I can see the flicker on one of my Jetbeam Rotaries, when I stare at the LED reflected in the reflector, when set to 0.1 lumens, here is the Opple data
I can also see the flicker at 0.01 lumens, (no Opple data)
I cannot see the flicket at 1 lument, here is the Opple data
I have occasionally seen the flicker, on the ceiling, when tailstanding at around 5 lumens… I have been able to make it stop by turning the light up to a higher level, and then turning it back down… I believe this is challenging the battery to stabilize its output, not sure.
In the past I suspected the issue was caused by a stuttering Protection Circuit in a battery, but Im using an Unprotected battery now.
I still dont know why this is the only one of my rotaries that flickers like this. Ive tried multiple LEDs, both 219b and 519a, and Ive tried multiple drivers. Ive cleaned all the contacts on the pill and battery, I even polished the end of the battery tube, hoping to eliminate any oxides that could be causing poor contact.
Nothing Ive tried has eliminated the flicker. I gave up trying, I still carry the light, it has my personal favorite LED atm, a dedomed 519a 4500k.
It is this light, Jetbeam TCR-1, my grail host:
I have had to let go of my expectations of perfect flat regulated outputs… the bottom line seems to be that all lights have some sort of electronic oscillation, even if it is not PWM, there can be flicker. In that regard, I really like how the Opple gives a Risk Assessment. I think frequencies above 3000hz might not be as biologically disruptive… as frequencies below 1000hz, not sure.
I dont use the light as long term ambient light, so my exposure to the flicker is not for long periods. I have not had any issues with headache or eye strain. I do however have a strong dislike for visible flicker on the target. I usually dont experience visible flicker, except as described on my ceiling. The flicker I see is when staring directly at the LED, at sublumen levels, which is not something I make a habit of doing… lol
for comparison, here is my other TCR-1 w sw45k.
On this one I cannot see the flicker. I set it to 0.1 lumens and got this Opple data:
Nothing in the Opple Data seems to show any difference to the light that I can see flicker. Iow, my eyes see stuff Opple does not capture.
