i don’t have any tools to mod lights…
and i don’t know what i need to start with…
i can see i need a spanner wrench
can someone suggest the best adjustable spanner ??
i mean the best at a reasonable price…
there’s none at home depot or sears B&M
but online i don’t have a clue which is best
and what other tools are used most often ??
i need to change the o-rings in some zoom lights (18650 and 26650 size)
and i can’t get the zoom slide off ….
Usually, you would need a pair of Needlenose Pliers to remove the pill first. Once the pill is removed, you should be able to remove the zoom slider.
I don’t know of a good recommendation for tools (someone here will be better equipped to offer a good tool kit) but Spanners and Wrenches will most likely prove difficult to contend with.
A good soldering iron and wire strippers will help too.
Hi there, I work on watches and see smaller adjustable spanners for removing wrist watch backs on eBay all the time. Prices vary, but consider spending a little more then minimum; you will get a sturdier tool and not be buying replacements all the time. Good Luck! Grumppa
ive got an ancient compass (the kind to draw circles), and i put a nail where the pencil goes. works a treat for removing pills and opening up tail caps
