I see a lot has changed since I have been around, so I’d like some help from the experts on finding a new headlamp.
Criteria:
- Floody emitter (or multi-emitter as long as one is floody)
- neutral or warm white, 4000k and under.
built in recharging, with USB-C or micro USB in-body(not a separate magnetic dongle)
I think I would like something 18650 best but I’m open to other options, even a built-in battery like Nitecore often does. I have a modded Skilhunt H02 that’s perfect but it’s missing the rechargeable aspect.
Yeah if you insist on the micro port. Might be tough to get an answer how close it is to 4000k but most of their “warm” are in that range. Probably better to just get the C2 wizard pro warm with the magnetic charger. All of the armytek headlights have a nice smooth wide beam pattern.
Edit: Opple Light Master III locates the ‘warm light’ Tiara (also XP-L) at 3700K, above BBL, not green but yellowish. The usual Armytek tint. If HCRI is not needed, I’d highly recommend it over the Samsung.
The recently announced Acebeam H17 kinda ticks most of your boxes, except that the built-in charging looks like it’s built into the battery, not the lamp.
