In response to a post by Old-Lumens where he did a tear-down of the Nitecore EA8, I did some less destructive testing of my own on some lights. The responses were such that I felt the need to expand the testing to more lights. So here it is, my Thermal Performance test thread. In the original thread I compared the EA4W to a heavily modded HD2010. First off, those lights are not in the same class so I moved the HD2010 to a separate graph (since I have not tested another big light, I left the EA4W in there).
Power is supplied with a bench power supply. Voltage is such that fully regulated output is obtained for the entire test, but not such that excessive driver heat would occur. Supply voltage is indicated.
Small single XM-L lights
Nitecore EA4W (U2, 5.5V, Turbo), Convoy M1 (2.8A T6 3C, 3.8V, High), and Convoy C8 (2.8A U2 1A, 3.8V, High)
Time | EA4W Temperature (Deg C) |
EA4W Output (Lumens) |
EA4W Current (A) |
Convoy M1 Temperature (Deg C) |
Convoy M1 Output (Lumens) |
Convoy M1 Current (A) |
Convoy C8 Temperature (Deg C) |
Convoy C8 Output (Lumens) |
Convoy C8 Current (A) |
0:00 | 24.0 | 772 | 2.21 | 23.8 | 673 | 2.79 | 23.8 | 718 | 2.8 |
0:30 | 27.0 | 685 | 2.19 | 26.8 | 616 | 2.80 | 26.6 | 682 | 2.8 |
1:00 | 28.8 | 677 | 2.19 | 29.8 | 604 | 2.80 | 28.8 | 678 | 2.81 |
1:30 | 30.6 | 671 | 2.19 | 31.8 | 603 | 2.81 | 30.6 | 674 | 2.81 |
2:00 | 32.2 | 667 | 2.19 | 34.4 | 597 | 2.81 | 32.4 | 669 | 2.81 |
2:30 | 33.6 | 664 | 2.18 | 36.2 | 590 | 2.81 | 34.0 | 666 | 2.81 |
3:00 | 36.0 | 659 | 2.18 | 38.0 | 586 | 2.81 | 35.2 | 663 | 2.82 |
3:30 | 37.2 | 657 | 2.18 | 40.2 | 584 | 2.81 | 36.8 | 658 | 2.82 |
4:00 | 38.0 | 652 | 2.18 | 41.8 | 579 | 2.81 | 38.0 | 656 | 2.82 |
4:30 | 39.2 | 649 | 2.18 | 43.4 | 577 | 2.81 | 39.6 | 652 | 2.82 |
5:00 | 40.6 | 644 | 2.18 | 44.6 | 575 | 2.81 | 40.4 | 651 | 2.82 |
5:30 | 41.8 | 642 | 2.18 | 46.0 | 572 | 2.81 | 41.6 | 648 | 2.82 |
6:00 | 42.6 | 639 | 2.18 | 47.2 | 570 | 2.81 | 42.4 | 645 | 2.82 |
6:30 | 43.4 | 635 | 2.18 | 48.6 | 566 | 2.81 | 43.6 | 643 | 2.82 |
7:00 | 45.0 | 633 | 2.18 | 49.4 | 564 | 2.81 | 44.6 | 640 | 2.82 |
7:30 | 45.6 | 630 | 2.18 | 50.0 | 563 | 2.81 | 45.4 | 637 | 2.82 |
8:00 | 46.4 | 626 | 2.18 | 50.8 | 562 | 2.81 | 46.2 | 636 | 2.82 |
8:30 | 47.6 | 624 | 2.18 | 51.6 | 560 | 2.81 | 46.8 | 635 | 2.82 |
9:00 | 48.6 | 622 | 2.18 | 52.6 | 558 | 2.81 | 47.4 | 634 | 2.82 |
9:30 | 49.2 | 621 | 2.18 | 53.4 | 557 | 2.81 | 48.0 | 634 | 2.82 |
10:00 | 49.8 | 618 | 2.18 | 54.0 | 556 | 2.81 | 48.8 | 632 | 2.82 |
And here is the graph, current is not plotted as it is virtually flat.
The EA4W has a significant initial lumen sag during the first 30 seconds (87lm / 11.3%). In fact, the majority of this occurs in the first 7-10 seconds. I believe this is due to poor thermal contact between the emitter - star - heat sink - body. The emitter - star junction would contribute to the immediate drop (within the first second), and the other junctions for the rest. Once heat starts reaching the body, things begin to ramp at a reasonable level for a light of this thermal mass. I suspect that the emitter is running quite a bit hotter than the body. Overall drop after three minutes and 10 minutes was 113lm / 14.7% and 154lm / 20%, respectively.
The Convoy M1 has a significant initial lumen sag during the first 30 seconds (57lm / 8.5%). In this case, the majority occurs within the first 15 seconds. Intend to open this light up to look for potential issues. If anything is found, I'll note it and retest. Based on the results, I suspect a poor star-pill contact. Once heat reaches the body thing ramp as expects for a light with this small thermal mass. Overall drop after three and 10 minutes was 87lm / 13.0% and 117lm / 17.4%, respectively.
The Convoy C8 results are very impressive. It exhibited a comparatively low initial thermal sage during the first 30 seconds (36lm, 5.0%). They are very close to what I measured from a light using a copper SinkPad. I should note that with respect to power input, the C8 and M1 are identical. The thermal mass of the C8 is greater, which shows in the latter portion of the graph (final temperature is lower). Overall drop after three and 10 minutes was 55lm / 7.7% and 86lm / 12.0%, respectively.
Medium Single XM-L lights
TangsFire HD2010 (XM-L2 T6 1C, Cu SinkPad, 4.10V), Nitecore EA4W (for reference, same as above)
EA4W Current (A) |
HD2010 Temperature (Deg C) |
HD2010 Output (Lumens) |
HD2010 Current (A) |
0:00 | 24.0 | 772 | 2.21 | 23.8 | 1146 | 4.03 |
0:30 | 27.0 | 685 | 2.19 | 25.8 | 1104 | 4.03 |
1:00 | 28.8 | 677 | 2.19 | 27.4 | 1099 | 4.03 |
1:30 | 30.6 | 671 | 2.19 | 29.2 | 1092 | 4.03 |
2:00 | 32.2 | 667 | 2.19 | 30.8 | 1087 | 4.03 |
2:30 | 33.6 | 664 | 2.18 | 31.6 | 1082 | 4.03 |
3:00 | 36.0 | 659 | 2.18 | 32.8 | 1080 | 4.03 |
3:30 | 37.2 | 657 | 2.18 | 34.0 | 1076 | 4.03 |
4:00 | 38.0 | 652 | 2.18 | 35.4 | 1074 | 4.03 |
4:30 | 39.2 | 649 | 2.18 | 36.4 | 1071 | 4.03 |
5:00 | 40.6 | 644 | 2.18 | 37.2 | 1069 | 4.03 |
5:30 | 41.8 | 642 | 2.18 | 38.4 | 1066 | 4.03 |
6:00 | 42.6 | 639 | 2.18 | 39.2 | 1063 | 4.03 |
6:30 | 43.4 | 635 | 2.18 | 40.0 | 1060 | 4.03 |
7:00 | 45.0 | 633 | 2.18 | 40.6 | 1057 | 4.03 |
7:30 | 45.6 | 630 | 2.18 | 41.4 | 1055 | 4.03 |
8:00 | 46.4 | 626 | 2.18 | 42.6 | 1052 | 4.03 |
8:30 | 47.6 | 624 | 2.18 | 43.0 | 1050 | 4.03 |
9:00 | 48.6 | 622 | 2.18 | 43.6 | 1048 | 4.03 |
9:30 | 49.2 | 621 | 2.18 | 44.2 | 1046 | 4.03 |
10:00 | 49.8 | 618 | 2.18 | 44.8 | 1043 | 4.03 |
Graph
The HD2010 performs quite well. Even with the relatively high power input, initial sag is kept low (41lm / 3.6%). The SinkPad is doing it's job to quickly get heat away from the emitter. The star-pill junction is also optimized by lapping and the use of silver thermal compound. Beyond that, the pill-body contact area is significantly large (and has compound as well) so it is not a thermal bottleneck. Overall drop after three and 10 minutes was 55lm / 7.7% and 86lm / 12%, respectively.
More to come, including some bigger lights.
