CRX TiCu Bolti Triple XP-L HI 3D - Convoy 5A - 18350 - Bolt Action Sw - 1485lm.
I had thought about this build for the contest but alas could not make it.
Bolt action side switch titanium & copper flashlight.
Hand made, no lathe etc as usual.
Ti-3Al-2.5V grade 9 titanium alloy body, copper lined
Copper battery tube
Triple Cree XP-L HI 3D emitters
LED4P 20mm Copper DTP MCPCB
Carclo 10507 optic
20mm x 1.5mm ARC glass
Copper topped brass pill
Convoy 17mm 5A thermally controlled driver
Biscotti firmware
Green triple afterglow gasket
Bolt action reverse clicky side switch
Titanium bolt with two 3mm x 0.9mm green tritium vials
Ferrocium centre tail movingl switch pin
Magnetic tail (50 x 2mm neodynmium magnets)
Thermochromic black GITD tail circle
Bayonnet locking system with o-ring
18350 cell compatible
Max – 1485lm
Length – 83mm
Width – 22mm
Weight – 112g (with 18350 cell)
CRX TiCu Bolty Triple XP-L HI runtimes:
Bayonet locking system with an o-ring cut into the copper battery tube.
Bypassed tail spring.
Copper lined titanium head section.
Copper battery tube.
Two green tritium vials in the switch bolt.
Titanium alloy outer casing.
Black to green glow thermochromic tail circle.
The ferrocerium tail pin moves along with switch presses.
Magnetic tail with 50 individual magnets.
Two green tritium vilas in the head of the titanium switch bolt.
And with an even smaller 10440 cell version with Anduril
