Hey guys this has been on hold for a lil while and since I got a lathe I’m working on it again it’s a 2 lens aspheric build that I got from scaru and here are some pics
Started out with a 5 inch round aluminum pipe
Bored out
U can see how nice it fits together
Bottom lens
Top lens
Side shot
Next is a retainer ring to hold the top section in place, then the handle ect…. Post any comment thanks
Can't wait to see this thing finished, so what is the plan for the LED and drive current? Nitro certainly is not exaggerating 1/2 a mile with a well driven XM-L is well within the possibilities for this thing.
Well I for got the webpage that u sent me scaru for that led setup that u told me about, where I have to send my board and LED so they can mount it ect…… I think I’m going with them if I don’t change my mind
If not ill be experimenting with all the newer LEDs that are out, and maybe trying few LEDs inside since its so darn huge
You have an awful lot of cooling there. So drive it hard.
It will be interesting to see the beam spot, with two lenses. My guess is that the image of the emitter won’t be as clear as with one thick aspheric but the spot will still be small.
Are you using 26650 batteries? If so there is a tube available that just needs a skim from the inside and is about 32mm OD. It saves heaps of machining time. Love the pics in the OP.
