Motorcycle LED Headlight from Aliexpress for bicycle night rides
8 posts / 0 new
YuvalS
YuvalS's picture
Last seen: 18 min 55 sec ago
Hi,
I want to build a mountain bikes light for a friend.
I come across this light on Aliexpress and it seems nice.
Unfortunately not a lot of information is provided.
Did anyone had a chance to play with this light? Any review is welcome
TIA
My FW repository
My BLF/OL contest entries: 7th 8th 9th
Edited by: YuvalS on 08/24/2021 - 18:50
cayman
My cousin uses similar ones, but they look a little different and come in black
https://s.click.aliexpress.com/e/_AX8lTZ
they look awesome IRL and on the street.
Apparently there are many similar light types
https://s.click.aliexpress.com/e/_Ake8Dt
YuvalS
YuvalS's picture
cayman wrote:
My cousin uses similar ones, but they look a little different and come in black they look awesome IRL and on the street.
Thanks, these lights are wide beam, the one i was asking about is a thrower.
The main reason I was interested with that model is the huge heat sink winch, I hope,  allow constant turbo mode.
It also claimed to have a XHP 70 emitter...
My FW repository
Dirty Water Guy
Dirty Water Guy's picture
Last seen: 19 hours 9 min ago
Never seen those, I’m running these on my 09 vstrom 650, wide beam with a 3m yellow self stick film to make them yellow. $20 / pair on amazon, cheap, probably 6500K tint, be careful because these can leak, some well placed silicone will fix
https://www.amazon.com/AUTOSAVER88-Lights-Motorcycle-Driving-Waterproof/...
YuvalS
YuvalS's picture
Dirty Water Guy wrote:
Never seen those, I'm running these on my 09 vstrom 650, wide beam with a 3m yellow self stick film to make them yellow. $20 / pair on amazon, cheap, probably 6500K tint, be careful because these can leak, some well placed silicone will fix https://www.amazon.com/AUTOSAVER88-Lights-Motorcycle-Driving-Waterproof/dp/B01N3YR0AE/ref=psdc_15730331_t1_B01MDJK1AJ[/quote]
Thanks, Does it have any smart features such as thermal protection/ low battery protection etc.?
My FW repository
PeyoX
PeyoX's picture
Last seen: 9 hours 37 min ago
Back in time I bought 5pcs (their last stock) for <$9/piece from a local online seller in my country, 4 of them was sold with some modifications.
Now I just have one on my bike, it has a good heatsink, but it cames with cheapy Eti7070 with blue-ish tint (I belive more than 7000K) and thin aluminum pcb for the led & driver.
I mod them with dedomed 6500K 12v Xhp70.2 20mm copper mcpcb (thermal glued) and 12v 2.4A driver.
Be careful when you try to open the bezel, the thread was glued. I broke the first light’s bezel and need to make the new one.
For the other lights, I used the heat technique for opening the bezels. Also, you need to seal the the glass and the cables output. It’s not rainproof at all.
http://imgur.com/a/s0pryDc
Limited English, still working on it.
YuvalS
YuvalS's picture
Thanks, that is some useful info.
I will try order this version since it claimed to have XHP 70 from factory. worse case, I will mod it myself....
My FW repository
YuvalS
YuvalS's picture
So I got the light, connected it to a 1P4S 21700 battery holder with a protection board and a simple on/off switch. I also sew a PVC case to protect the batteries.
Seems like a nice solution for night rides: constant 1000 lm for 150-200 meters it consume constant 1.5A so high capacity 21700 will last for about 3h and not get hot while riding
My FW repository
