just wanted to say that I’ve tested what i thought was these batteries, that i bought from gearbest a while ago, http://www.gearbest.com/chargers-batteries/pp_43011.html
they had 3519 + 3586 mAh when tested on my opus bt c-3100 @1A. the text is different from the ones in this review, but i didn’t notice that. i think the batteries managed just under 3A when DD my UF1504 with a dedomed XP-G2 S4, my Keeppower IMR 4200mAh is ~4A there.
These INR's are lower performing, higher resistance, than the ICR's. I got a couple of them, but think my tested to the capacity what HKJ got, above 4000. Could be fakes, could be worsening quality, bad batch, etc. All the KK cells have quite a bit of piece by piece variation as well.
Really have to very cautious with GB - they sell known fakes, and even admit it - AWT "Style" cells: http://www.gearbest.com/batteries/pp_178120.html. Note my comments there. Must give them 4 or 5 stars to get published reviews. GB is just so aggressive in pricing, they cut corners everywhere they can, so their buyers buy cheap, we pay cheap, but things can go wrong as a result.
yes, so i don’t think these are king kongs…
tested my UF1504 again, and this time i got 3.5A, so the amps might be ok, but the capacity was disappointing. so don’t buy these batteries from gearbest and expect king kongs!
i don’t know where you’ve got that from, but take a look at the comparator Battery test-review 26650 comparator and you’ll see that KP IMR 4200 doesn’t share the look of the tested KK batteries at all…
did you buy yours from gearbest as well? the text on the batteries aren’t the same as in this review, but i didn’t really notice that before i ordered. i posted a negative review for trustfire 26650, that only had ~3000 mah at the same time as i posted some positive reviews for KP batteries. the positive ones showed up almost immediately, while i asked their customer service after some days why the negative hadn’t been published. after some more days even the negative review got posted. but now when i look for it, it’s gone :~ so they must have deleted it since it wasn’t positive. i should stop supporting gearbest, but i’m a sucker for low prices and (seemingly) good deals J)
Yea, HKJ's test of the KP IMR 4200's vs. the KK ICR 4200's show higher Vf on the KP's mostly, but internal resistance is lower on the KK's - usually it's the opposite. I just know KP re-labels all their cells - they don't make cells. I always assumed they were KK's because there's not much else in the market that's IMR and at that capacity, but things have changed - more offerings and sources. But also, they change cell sources in different batch's over the years as well. Me and a couple of dealers I've worked with in the past went thru a lot working with KP's - they aren't always willing to say what the cell is they use, so it can be changed anytime, resulting in differences in discharge curves and capacities. EFEST is the same way - they don't make cells, and two EFEST dealers I know can't get that info from EFEST as well.
For the KK INR's, HKJ tested them for higher internal resistance (0.08) vs the ICR (0.05), and that match's my head-to-head testing I've done in DD based lights. I've got several KK 4000's, a few KK 4200's when RIC used to sell them, and two INR 4000, plus the KK 26700's (about 8-10) which are actually the best performing of the KK's I've seen.
The 4000's could be called 4200's, or visa-versa - they perform the same and basically the same capacity, just a matter of labeling.
