Exactly the ones I showed in the pictures. Two Nimh Energizer AA’s and a cheapo 18650 cell. I set the standard 500ma for charging. It’s ok to charge Nimh and Li Ion at the same time, right?
Nimhs cell heat up at the last segment of the charging process, triggering the temperature sensors and the fan. Maha recommends a minimum of .5C charging rate for Nimh. So 500ma charging rate is too low if the cell you are charging is a 2000mah cell. The charger will not terminate properly and will heat up your cell higher and longer than if they were charged at 1A or .5C. (2000mah X .5 = 1)
I don’t have mine yet, but I’ve read that anytime the internal temp of the charger reach 40c, the fan activates automatically.
Yes, you can charge Nimh and Li Ion together, or even discharge while the other bay is in a different mode, and different charging/discharging rate.
Considering that it wasn’t designed to be easily accessible in the first place, switch durability probably wasn’t on his mind. It would be interesting to know why it was even designed with a switch, since it could’ve been jumpered to the target voltage setting and saved them a few cents per unit.
Gearbest read this thread. You will be attended to in a few hours. Monday’s business hour has just started now. It should be out in within 3 business days.
All good. They even noticed I am from down under an included a socket adaptor which inverts the phase because everything is opposite on this side of the equator. Jokes, but they did include an adaptor.
