XPL-HI, but I like the tint, color temperature and CRI.
Jimo
Thanks for the info I appreciate your time and help Jim
Jimo
d_t_a
Last seen: 9 hours 34 min ago
I notice there were some questions about the length of the Vapcell H10.
I’ve ordered the Vapcell H10 a couple of month ago, both flat-top & button-top (unprotected), their measurements are as follows:
Vapcell H10 (flat & button-top unprotected)
Vapcell H10 flat-top @ 49.1mm:
Vapcell H10 button-top (unprotected) @ 51.4mm:
The caliper I’m using is not that high-quality, so maybe error could be +/- 0.1-0.2mm.
flightless22
flightless22's picture
Last seen: 1 hour 59 min ago
I’m interested.
Could you convince Neal / Lumintop to sell the 16mm triple mcpcb and triple optic alone?
Brandon42364
Last seen: 5 months 3 hours ago
I’m curious how hard flashling anduril 1 on this would be, I’m not a fan of anduril 2
Twisted_Saint
Last seen: 18 hours 24 min ago
That’s what Neals site has the measurements as when I bought some earlier
BOO5TED
BOO5TED's picture
Last seen: 16 hours 56 min ago
Just curious as to why?
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
djans1397
djans1397's picture
Last seen: 16 hours 26 min ago
TMaxxJJ wrote:
Interested! 14500 is my preferred pocket carry size so this will be a welcome addition. Please ask them for a deep carry clip though!! Not even bothered about the two way, but deep carry makes all the difference
This Thumbs Up . .. I second the motion for a deep carry clip!!!
Gunga
Gunga's picture
Last seen: 1 hour 15 min ago
What were the changes in anduril 1 vs 2?
djans1397
djans1397's picture
Yep…. make it a single emitter option, deep carry clip and offered by another/ a different vendor and I’m in! This would be my favorite 14500 EDC then!
Jimo
So according to the measurements the button top batteries are 9/10ths of a mm over the stated maximum battery size I think that they will work. Right???
Jimo
BOO5TED
BOO5TED's picture
It’s possible but the tolerances on the FWXX series lights are so tight that it could damage the spring or the cell itself over time.
Jimo
Are they going to include classes to get a degree in that,my goodness that loos confusing
Jimo
BOO5TED
BOO5TED's picture
I’ll admit it’s intimidating at first but once you have the light and understand the flow it gets MUCH easier.
Jimo
Is that the anduril for the Fwaa
Jimo
