LUMINTOP GT MINI
in Copper & Brass
Special Price: from $83.93 - $89.93
Freeme's Coupon: F17913
Special Price: $89.97 (usual $119.95)
Freeme's Coupon: 1TDNEW
Specifications:
- Emitter: KW CSLNM1.1G LED, cool white
- Intensity: >372,625cd (ANSI throw >1050)
- Firmware: Andúril Firmware - free software distributed under the terms of the GNU Public License version 3.
- Modes:
- Default smooth RAMPING UI. Instant access to a TURBO mode and mode settings are also provided.
- A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre- defined mode-sets can be selected.
- MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
- Battery: One button-top 18650 or 18350 (short tube included) Li-ion cells Protected cells are recommended. Cells are not included.
- Reflector: 43 mm ID, aluminum, smooth finish
- Lens: Glass with anti-reflective coating
- Body: Aluminum with Type III hard-coat anodizing
- Button: Tactile with back-lit rubber boot
- Ingress rating: IP68, underwater 2 meters
- Weight: 400g without cells
- Dimensions: 50 mm Ø head x132 mm length
Package Included:
- 1x Lumintop GT MINI NM.1 Copper/ Brass
- 1x Short tube
- 2x o-rings
- 1x instruction manual
