"Grandma" flashlight
48 posts / 0 new
mickb
Last seen: 2 weeks 18 hours ago
I have to be honest I think a flashaholics idea of an ideal light may not be an ideal light to someone who cares nothing about modes, interfaces, grip, knurling and multiple buttons. As such another vote for 1 mode basic light.
Example:My mother is in her 70’s but quite sprightly and uses a light to walk out the back to check on the animals etc. She has absolutely no interest in the vagaries of flashaholicism. I gave her what I thought was the most basic light I had being a Fenix HL23 headlamp with 3 power settings and the problem was it comes on high, and she forgets or doesnt care to turn it down. As such the battery runs down more quickly, and I find the light in the bottom of a draw one day because she got tired of continually changing batteries and/or turning the light levels down. She went back to using some cheap plastic light.
djozz
djozz's picture
Last seen: 5 hours 20 min ago
We went through what grandma (grandpa?) needs in the grandma light development thread (link) that started 2 years ago, part of the discussion is repeated here. In practice, any light that works is good enough for most old people and flashlights like that are around already. If it is unreliable, put three of those in the drawer, one will likely work.
My approach was instead not to focus exclusively on what works for eldery people, but also make it desirable for us flashlight enthousiasts (and there are eldery flashlight nuts too, as BLF proves). That is why the magnetic ring came in (every flashoholic loves that), why compactness is required (no flashoholic likes a needless bulky light), why good tint and CRI was chosen, and it must look good too!
For me, a light like that, robust, always works, does not drain when not in use, with easy to use magnetic ring, with USB-C charging, with good tint, and not overly expensive, is as desirable as any cool new cutting edge performer with latest technology. And it works for grandma too.
mickb
of all the qualities of a flashlight I would probably say tint above all else is something that means absolutely nothing to the average grandma, muggle or even security guard or cop. I think I could give my friends and even my brother who is a cop three different tinted light and ask them afterwards what their favorite tint or colour was and all would go “huh?”
LuxWad
LuxWad's picture
Last seen: 19 hours 21 min ago
Just chiming in, I think a super basic but well-made, inexpensive light like this would be a fantastic option to have, not just for grandma. I would love to see Wurkkos pursue this.
TheIntruder wrote:
Rather than trying to reinvent the wheel, develop a modern analog slide switch, and put “Off/Low/High” labels next to it, one of the oldest and simplest UI concepts around. No standby/parasitic drain to worry about either. That might come at the cost of a good IP ingress rating, but that’s probably not a concern for grandma. A rotary switch might fare better in that respect, but grandma already has issues opening pill bottles, so it’s a less preferable solution.
This multi-stage slide switch would be the ideal system I think, easy to use even one-handed, and very obvious which mode the light is set to.
Something like 50/500 lumens would be great. For a single output level, I would think around 200 lumens could accomplish just about everything.
Most importantly, the light should be available in multiple bright, fun colors. A very simple design, like this Rayovac, but aluminum:
26650 would be the ideal battery, thick and high-capacity. 26800 would be amazing form-factor wise but it’s too obscure. It would be especially awesome if it could run off either one li-ion or multiple NiMH/Alkaline cells, just because so many people are averse to good batteries.
A quality driver running an inexpensive and efficient LED, something with a good balanced beam in a larger optic… maybe XHP50? Long runtimes and low heat with consistent output should be the goal. A large triple might work well too, I can’t speak for all but I feel like grandma would appreciate a beam with good coloration, I know mine does LOL Around 5000K would be great, it’s nice and “normal” so it wouldn’t put anyone off but would still be pleasant
Lightbringer
Lightbringer's picture
Last seen: 1 hour 28 min ago
Exactly. As much as I was trying to get her into using a “real” light, she kept going back to those craptastic 3×AAA lights, because they were simple on/off, and had just enough brightness to light up what she wanted to. No crazy modes, nothing.
Again:
People don’t want ¼-inch drills, they want ¼-inch holes.
Anyone designing new drills often forgets that.
PhantomPhoton
PhantomPhoton's picture
Last seen: 18 hours 25 min ago
Definitely interested in a grandma light.
One Mode. A Medium-ish 300 Lumens is plenty.
Can take primaries. As much as we hate alkaleaks.
Inexpensive. But a 1hour shutoff timer would be great if possible
PhantomPhoton on CPF; reddit.com/r/flashlights; LPF
My rules for flashlights:
1) Always have an option for Neutral, Warm, HiCRI
2) Just say "NO!" to proprietary cells and battery packs
3) Have a KISS interface: no scrolling through blinky modes
Red Rock SAR
headband
Last seen: 1 hour 39 min ago
For the interface I would say click for high/off, hold for ramp up/down. This seems more intuitive than cycling through even 2 modes and gives more flexibility as well.
Maybe have something like 10c to toggle memory mode on/off. Would have to be something not done accidentally to have it at all.
Single 2170 with usb-c seems good. I like the idea of charging only to 80% if it’s sitting around a lot.
Maybe offer it in lh351 and sst-20 2700k, 4000k, 6500k. I think color temp is actually something a lot of people notice. Some prefer the warm color and some associate coolness with bright/high tech. But not sure if offering this many options would lead to analysis paralysis and people buying for themselves would just move on to another light, or if they would just get whatever the default on amazon was and be fine with it.
FBsLights
Last seen: 16 hours 36 min ago
Nothing with modes seems simpler than a rotary switch. It is very easy to turn, even with old hands.
Everyone knows how a volume knob works. Turn it clockwise for more output.
The Sofirn SD05 “diving” light only draws ~70uA when off. It has a 4AH 21700 battery. 4AH/70uA = 2381 days
The self drain on the battery is probably higher than that.
I checked a couple other magnetic ring dive lights marked Volador (Willcrew DX30 and DX60, thought to be manufactured by Sofirn). They also measured 70 to 80uA standby drain.
Point is, magnetic ring lights can be made with low drain. Now they need a USB port for charging. (no longer dive lights…).
The examples given are brighter than necessary. A lower output version of the SD05 with a charging port seems about perfect to me.
Since this doesn’t exist, for gift lights, I like dual switch lights with built in charging. Tail switch is on/off (most people get that), and side switch selects brightness mode. Flashlight works even if you forget it has a side switch! Problem is the charging. The tail switch is mechanical so the light must be turned “on” to charge. Not as easy or intuitive as a rotary switch, but these are available with charging.
FB
Boaz
Boaz's picture
Last seen: 12 hours 43 min ago
Get grandma a Porsche 911 and then when she says " You know I cain"t drive a stick .much less see the road .! "
 Shrug and say   "Oh man I forgot that .. can't return it so it looks like I'm stuck with it ."
"What do you think about paddle shifters granny ?"
Wurkkos
Wurkkos's picture
Last seen: 1 day 15 hours ago
After the final plan is confirmed, I will submit the project and start the design as soon as possible
Bort
Bort's picture
Last seen: 4 hours 56 min ago
What features/host are you looking at?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
alpg88
Last seen: 2 days 1 hour ago
I thought we had dozens of such lights at home depos and walmarts.
Bort
Bort's picture
They often run on C and D batteries.
alpg88
Yes as well as AA and AAA, that is exactly what you want for a grandma light. tell a grandma that batteries she uses and has to charge, can explode, or catch on fire, it will not take a second before she tells you “get that crap out of my house and never bring it here again”. i got that from not so old people, they just do not want worry about another thing that can burn their house down, or something similar. not to mention they tend to forget things, like cells in charger for days. or accidentally put a cell wrong way, or something else, (iirc we had a thread about an explosion of a battery in a charger, that was not supposed to be recharged). or was it cpf?
headband
You realize you don’t have to have a dedicated charger right? You can just build it in and have it cut off when finished charging. Cylindrical cells are safer than the pouch cells in your phone or your laptop and you don’t see people freaking out about those.
xevious
xevious's picture
Last seen: 13 hours 42 min ago
FWIW… my mother, who is a grandmother, uses a twisty light just fine. What I think would work well as a grandma light is a twisty with a low and high. And maybe a hidden SOS (low/high/off/low/high/off in continuous succession would trigger SOS).
stephenk
stephenk's picture
Last seen: 2 hours 46 min ago
Plenty of “Grandma” lights already available in hardware stores.
