I’ll see first if we can squeeze in 8x 7135 using an MCU in 20SSOP(Shrink Small Outline Package). If not, is this acceptable?
Addr1 - Unit 1 7135
Addr2 - Unit 2 7135
Addr3 - Unit 3 7135
Addr4 - Unit 4 7135
Addr5 - Unit 5 7135
Addr6 - Unit 6 7135
Addr7 - Unit 7 7135 with option to stack another 7135 for total of 8
1 could be single stack, 2 a single stack of two, 4 could be two stacks of 2. Then add a 4th group of 4 chips.
Edit: that would be 11 chips total, 4 pins. Probably more than you would want typically. But you could either not use more than 8 chips or program hidden mode for 11 chip turbo...I'm mnot making this so take my thoughts with a grain of salt.
MCU Pin 1 – 1 7135 - PWM for lowest mode, OFF or ON
MCU Pin 2 – 2 7135
MCU Pin 3 – 3 7135 - modify one to two stacks for total of 4
MCU Pin 4 – 2 7135 - modify each to two stacks for total of 4
8 solder pads for 7135
Option for 11x to 12x 7135.
We can also include Group 2 for blinkers, police, beacon, strobe and pulse
From playing with the programmable Asgard driver and using each 7135 at a time (total of 8, so 12.5% steps), I don't think it would be particularly useful like that. You'll need at least one and maybe two low modes that are less than a single full-on 7135, and then something like 1-2-4-8-chip modes. The jump between 75%/6 chips and 100% is barely noticeable.
What MCU are you guys planning to use? I see a 20pin SSOP mentioned but then the diagram shows an 8-pin device. The text looks like Z8F04 to me...if it is I should point out that the max input voltage is only 3.6V.
Actually MCU Pin 1 on post #7 is a PWM. So you can set the lowest mode from 80uA to 350mA or in steps of 1/4196 (using 16 bit PWM). You can set 1 or two modes in less than a single full-on.
Example modes:
Moonlight = 1mA >
Low = 175mA >
Low Med = 1 AMC7135 (full ON) >
Med = 2 AMC7135 >
Med HI = 4 AMC7135 >
High = 8 AMC7135 >
You can program any mode from 80uA to #AMC7135*350mA Ex. 8*350 = 2800mA).
or if stacked to 11, 11*350mA = 3850mA. I think I like this setup versus one PWM controlling all 8 AMC7135.
The original request was to individually turn on each 7135 from BHSimon. Initially I thought about using a 20pin SSOP but it looks like it’s too big for the board
PPtk’s input is to use binary addressing of 7135s which is really a great idea! We can use then an 8-pin MCU.
The diode drops the Vcc to the MCU to 4.2 - 0.7V which is around 3.5V. Testing at MFG usually test them at higher level than 3.6V so it’s OK. I have actually tested it at VBat=4.5V using a bench PS. See my DIY project here.
