Convoy T4
91 posts / 0 new
Tumbleweed48
On the matter of lithium primaries – I have a few Utorch UT-01’s that I’m very fond of, and they also won’t accept FRESH lithium primaries. My work-around is to run the cells for 10 or 15 seconds in another light to “blow the foam off the beer”, after which they run fine in the UT-01. I have an old Fenix light that I have to use the same trick with.
It seems like that initial 1.8 v is a spike that very quickly reduces itself to 1.5 or 1.6v for the remaining 99.9% of the cells capacity. I don’t know if that would work with the T4, but it might be worth a try.
damexoid
Last seen: 3 weeks 2 days ago
Simon Mao wrote:
mortuus wrote:
2 protected 14500 fit this light ?
too long
how long would be ‘too long’?
would something like this https://aliexpress.com/item/1005003232808394.html at 52mm be too long?
how about something like this (seems to be without protection but they don’t have length listed) https://aliexpress.com/item/32824639505.html ?
Simon Mao
Simon Mao's picture
Last seen: 16 hours 1 min ago
damexoid wrote:
Simon Mao wrote:
too long
52mm is little long,
the second link is invalid
TIFisher
Last seen: 2 days 11 hours ago
Simon – any update as to when the arc white (or grayish white) version will be available?
damexoid
Simon Mao wrote:
52mm is little long, the second link is invalid
weird. second link works for me. there is Soshine 14500 900mah button-top battery without protection.
kinda like this http://www.soshine.com.cn/a679.aspx and seems to be listed at 50mm.
would 50-51mm be the sweet spot for battery since 52mm is too long?
Simon Mao
Simon Mao's picture
Around May 20th.
Simon Mao
Simon Mao's picture
I recommend using a standard length battery, 52mm might work, but it will be very tight.
nicodimus22
Last seen: 2 hours 43 min ago
It’s May 20th. My wallet is ready!
damexoid
well, it is May 24th and no white version available (yet?) ;(
i am waiting for grey version to be delivered (with lh351d 2700k) and i would love to get while version + 519a
nicodimus22
It’s May 27th. My wallet is ready!
atobe
Last seen: 2 days 52 min ago
Simon Mao wrote:
Andometto wrote:
Hi Simon,
Do you know when the white Micro Arc Oxidation colour for the T4 will be available?
Thanks.
28-30 this month
Almost there !!!
nicodimus22
So, while I’m waiting for the MAO version to come out, is there a clear-cut best emitter for this light (especially high CRI versions from 4500K to 5000K? Floody lights (or lights that I can make a bit floody with DC-fix) with that CCT range and 90+ CRI seems to be my jam.)
Emitter choices are shown here across the bottom: https://imgur.com/a/nUaimQY
I like the 5000K LH351Ds in my Sofirn SP36. I know that the 219B 4500K is well-regarded by many, but is a bit rosy-tinted and dimmer than the rest. The newer 519A 4500K is supposed to be really good as well, but I don’t have any lights with it yet, so I can’t compare.
Which would you (or did you) get?
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 9 min ago
I’d get the 4000k SST-20, since small lights like these need the most throw possible.
Simon Mao
Simon Mao's picture
MAO T4 is ready ,
But there has been a delay in the production of the flashlight gift box, and it will take another week.
TIFisher
nicodimus22 wrote:
So, while I’m waiting for the MAO version to come out…Which would you (or did you) get?
I have the LH351D 5000K and really like it. The beam is pretty neutral, and the green AR coated lens definitely reduces the typical greenish hue of this emitter. When compared side by side with my SP10 PRO with the same die, the T4 hotspot appears to be much closer to bbl.
nicodimus22
Simon Mao wrote:
MAO T4 is ready , But there has been a delay in the production of the flashlight gift box, and it will take another week.
Looking forward to it!
QReciprocity42
Last seen: 3 days 12 hours ago
For floody high CRI between 4500-5000K, get the 519A 5000K. High CCT 519As tend to be 300K warmer than rated, so you’d expect around 4700K in practice. The higher R9 and better tint will make you want to toss the LH351D in the bin. Although rated at 90CRI, 519As seem to be consistently above 95 and average 97+.
nicodimus22
Thank you for the info, guys. I might have to get one of each!
damexoid
is there any news about MAO T4?
any plans for a UV version? would be nice to get one with Nichia UV led in there Smile
nicodimus22
For floody high CRI between 4500-5000K, get the 519A 5000K. The higher R9 and better tint will make you want to toss the LH351D in the bin.
I got both a 519A 4500K and a LH351D 5000K Convoy S2+ in the mail yesterday, and you’re right. The LH351D looks downright unpleasant and green when you put them side by side, and anything with red/brown in it looks much better with the 519A.
However, any light is useful when you need to shoo the darkness away, so it’s not a utility issue, just a cosmetic/user experience issue. I’ll probably be putting this one into storage or giving it away.
Now I’m wondering how good the SP36 would be if they put 519A or some other emitter in there instead of the LH351D.
damexoid
https://aliexpress.com/item/1005003937912964.html got grey 2700k lh351d version.
well packaged and built like a tank but interface is new to me.
aliexpress page says:
Quote:
Option 2 (normal-flash 2 times + buzz-flash): tap the switch to active the mode memory or inactive it,If the user has no operation,flashlight will enter into the last mode.
turn flashlight on -> do short clicks till it turns off to under configuration mode -> it starts buzzing (wait through it) -> it flash twice and go through buzz again (do a short click here)
but it does not seem to be able to toggle memory mode on/off. maybe i am doing something wrong?
if i turn flashlight off and then on – it cycle through the presets. like 1st group with 1%/10%/30%/100% – if i turn flashlight on 1% and then turn it off – it starts from 10%. and if i turn it off on 10% – it starts from 30% and etc
and i have found that if i do short tap before turning flashlight on – it starts from the first preset like 1% in 1st group. maybe i can turn that make it start from the first preset and/or atleast make it stop cycling through presets when you turn it off?
scs
Last seen: 1 week 5 days ago
Shoot. I should have ordered 4000K then, because I really like my E21A 3500K, and my other 3000K will look like 2700K instead, too warm for general use for me.
scs
T3 and T4 just came with 519A 3500K and 3000K.
Their CCTs don't appear lower than nominal.
T3 orange is glossier. T4 orange is more matte and a bit darker.
Protected cell in T3 is a tight fit due to stiff/long srping. 2 protected cells in the T4 will also be a tight fit.
T4 can use anti-roll flats on head.
korpzgrinda
korpzgrinda's picture
Last seen: 7 hours 42 min ago
Location: Eastern Woodlands in the Wilderness of North America
Thanks for letting us know. I have been thinking about a T3 and T4 orange combo to match my hi-viz work gear Big Smile . Kind of a bummer that the oranges don’t exactly match each other.
QReciprocity42
As mentioned before, the lower-than nominal CCT appears to only occur with high CCT 519A's, I'd say 4500K and above. (I haven't seen any data on the 4000k.) Not exactly sure why this happens.
My conjecture is that reflectors/optics blend the warmer sideways emission into the hotspot and shifts the color a bit along the BBL. A shift of constant distance along the BBL is known to affect CCT much more at the higher end; for an extreme example, even a tiny shift can move the T=infinity point to a finite-CCT point, resulting in an arbitrarily large drop in CCT.
nicodimus22
It’s finally ready!
I really hope that the MAO light gray finish eventually finds its way to the S21A as well. That would look fantastic!
dusty99
Last seen: 6 days 3 min ago
Simon: any updates on a version of the T4 that can use alkaline, NiMH, primary lithiums and 3.7v? It seems there are not many 2AA lights that can take all four chemistries/ voltages. I’d definitely be interested in a couple for backcountry use.
Simon Mao
Simon Mao's picture
i got new driver , But since I still have some old drivers left, the update will take a while.
If you need T4 with new driver, pls note your requirement in the remarks of your order
jasontheguitarist
Last seen: 10 hours 41 min ago
What are the details on the new driver? Does it support all AA types and 14500 or was there some compromise made? Still 12 groups?
Simon Mao
Simon Mao's picture
Yes, they are all compatible.
