Quick, and probably pointless review.
These are the cheapest P60 drop-ins I have found.
First, of the Orange Peel (OP) reflector found here.
And of it's sister, the Smooth (SMO) reflector found here.
I live in the same time zone as Hong Kong, so shipping dates are accurate.
The order was placed on the 12th Jan, late at night (way past business hours, since I closed my bar that SATURDAY night).
Order was shipped on the 14th Jan in the morning, and arrived in at my home on the 25th Jan.
Despite being virtually the same thing, one costs 17c (AUD) more than the other. SMO on left, OP on right.
The SMO Drop-in (cheaper) comes with standard two contact springs, insulation separator ring and seperately wrapped reflector. (advice on seperate packaging well-heeded by FastTech.
The OP Drop-In comes with the same as above, as well as a LED Die center-er and the reflector comes in a heat-sealed anti-static bag. Shmancy.
Both reflectors from top-down view. But in excellent condition.
From the side, and semi-assembled. The SMO reflector has a brass/golden coloured spring, whereas the OP has a silver coloured one. Big deal?
What might be slightly disconcerting to the most OCD of people is the brown spatter on the side of the OP reflector. Being Aluminium, is definitely isn't rust, and it's see through so I'm assuming it's a stain from machine oil or something like that. The discolorations on the OP reflector which look like burn marks are also on the SMO. I assume they're normal.
My super accurate measuring tools, way better than digital calipers, and pretty much on par with laser measurement systems. This method determines that a 16mm star and a 17mm driver are perfect fits. Albeit a little tight.
In this last photo, if you have the most discerning of eyes, and an incredibly calibrated monitor, you'll be able to tell that the pill on the left, belonging to the SMO drop-in is brass coloured. Very yellow and shiny. The pill on the right is slightly dull and tarnished and appears to have a much higher copper content than the SMO one. It also smells like freshly machined/oxidised metal.
There's only so much crap I can ramble on about. Given my name you'd think I could ramble on forever. But, no.
Feel free to spam.
