I would hazard a guess that the emitter was shorted but I could be wrong. I've never had this happen before (a or b). As for what that part is, it looks like a generic version of an AMC7135 chip. I wonder if you could replace them with 7135's. I'm sure someone of the electrical genius persuasion will chime in shortly.
Unfortunately I don’t have replacement part, who has AM3400 mosfet lying around the house anyway!!!
I took it off just to see will it be hassle to do it, no problems there, I could easily solder new one if I had it…
Ordered nanjg 105C from DX, let’s hope that it will be here in 2012
P.S. If anyone have broken (and unusable) driver with this part (AC3400, working) and is willing to send
it to me I will be most grateful.
———- Komšo hvala za informaciju
I’d just get a new driver. You can also from intl-outdoors buy a single amc7135 and attempt the repair yourself. That way if it works you have a spare driver, if you fail, well you really only lost 49 cents.
Maybe I’m missing something here but I would have thought an amc7135 =/= AM3400.
Once is a self contained current regulator, the other is a power FET, of which many are probably contained within the amc7135.
You need either the exact replacement, (or equivalent). Secondly, the AMC7135 has a different footprint to the one in question (thanks scaru for bringing this to my attention)
The large tab on the "back" and the small in the middle are connected. Left one is output, right needs input to switch on. So there are 4 pins, 3 different types and all are needed.
