Ordered my first ZebraLight
43 posts / 0 new
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 3 hours 42 min ago
All my ZLs have that same feeling of the dome pushing down to meet the switch first, but the switch itself feels so good that I don’t really mind.
Unheard
Unheard's picture
Last seen: 1 hour 58 min ago
No much to see, but now I know it’s the switch. It does touch the boot. When pressing it slightly down, it clicks and stays there for some seconds, then again moves slowly upwards. Pressing it further down, there’s a second click and the light registers the signal.
Maybe a spring is broken that keeps the button under tension. The actual contact spring is ok. Hope it stays that way.
Ideas, anyone?
Smile, you cannot kill them all.
BurningPlayd0h
Switches can have pretravel, I assume this is true of electronic microswitches as well? Considering it actually sounds to be kinda common based on this thread (the 3 Zebras I own now all have it but zero other switch issues, and I think there were some posts about it on CPF once) I’d imagine it’s just how the particular microswitch these use operates.
thefreeman
thefreeman's picture
Last seen: 54 min 20 sec ago
Ah so it’s not the boot not touching the switch (I have several ZL where they don’t touch) but the switch is defective, I don’t see other option than to change it, This is what they use (or others of the same size, 250g)
Unheard
Unheard's picture
I’ll replace it if I find a source for the switches. It doesn’t feel ok.
Unheard
Unheard's picture
Thanks again!
thefreeman
You’re welcome, probably you’ll going to have to remove the driver from the light because replacing it from the switch opening looks difficult.
Unheard
Unheard's picture
Yes, maybe my reflow station will do. Not yet ready to prey out the bezel (chicken Facepalm ).
SammysHP
SammysHP's picture
Last seen: 1 hour 41 min ago
It’s not the bezel or the damaged glass lens. It’s the epoxy used to glue down the PCB that might rip off some components like the inductor.
id30209
id30209's picture
Last seen: 9 hours 20 min ago
SammysHP wrote:
It's not the bezel or the damaged glass lens. It's the epoxy used to glue down the PCB that might rip off some components like the inductor.
It's not epoxy but soft silicone. Use hot air gun to heat the head before removing the board and it will pop out with the silicone still in place. Smile
WTB Titanium 4sevens 2xAA tube
Unheard
Unheard's picture
id30209 wrote:
It’s not epoxy but soft silicone. Use hot air gun to heat the head before removing the board and it will pop out with the silicone still in place. Smile
Thanks!
Have you successfully repaired yours?
id30209
id30209's picture
Unheard wrote:
Thanks! Have you successfully repaired yours?
All of them! Thx to Loneocean’s inputs, all are working great now.
